| | #76 |
So it would be this maybe Code: void send_nibble(byte b) {
LCD_PORT = (LCD_PORT & 0xE1) | ((b & 0x0f)<<1);
strobe();
and the E1 makes it use the lower PORTA LCD.h should look like this Code: /* * PIC 16F886 HD44780 LCD Driver * Author: solarwind * Date: 2009-01-31 * Email: x.solarwind.x@gmail.com * Compiler: Microchip C18 (v3.22) * * Pin Configuration: * The LCD's data 4 - 7 pins should be connected to bits 4 - 7, * respectively, of any port you wish to use on your PIC. * * The E, R/W and RS pins can be connected to any unused port at * any pin. * * My configuration is as follows: * LCD PIC * 16 BK- * 15 BK+ * 14 D7 -> RA4 * 13 D6 -> RA3 * 12 D5 -> RA2 * 11 D4 -> RA1 * 10 D3 * 9 D2 * 8 D1 * 7 D0 * 6 E -> RB1 * 5 R/W -> RB3 * 4 RS -> RB4 * 3 VO * 2 VDD * 1 VSS * * Note: * This driver is designed to work with almost any PIC 18. Be sure to * correctly initialize your PIC, correctly connect your LCD and * define your connections below. * * Note: * DDRAM Addresses are as follows on 16 x 4 displays: * * Line 1: 0x00 -> 0x0F * Line 2: 0x40 -> 0x4F * Line 3: 0x10 -> 0x1F * Line 4: 0x50 -> 0x5F * */ #ifndef LCD_H_ #define LCD_H_ #include "main.h" //Define your LCD's data PORT here: #define LCD_PORT PORTA //Define your LCD's control pins here: #define LCD_E PORTBbits.RB1 //Enable #define LCD_RW PORTBbits.RB3 //Read/write #define LCD_RS PORTBbits.RB4 //Register select void strobe(void); //Strobes the enable pin of the LCD void send_nibble(byte b); //Send high nibble of byte b to LCD void send_byte(byte b); //Send entire byte b to LCD via 4 bit interface void send_cmd(byte b); //Send command to LCD void send_data(byte b); //Send data to LCD void set_cursor(byte row, byte col); //Set cursor position at (row, col) void cursor_on(void); //Turn on cursor void cursor_off(void); //Turn off cursor void cls(void); //Clear screen void sc_r(void); //Scroll all lines one character right void sc_l(void); //Scroll all lines one character left void home(void); //Send cursor to top-left position byte b2hc(byte data); //Convert lower nibble of byte data to an ascii character void lcd_init(void); //Initialize LCD #endif /*LCD_H_*/ Code: #include "LCD.h"
#include "delay.h"
void strobe() {
LCD_E = 1;
Nop();
LCD_E = 0;
Nop();
LCD_PORT = (LCD_PORT & 0xE1) | ((b & 0x0f)<<1); // changed this to use low pins porta
strobe();
void send_byte(byte b) {
send_nibble(b); //Send high nibble
send_nibble(b << 4); //Send low nibble
void send_cmd(byte b) {
LCD_RS = 0; //Command mode
send_byte(b);
delay5ms();
void send_data(byte b) {
LCD_RS = 1; //Data mode
send_byte(b);
delay100us();
void set_cursor(byte row, byte col) {
byte command = 0x80;
switch(row) {
case 1:
command += col - 1;
break;
case 2:
command += 0x40 + col - 1;
break;
case 3:
command += 0x10 + col - 1;
break;
case 4:
command += 0x50 + col - 1;
break;
default:
command += col - 1;
break;
send_cmd(command);
void cursor_on() {
send_cmd(0x0E);
void cursor_off() {
send_cmd(0x0C);
void cls() {
send_cmd(0x01);
void sc_r() {
send_cmd(0x1E);
void sc_l() {
send_cmd(0x18);
void home() {
send_cmd(0x02);
byte b2hc(byte data) {
switch(data & 0x0F) {
case 0:
return '0';
case 1:
return '1';
case 2:
return '2';
case 3:
return '3';
case 4:
return '4';
case 5:
return '5';
case 6:
return '6';
case 7:
return '7';
case 8:
return '8';
case 9:
return '9';
case 10:
return 'A';
case 11:
return 'B';
case 12:
return 'C';
case 13:
return 'D';
case 14:
return 'E';
case 15:
return 'F';
return 0;
void lcd_init() {
delay100us(); //Delay for LCD to start itself up
LCD_E = 0;
LCD_RW = 0;
LCD_RS = 0;
//Start initializing the LCD
send_nibble(0x30);
delay5ms();
send_nibble(0x30);
delay5ms();
send_nibble(0x30);
delay100us();
send_nibble(0x20); //4 bit interface
delay100us();
send_cmd(0b00101000); //Function set: 4 bit interface
send_cmd(0b00001110); //Display on/off: display on, cursor on, blink off
send_cmd(0b00000110); //Entry mode: increment, no shift
send_cmd(0b00000010); //Cursor home
send_cmd(0b00000001); //Clear DDRAM/LCD
delay5ms();
| | #77 | |
Hi i do have another thread going on but since i found this one so i will go ahead and post my questions here k. 1)Can we have multiple source codes(not included as functions in header files) in a C18 project.This will help if one is working on multiple devices and rather then going through the process of putting the code in to one file(a huge head ache) one can just add them and link them.If so then how?(sorry my C has just dried up...) 2) A question about pointers, by looking at some code (thanks to Mike @ Pommie) i did get some idea of how a pointer can be used. The transfer was understandable and i post my question in the code given below: Quote:
PIC C18 Compiler Issues: Pointers, Function Prototypes I understand the transfer but then if i want to access the first character of our transferred string then this char *dstring; *dstring++=*pdata++;// may be wrong! Isnt *pdata now pointing to the last element? if i want to access the first element then will have to initialize it at a known location using pragma? Also i dont get the difference between using and not using *, what does it mean...in Simple C its & so its very clear.
__________________ Syed Last edited by Wond3rboy; 11th August 2009 at 07:29 AM. | ||
| | #78 |
To access the first character of the transferred string you would use dataArray[0]. If you have a pointer p then you can set it to point to a variable by doing p=&Var. That is that you set it to the address of Var and so p contains an address. To find out what is contained in Var we have to tell the compiler that we want the value of the location at address p. We do this by using * before the pointer. So, if Var is a char at address 0x23 and we do Var=0x45 then p=&Var will set p to 0x23 and the value of *p will be 0x45. I don't think I explained that very well. ![]() Mike. | |
| | #79 |
You did fine,thank you.This is like simple C, i can use this in C18?What does this imply then pData=dataArray; It does not specify whether you are using it for addressing or data.Thats what got me confused. Thanks for your reply.
__________________ Syed | |
| | #80 |
It is a rather confusing way to write it. You need to know the data types of the two variables to know what it is doing. A less confusing way would be, pData=&dataArray[0]; Mike. | |
| | #81 |
| Code: #include<p18f1320.h>
char * data=00;// Initiazlizes it to zero so the array is saved on
// first location and one can retrieve it.
void main(void)
rom near char * pname;
static rom near char name[]="Hi";
pname=name;//pointer points to first element of name
*data++=*pname++;
*data ++=*pname++;
data=data+20;;
pname=name;
*data++=*pname++;
*data ++=*pname++;
while(1);
//void main(void)
////static rom near char name[]="Hi";
//*data++=name[];
//*data ++=pname[];
//while(1);
data=0x20; It says wrong assignment.But the addition thing works fine. I want to first store it from ram location 00 and then be able to access it using the pointer.Also & is illegal in C18.
__________________ Syed Last edited by Wond3rboy; 12th August 2009 at 07:49 AM. | |
| | #82 |
When you are working in C, you can't just write to any memory. The C compiler will allocate memory and if you need a block for yourself then you should allocate it as an array. You can do malloc in BoostC but I'm not sure in C18. Why do you say & is illegal? You can do, Code: #include<p18f1320.h>
char chrArray[40];
char * data=chrArray;
void main(void)
pname=&name[0] ;//pointer points to first element of name
*data++=*pname++;
*data ++=*pname++;
data=data+20; //will point to chrArray+22 (20+2 increments)
pname=name;
*data++=*pname++;
*data ++=*pname++;
while(1);
Mike. | |
| | #83 | |
You can also link in compiled objects by adding .o files to the objects list. 3v0
__________________ Please post questions to the forums. PM's are for personal communication. BCHS/3v0's Tutorials Junebug USB PIC programmer kit., USB Bit Whacker, The 15 Minute Printed Circuit Board! (+drill time) Last edited by 3v0; 12th August 2009 at 10:20 AM. | ||
| | #84 |
Just to make this clear as possible Bit Manipulation: PORTAbits.RA1 - Use this to read a bit/pin value (can be used like LATA also) LATAbits.LATA1 - Use this to set a pin High or Low TRISAbits.TRISA - Use this to set a pin input or output Byte(whole port) Manipulation: PORTA - Modifying this will alter every pin on PORTA/LATA register. Reading it will result in all PORTA pins data. LATA - Modifying this will alter every pin on LATA/PORTA register TRISA - Modifying this will alter every pin in TRISA register
__________________ AtomSofts eBay Store AtomSoftTech: C18 TIPS & TRICKS v9 PDF Nokia 6100 Driver/Software My Name: Jason Lopez http://atomsofttech.info/ | My YouTube Videos! My Favorite Store: dipmicro Electronics | |
| | #85 |
Thanks for your replies all. Thanks had posted a question here but worked it all out.In order to use multiple source files in our project, we need to have one file with main and all that stuff and others which simply define functions and their respective variables.And arguments to functions need not be declared as global variables.
__________________ Syed Last edited by Wond3rboy; 12th August 2009 at 02:37 PM. | |
| | #86 |
you have to include the PICs header. Or the generic which is p18cxxx.h. When you include that it will have all the definitions for the selected device in MPLAB. Meaning it looks for your device setting in mplab and uses the appropriate header.. So if 18f1320 is selected in MPLAB it will use.... p18f1320.h Which includes the definitions and info for every register on that pic. EDIT: Reuse is up to how you code it. If you use definitions in your code then its easy to move over to other PICs and even to AVRs and ARMs. I have taken most of my PIC code and turned it into ARM in minutes. Its easy! as long as you code it right. Instead of straight calling like LATAbits.LATA1 = 0; Define it : #define LED_Ready LATAbits.LATA1 and in your code use LED_Ready = 0; This way when you move it over you can alter just the definition and the rest of the code follows
__________________ AtomSofts eBay Store AtomSoftTech: C18 TIPS & TRICKS v9 PDF Nokia 6100 Driver/Software My Name: Jason Lopez http://atomsofttech.info/ | My YouTube Videos! My Favorite Store: dipmicro Electronics Last edited by AtomSoft; 12th August 2009 at 02:30 PM. | |
| | #87 |
Thanks for the pointer Atomsoft.I was editing my previuos query.
__________________ Syed Last edited by Wond3rboy; 12th August 2009 at 02:38 PM. | |
| | #88 |
heh ok just noticed it above
| | #89 |
Hi, i wanted a bit to be used for indication but found out that C18 doesnt support the bit data type .Secondly, a question regarding multiple source files.Is there some way one can have variables that are accessible in both files?
| | #90 | |
shareStuff.hMaybe if you give a bit more detail on what you mean by indication we can help you on your bit problem. 3v0
__________________ Please post questions to the forums. PM's are for personal communication. BCHS/3v0's Tutorials Junebug USB PIC programmer kit., USB Bit Whacker, The 15 Minute Printed Circuit Board! (+drill time) Last edited by 3v0; 16th August 2009 at 02:24 PM. | ||
| c18, questions |
| A few questions | erosennin | Feedback/Comments | 24 | 29th November 2007 12:08 AM |
| 2 questions | juan123 | Electronic Projects Design/Ideas/Reviews | 5 | 27th September 2007 03:46 AM |
| A few questions. | Marks256 | General Electronics Chat | 55 | 5th August 2006 11:49 PM |
| few questions | Victor Frankenstein | General Electronics Chat | 13 | 5th July 2005 07:29 PM |
| Questions? | Philipc | Electronic Projects Design/Ideas/Reviews | 4 | 7th August 2003 07:18 PM |
