Old 2nd July 2009, 01:03 AM   #1
Default GOOD looking PWM LED candle
after seeing other LED candles I wanted something that looked REAL, not just on n off leds.
I left the orginal code in but added //
to change the flicker just change the value of the subtraction of RandomVal
Device = 18F1320
Clock = 8
Include "IntOSC8.bas"
Include "RandGen.bas"
Include "Utils.bas"
Dim TMR2IE As PIE1.1,         // TMR2 interrupt enable
    TMR2IF As PIR1.1,         // TMR2 overflow flag
    TMR2ON As T2CON.2,        // Enables TMR2 to begin incrementing
    Signal_Pin As PORTA.0     // Signal output to frequency meter
Dim Red_Pin As PORTB.0,
    Green_Pin As PORTB.1,
    Blue_Pin As PORTB.2,
    Red_Duty As Byte,
    Green_Duty As Byte,
    Blue_Duty As Byte,
    Red_DutyVal As Byte,
    Green_DutyVal As Byte,
    Blue_DutyVal As Byte,
    RandomVal As Byte
Dim uS As Word,
    mS As Word
   // ranval(1)as word
Interrupt TMR2_Interrupt()
    High(Signal_Pin)
    Save(0)                   // Back up system variables
    If TMR2IF = 1 Then        // Check if the interrupt was from TMR2
        TMR2IF = 0            // Clear the TMR2 interrupt flag
        uS = uS + 50
        If uS >= 1000 Then
            uS = uS - 1000
            Inc(mS)
        EndIf
        Inc(Red_DutyVal)
        Inc(Green_DutyVal)
        Inc(Blue_DutyVal)
        If Red_DutyVal > Red_Duty Or Red_Duty = 0 Then
            Red_Pin = 0
        Else
            Red_Pin = 1
        EndIf
        If Green_DutyVal > Green_Duty Or Green_Duty = 0 Then
            Green_Pin = 0
        Else
            Green_Pin = 1
        EndIf
        If Blue_DutyVal > Blue_Duty Or Blue_Duty = 0 Then
            Blue_Pin = 0
        Else
            Blue_Pin = 1
        EndIf
    EndIf                     //
    Restore                   // Restore system variables
    Low(Signal_Pin)
End Interrupt
Private Sub TMR2_Initialize()
    TMR2ON = 0                // Disable TMR2
    TMR2IE = 0                // Turn off TMR2 interrupts
    PR2 = 149                 // TMR2 Period register PR2
    T2CON = %00000001         // T2CON 0:1 = Prescale
                              //        00 = Prescale is 1:1
                              //        01 = Prescale is 1:4
                              //        1x = Prescale is 1:16
                              //      3:6 = Postscale
                              //     0000 = 1:1 postscale
                              //     0001 = 1:2 postscale
                              //     0010 = 1:3 postscale...
                              //     1111 = 1:16 postscale
    TMR2 = 0                  // Reset TMR2 Value
    TMR2IE = 1                // Enable TMR2 interrupts
    TMR2ON = 1                // Enable TMR2 to increment
    Enable(TMR2_Interrupt)
End Sub
// Start Of Program...
Low(Red_Pin)
Low(Green_Pin)
Low(Blue_Pin)
Red_Duty = 30
Green_Duty = 0
Blue_Duty = 0
Red_DutyVal = 0
Green_DutyVal = 0
Blue_DutyVal =0
uS = 0
mS = 0
RandGen.Initialize(128)       // Initialize the Random Number generator
TMR2_Initialize               // Setup and enable TMR2
While True                    // Create an infinite loop
    RandomVal = RandGen.Rand  // Grab a random number from 0 to 255
    // Select RandomVal         // Find out what colour to increase/decrease
        //Case 0 To 42
             Red_Duty =RandomVal-5
                //mS = 0
             // (Red_Duty)=Rand(1)
               // Repeat
               // Until mS = 19
               // and Red_Duty>0
           // endif
        //Case 43 To 84
            If Red_Duty > 0
              Then  mS = 0
                Repeat
                Until mS = 19
                Dec(Red_Duty)
            EndIf
       // Case 84 To 127
             Green_Duty =RandomVal-20
              //Then  mS = 0
              //  Repeat
              //  Until mS = 19
              //  Inc(Green_Duty)
           // EndIf
       // Case 128 To 170
            if Green_Duty > 0
              Then  mS = 0
                Repeat
                Until mS = 19
                Dec(Green_Duty)
            EndIf
      //  Case 170 To 212
             Blue_Duty = RandomVal-30
             // Then  mS = 0
              //  Repeat
              //  Until mS = 19
              //  Inc(Blue_Duty)
           // EndIf
       // Case 212 To 255
            If Blue_Duty > 0
              Then  mS = 0
                Repeat
                Until mS = 19
                Dec(Blue_Duty)
            EndIf
            Wend
         End
any suggestions or tweeking is appreciated
MrDEB is offline
Old 2nd July 2009, 01:15 AM   #2
You've become quite the programmer MrDeb, nice work.
Bill
Smart Kits build Smart People
Old 2nd July 2009, 01:44 AM   #3
Default I try
the original code link was posted by be80be
I just majorly edited it.
just kept plugging away, trying LOTS of different things until I hiton using RandomVal then subtracting from it.
BAM it works
just needs a little clean up and tweeking.
I owe most of my programming to be80be and Pommie as well as others on this site as well as
Welcome
hopefully someday I will grasp the whole meaning of all this code.
MrDEB is offline
Old 2nd July 2009, 01:57 AM   #4
MrDeb That's what i'm talking about the looks real good you get your Pro badge tomorrow
in the mail great job. You got flow now. I like it.
be80be is offline
Old 2nd July 2009, 02:58 AM   #5
Default Thanks all
just change the -5 to -25, it looks better (a better flicker)
now to get back to the critter ridder.
I got a code that will compile but havn't actually tried it out.
I will be looking for that pro badge in the mail
Hey be80be have you tried seeing this code in action.
I only have 3 blue LEDs but maybe tomorrow will try for a red, bkue and yellow LEDs anmd a styrofoam cup
MrDEB is offline
Old 2nd July 2009, 03:11 AM   #6
I was going to load her up now and see what how it looks
be80be is offline
Old 2nd July 2009, 03:45 AM   #7
I tried it the Red_Duty led works real good the blue and green don't work but it would
make a candle with the red led just need to get blue and green to work
be80be is offline
Old 2nd July 2009, 12:06 PM   #8
Default WHY don't the blue n green work??
I have LEDS on pins 8,9,17,18
the pins 8,9,17 are the ones I have to come on.
if you can't get all to work then your worrying me.
hopefully there is not a problem with my code??
keep me updated.
MrDEB is offline
Old 2nd July 2009, 01:24 PM   #9
Default video if I did it right
YouTube - LED candle using PWM
I only have blue connected to test board.
final will have blue, red and green behind an obscure yellow glass
MrDEB is offline
Old 2nd July 2009, 02:09 PM   #10
did darth vader shoot that video?
OutToLunch is offline
candle, good, led, pwm
LED candle effect using PWM MrDEB Micro Controllers 10 26th June 2009 12:26 PM
Led candle with 16f84a gregted Micro Controllers 4 3rd March 2009 02:01 PM
And you though the candle and nail hoax was bad! Andy1845c Chit-Chat 62 25th November 2007 10:41 PM
Candle Light Dudeler General Electronics Chat 2 29th April 2004 07:13 PM
Way to Light A candle yojo77 General Electronics Chat 10 23rd December 2003 03:30 AM
