hello, I have tried to program PIC18F4550 using microbrn and have the folllowing error ROM ERROR at 0x0016 Good 0x0EA5 Bad 0x0E21 I thought that the pic is faulty so I tried too more pics with the same error note: I program using mikroC please if any one program this pic please send yr experience Last edited by mrDiode; 30th June 2009 at 10:03 AM. | |
Hi, Are you using kitsrus.com Kit128 as programmer? Is it custom built or genuine? Has it programmed other PICs? Is your pic supported by Kit128/Microburn at all?
__________________ "The only thing worse than getting an error message is not getting an error message." - Allen Downey | |
| | #3 | |
it is custom built and I have programmed other pics as pic18F452,16F series Quote:
do anyone know a solution for this problem?????????/ also I would want to know from PIC18F4550 programmers using mikroC what is the project properties used Last edited by mrDiode; 2nd July 2009 at 10:50 AM. | |
| No. But I suggest you build PICkit2. Schematics are in PK2 datasheet. Or you can build (or buy) Junebug - the pickit2 clone. It is 2in1 (tutor + programmer) but if you do it yourself, you can build only the programmer part. I have built it and it works *much* better than my old kit128. The latter doesn't support many newer chips and it is not actively developed anymore. Try to form your question better.
| | #6 |
what are the project properties when programming 18F4550 using mikroC
| | #7 |
please , i also have the same pb with pic184550: did you solved your pb ? I have Rom error at 0x0000 good at 0xEF59 bad at 0x2000; with the menu help at protocol it is said "system mismatch; use old micropro to update firmware to match new microbrn" Please , how to do it ? remarque : No pb with pic 18f252 and all pic16 | |
| | #8 |
I programm with mcc18 .
| | #9 |
I have used MicroC pro Ide with a 18f4550 and no problems just set the Ide to use 18f4550 and set the configure and your good to good
| error, microbrn, pic |
| PIC18F4550 I/P help | Laupdior | Micro Controllers | 3 | 19th April 2009 01:29 AM |
| pic18f4550 | oussamasgh | Micro Controllers | 10 | 4th April 2009 05:53 PM |
| Pic18f4550!! | watzmann | Micro Controllers | 1 | 20th March 2008 11:59 AM |
| PIC18F4550 and USB | max2005 | Micro Controllers | 3 | 5th July 2005 06:39 PM |
| Need Assistance , Another Verify Error At OOOOh! Error | MindShaper | Micro Controllers | 0 | 4th September 2003 03:05 PM |
