| | #106 |
3v0 i think i finally understand that Multitasking stuff a bit thanks to your PDF. But i noticed some error or something you forgot to edit.. For instance check out page 8 on the left side the line of code: Code: #define DUR 500
__________________ AtomSofts eBay Store AtomSoftTech: C18 TIPS & TRICKS v9 PDF Nokia 6100 Driver/Software My Name: Jason Lopez http://atomsofttech.info/ | My YouTube Videos! My Favorite Store: dipmicro Electronics | |
| | #107 |
I will try to create my own code following yours but with 3 task! 1. Blink LED 1/4 Second. (not half) 2. Sound speaker (just for fun) 3. Something complicated like write to a char LCD What should happen if one TASK last to long? Would it be ok to mix some Non Multitasking like normal init stuff with some multitasking after? this way i have a normal flow of items initializing and then the multi. stuff after
__________________ AtomSofts eBay Store AtomSoftTech: C18 TIPS & TRICKS v9 PDF Nokia 6100 Driver/Software My Name: Jason Lopez http://atomsofttech.info/ | My YouTube Videos! My Favorite Store: dipmicro Electronics Last edited by AtomSoft; 2nd September 2009 at 07:08 AM. | |
| | #108 |
| What should happen if one TASK last to long? As you know each task is broken down into states. It is up to the author to ensure that no task state runs too long. If a state runs too long other tasks that are ready to run will be delayed. In some cases that is no problem. In time critical tasks it is.Would it be ok to mix some Non Multitasking like normal init stuff with some multitasking after? There is no problem with running non multitasking code prior to starting multitasking. Once you start the multitasking engine any code that executes must yield or it will screw up the scheduling system.The use of cooperative multitasking does not limit the complexity of the code or any given task. As long as you ensure that each state yields instead of waits, and never runs longer then the timer without yielding, any task length is possible. The one thing I did not address was interrupts. The system works much better will polling. With a little work you can extend the system to block waiting for any given register flag. But putting a IO task first in the list it will execute with within 1 timer period of the interrupt. You can use interrupts but you need to be sure the interrupt routine + any task does not exceed the length of the timer. If the interrupt happens more then once during the execution of a task state it may fall apart. If you increase the timer duration tasks can run longer prior to yielding but it will be impossible to run tasks that require frequent execution. Thank for the info on the error in the text. 3v0
__________________ Please post questions to the forums. PM's are for personal communication. BCHS/3v0's Tutorials Junebug USB PIC programmer kit., USB Bit Whacker, The 15 Minute Printed Circuit Board! (+drill time) | |
| | #109 |
heh my help was small yours help is better heh thanks. I understand it more now. So it would be best to cut my code into sections like you did with the blink ... Like when sending characters send about 2 to lcd then run back to main and then if free time then it will resume until all characters are sent. since this is fast most likey it shouldnt bother. Also instead of 2 characters maybe around 5 at a time before yielding and checking if another item needs time.
| | #110 | |
Yes. That is a blunder on my part. DUR is just the index of a timer used for the duration. It has been fixed and uploaded thanks. 3v0 Quote:
__________________ Please post questions to the forums. PM's are for personal communication. BCHS/3v0's Tutorials Junebug USB PIC programmer kit., USB Bit Whacker, The 15 Minute Printed Circuit Board! (+drill time) | ||
| | #111 | |
__________________ Please post questions to the forums. PM's are for personal communication. BCHS/3v0's Tutorials Junebug USB PIC programmer kit., USB Bit Whacker, The 15 Minute Printed Circuit Board! (+drill time) Last edited by 3v0; 2nd September 2009 at 01:55 PM. | ||
| | #112 |
heh thanks !
| | #113 |
You're already ahead of me Jason, I still haven't got a timer interupt to fire properly, not that I can tell anyway.
__________________ -Paul | |
| | #114 |
For the multitasking demo there is a zip file you can download with a MPLAB project that is compiled and running. The link is on the same line as the pdf. 3v0
| | #115 |
if i start college soon (as i plan to) i will create videos of all my workings this way i can reteach myself since ill be busy with work, school and family. i will of course share my vids. But im in no way ahead. I just understand the theory. I think in my C18 sheet i have timer code but not 100% sure but as 3v0 said his code is downloadable and working . at least you can download that step through it a bit and then edit it to your liking. Then when you get better you can create a template and reuse it when ever.
| | #116 |
I'm not sure what is keeping this timer interrupt from acting as expected. I know it could be a lot of thigns, since I haven't done much with timers. I'm working on modifying code from chapter 5 of this pdf (the Mplab c18 compiler users guide) Code: #include <p18cxxx.h>
#include <timers.h>
#define NUMBER_OF_LEDS 8
long int counter = 0;
/* 6 */ void timer_isr (void);
/* 7 */
/* 8 */ static unsigned char s_count = 0;
/* 9 */
/* 10 */ #pragma code low_vector=0x18
/* 11 */ void low_interrupt (void)
/* 12 */ {
/* 13 */ _asm GOTO timer_isr _endasm
/* 14 */ }
/* 15 */
/* 16 */ #pragma code
/* 17 */
/* 18 */ #pragma interruptlow timer_isr save=PROD
/* 19 */ void
/* 20 */ timer_isr (void)
/* 21 */ {
/* 22 */ static unsigned char led_display = 0;
/* 23 */
/* 24 */ INTCONbits.TMR0IF = 0;
counter += 1;
/* 25 */
/* 26 */ s_count = s_count % (NUMBER_OF_LEDS + 1);
/* 27 */
/* 28 */ led_display = (1 << s_count++) - 1;
/* 29 */
/* 30 */ PORTB = led_display;
/* 31 */ }
/* 32 */
/* 33 */ void
/* 34 */ main (void)
/* 35 */ {
/* 36 */ TRISB = 0;
/* 37 */ PORTB = 0;
/* 38 */
/* 39 */ OpenTimer0 (TIMER_INT_ON & T0_SOURCE_INT & T0_16BIT);
/* 40 */ INTCONbits.GIE = 1;
/* 41 */
/* 42 */ while (1)
/* 43 */ {
/* 44 */ }
/* 45 */ }
edit, forgot the details, if I monitor timer0L I get seemingly random variation, perhapse because its looping too fast for me to really tell. The counter varaible seems to stay the same.
__________________ -Paul Last edited by Triode; 3rd September 2009 at 02:53 AM. | |
| | #117 |
Timer1 is classed as a peripheral and so you need to set INTCONbits.PEIE. Mike. | |
| | #118 |
3v0, Ive been trying your tutorial, but I'm having the same problem as when I write my own timer programs, it just sits as if the timer isn't ticking. I have the code unedited, except for arranging the files into a project so it compiles in C18, and for example, now I have it set to pattern four, and the first two LEDs light, and stay lit. I just cant get that timer to actually run. the only warning I get is a few "call of function with out prototype" ones, referring to the part where the switch executes the led patterns. In case any thing is wrong, or for those who haven't seen the code, here it is. The only change Ive made is to lock the selection to pattern 4, just so I know that the switching isn't the problem. I did that just recently, but the problem with stalling at the first step of the pattern was the same. Code: /*
* Junebug Demo
* Purpose: Demonstrate cooporative multitasking
* using only the Junebug LED display
* File: DJ_coop.c
* Software: BoostC or Microchip C18 compilers
* Hardware: Junebug (or other debugger + breadboarded circuit)
* by Daniel Johnson
* July 2008
#include "multiCompiler.h"
// defines & macros
#define byte unsigned char
#define TRUE 1
#define FALSE 0
#define LED_PATTERN_MAX 4
#define INITIAL_PATTERN_ID 2
#define COUNTER_MAX 3
#define C_DEBOUNCE 0
#define C_DELAY0 1
#define setCounter(X,Y) counter[X] = Y
#define SET_LATA(val,mask) lata_=(lata_&~mask)|(val&mask)
#define SET_TRISA(val,mask) trisa_=(trisa_&~mask)|(val&mask)
// global vars
// counters triggered by timer0
unsigned int counter[COUNTER_MAX];
byte ledPatternChanged;
byte seenTimerInterrupt;
#include "LED.c"
// functions
// Update counters and set seenTimerInterrupt flag
void interrupt(void)
byte cNum;
intcon_.TMR0IF = 0; // always clear the IF
for (cNum=0; cNum<COUNTER_MAX; cNum++)
if (counter[cNum] != 0) // hold at 0
counter[cNum]--;
seenTimerInterrupt = TRUE;
// Read portb and determine switch settings
byte readSwitches(void)
byte readVal,switchVal;
readVal = portb_;
switchVal = 0;
if (!(readVal & 0x01)) switchVal += 0x01;
if (!(readVal & 0x04)) switchVal += 0x02;
if (!(readVal & 0x20)) switchVal += 0x04;
return switchVal;
// Determine led pattern base on switches
byte setPattern(byte switchVal)
static byte ledPatternId_ = INITIAL_PATTERN_ID;
ledPatternChanged = TRUE;
if (switchVal==1)
ledPatternId_=0;
else if ((switchVal==2) && (ledPatternId_<LED_PATTERN_MAX))
++ledPatternId_;
else if ((switchVal==4) && (ledPatternId_>0))
--ledPatternId_;
else
ledPatternChanged = FALSE;
return ledPatternId_;
void main (void)
byte switchVal = 4;
byte i, ledPatternId;
// sundry setup
// speed up the clock to 8MHz, 18F1320
osccon_.IRCF0=1;
osccon_.IRCF1=1;
osccon_.IRCF2=1;
// configure ports
adcon1_ = 0xFF; // all digital
intcon2_.RBPU = 0; // PORTB weak pullups on
trisb_ = 0xFF; // all inputs
lata_ = 0;
trisa_ = 0; // all outputs
// configure Timer0
t0con_ = 0xD0;
intcon_.TMR0IF = 0; // clear the IF
intcon_.TMR0IE = 1; // Enable Timer0 overflow interrupt
t0con__.TMR0ON = 1;
intcon_.GIE = 1;
// general init
ledScan = 1;
ledIdx = 0;
seenTimerInterrupt = FALSE;
ledBits = 0x3F;
ledPatternId = INITIAL_PATTERN_ID;
// zero out the counters
for (i=0; i<COUNTER_MAX;i++) counter[i] = 0;
while (1)
// task1 - turn on the correct LEDs
serviceLEDs();
// task2 - read the switches to select correct LED action
if ((!counter[C_DEBOUNCE]) && (switchVal=readSwitches()))
setCounter(C_DEBOUNCE,1000);
ledPatternId = setPattern(switchVal);
// task3 - animate the LED display
//for testing
ledPatternId = 4;
switch (ledPatternId)
case 0: // turn off the display
ledBits = 0;
break;
case 1: // 1st LED to blinks
blinkLed();
break;
case 2: // alternate 135 and 246
alternateLEDs();
break;
case 3: // 2 LEDs left to right
marchLEDs();
break;
case 4: // 2 LEDs left to right and back
marchBackLEDs();
break;
{ // option sychronization
#ifdef sync_loop
while(! seenTimerInterrupt); // wait for timer interrupt
#endif
__________________ -Paul Last edited by Triode; 5th September 2009 at 06:12 AM. | |
| | #119 |
In file multicompiler.h change Code: #pragma code low_vector=0x18 Code: #pragma code low_vector=0x08 This is a bug in my code that did not cause problems until Microchip changed to the new header files. I think it has now been fixed in all the project zip files. 3v0
__________________ Please post questions to the forums. PM's are for personal communication. BCHS/3v0's Tutorials Junebug USB PIC programmer kit., USB Bit Whacker, The 15 Minute Printed Circuit Board! (+drill time) Last edited by 3v0; 5th September 2009 at 09:32 AM. | |
| | #120 |
call of function with out prototype means that function is not seen by the main. Try adding: Code: void interrupt(void); byte readSwitches(void); byte setPattern(byte switchVal); void main (void); #include "multiCompiler.h"
| c18, questions |
| A few questions | erosennin | Feedback/Comments | 24 | 29th November 2007 12:08 AM |
| 2 questions | juan123 | Electronic Projects Design/Ideas/Reviews | 5 | 27th September 2007 03:46 AM |
| A few questions. | Marks256 | General Electronics Chat | 55 | 5th August 2006 11:49 PM |
| few questions | Victor Frankenstein | General Electronics Chat | 13 | 5th July 2005 07:29 PM |
| Questions? | Philipc | Electronic Projects Design/Ideas/Reviews | 4 | 7th August 2003 07:18 PM |
