yes I have looked at the one on the mondo site. all it does is turn the leds on n off . no big deal but it dosn't flicker like a real candle I looked and pasted the PWM code from swordfish but keep hanging up on start1 or ?? need to investigate further. my idea is to use a random num gen in conjunction with PWM saw a video of an array of 12 LEDs that fade from 100% to 0% and back. copied n pasted and it hanges up on the START1() will post code later. I am worried why my timer hasn't timed out yet?? another project. | |
| | #2 | ||
__________________ Please post questions to the forums. PM's are for personal communication. BCHS/3v0's Tutorials Junebug USB PIC programmer kit., USB Bit Whacker, The 15 Minute Printed Circuit Board! (+drill time) | |||
Hi, You can make a candle simulator pretty nice with a bi color LED, green and red. When green and red mix they make amber. A real candle has somewhat constant intensity, but the physical position of the flame varies. By using a bi color LED with two dies inside and a frosted lens, when the PWM remains around 100 percent (sum of both LEDs) the intensity shifts from the red to the green, then back again according to a random number calculation. As the modulation shifts, the position of the light source actually truely shifts too and so gives the impression that a flame is dancing around inside the LED. I would imagine that this would also work with one green LED and one red LED, inside of a small enclosure shaped maybe like one of those flame shaped incandescent bulbs, with a frosted outside coating to diffuse the light. I actually built one of these just as a test to see how the (then board sized) microcontroller board was working. It's amazing how when you look at it it gives you the distinct impression that you are looking at a small candle flame. It even makes you feel like it is too hot to touch, and may even fool you into thinking it is actually warm when you touch it. It's an amazing illusion if done right. If i remember right, the PWM is gradually shifted from the red to the green, then back again, but the total intensity is also varied a little, from maybe 100 percent down to 50 percent, but not too low as to blank out the light totally. Also, 100 percent green or 100 percent red is never allowed, so the limit is maybe something like 80 percent for any one LED. You could try different limits to see what looks the most realistic. Last edited by MrAl; 24th June 2009 at 04:35 PM. | |
| | #4 | ||
you have to change color for a flicker. He using a 6.3 volt lamp Quote:
or just a red and maybe a blue. the leds are going behind an obscure yellow glass looking from the front= yellow obscure glass, 1/2inch space w/ LEDs in bottom of opening, a mirror. there are two windows (2"x5") on an 8 sided octagon box. has two doors in front. sides made of English walnut with each corner with hard maple inlay to accentuate the corners bottom and top to be star burst pattern (walnut and maple) when I get it done will post pics just want to simulate a burning flame and the "flame" controlled by a photo transistor. only on at dark. | |
| | #6 |
take a look at this. Swordfish Tutorial - Red Green Blue (RGB) LED I tried it and change it some you can do some real cool thing with rgb leds and this code. | |
| | #7 |
I really don't want to buy a crystal and another chip but I need to order some parts anyway. do you think the code can be converted for the 1320?? and run at 8mhz instead of 20?? I am still trying to figure out a timer. I thought I had one working (2x be be exact) been trying to tweek the longdelay code for a 20 minute off/5sec on in the code I need to add a temp delayms as the LED flashes tooo fast I think and I miss the event. | |
| | #8 |
Here MrDeb save the zip and unzip it and open the rgb with swordfish try it out you can use 3 leds on portb 0to2 any color just to try it use 150ohm resistors for all led pins it's for a 18f1320 Last edited by be80be; 25th June 2009 at 02:40 AM. | |
| | #9 |
want to change ms for each color so I used ms() but keep getting an error on the ms() dim syntax Code: Device = 18F1320
Clock = 8
Include "IntOSC8.bas"
Include "RandGen.bas"
Include "Utils.bas"
Dim TMR2IE As PIE1.1, // TMR2 interrupt enable
TMR2IF As PIR1.1, // TMR2 overflow flag
TMR2ON As T2CON.2, // Enables TMR2 to begin incrementing
Signal_Pin As PORTA.0 // Signal output to frequency meter
Dim Red_Pin As PORTB.0,
Green_Pin As PORTB.1,
Blue_Pin As PORTB.2,
Red_Duty As Byte,
Green_Duty As Byte,
Blue_Duty As Byte,
Red_DutyVal As Byte,
Green_DutyVal As Byte,
Blue_DutyVal As Byte,
RandomVal As Byte
Dim uS As Word,
Dim mS() As Word
//dim mSb As Word
//dim mSg As Word
Interrupt TMR2_Interrupt()
High(Signal_Pin)
Save(0) // Back up system variables
If TMR2IF = 1 Then // Check if the interrupt was from TMR2
TMR2IF = 0 // Clear the TMR2 interrupt flag
uS = uS + 50
If uS >= 1000 Then
uS = uS - 1000
Inc mS(r)
IncmS(b)
IncmS(g)
EndIf
Inc(Red_DutyVal)
Inc(Green_DutyVal)
Inc(Blue_DutyVal)
If Red_DutyVal > Red_Duty Or Red_Duty = 0 Then
Red_Pin = 0
Else
Red_Pin = 1
EndIf
If Green_DutyVal > Green_Duty Or Green_Duty = 0 Then
Green_Pin = 0
Else
Green_Pin = 1
EndIf
If Blue_DutyVal > Blue_Duty Or Blue_Duty = 0 Then
Blue_Pin = 0
Else
Blue_Pin = 1
EndIf
EndIf //
Restore // Restore system variables
Low(Signal_Pin)
End Interrupt
Private Sub TMR2_Initialize()
TMR2ON = 0 // Disable TMR2
TMR2IE = 0 // Turn off TMR2 interrupts
PR2 = 149 // TMR2 Period register PR2
T2CON = %00000001 // T2CON 0:1 = Prescale
// 00 = Prescale is 1:1
// 01 = Prescale is 1:4
// 1x = Prescale is 1:16
// 3:6 = Postscale
// 0000 = 1:1 postscale
// 0001 = 1:2 postscale
// 0010 = 1:3 postscale...
// 1111 = 1:16 postscale
TMR2 = 0 // Reset TMR2 Value
TMR2IE = 1 // Enable TMR2 interrupts
TMR2ON = 1 // Enable TMR2 to increment
Enable(TMR2_Interrupt)
End Sub
// Start Of Program...
Low(Red_Pin)
Low(Green_Pin)
Low(Blue_Pin)
Red_Duty = 0
Green_Duty = 2
Blue_Duty = 0
Red_DutyVal = 0
Green_DutyVal = 4
Blue_DutyVal = 0
uS = 0
mS = 0
RandGen.Initialize(128) // Initialize the Random Number generator
TMR2_Initialize // Setup and enable TMR2
While True // Create an infinite loop
//RandomVal = RandGen.Rand // Grab a random number from 0 to 255
// Select RandomVal // Find out what colour to increase/decrease
//Case 0 To 42
While Red_Duty < 255
And Green_Duty < 255
And Blue_Duty < 255
mS(r) = 0
mS(b) = 0
mS(g) = 0
Repeat
Until mS(r) = 19
And mS(b) = 19
And mS(g) = 19
Inc(Red_Duty)
Inc(Green_Duty)
Inc(Blue_Duty)
Wend
// Case 43 To 84
While Red_Duty > 0
And Green_Duty > 0
And Blue_Duty > 0
mSr = 0
mSb = 0
mSg = 0
Repeat
Until mS(r) = 19
Until mS(b) = 19
Until mS(g) = 19
Dec(Red_Duty)
Dec(Green_Duty)
Dec(Blue_Duty)
Wend
// Case 84 To 127
//While Green_Duty < 255
// mS = 0
// Repeat
// Until mS = 19
// Inc(Green_Duty)
//Wend
// Case 128 To 170
// While Green_Duty > 0
// mS = 0
// Repeat
// Until mS = 19
// Dec(Green_Duty)
//Wend
// Case 170 To 212
// and Blue_Duty < 255
// mS = 0
// Repeat
// Until mS = 19
// Inc(Blue_Duty)
// Wend
// Case 212 To 255
// While Blue_Duty > 0
// mS = 0
// Repeat
// Until mS = 19
// Dec(Blue_Duty)
// Wend
// End Select
Wend
am sure there is a shorter way o do the IF THEN statements but at least I got all three LEDs going together (big deal) suggestions as I want to have each color flicker different from the others hint = a flickering candle effect other than turning the LEDs on and off | |
| | #10 |
the syntax gets hung up on INC ms() Code: Dim uS As Word,
mS(2) as byte
//dim mSb As Word
//dim mSg As Word
High(Signal_Pin)
uS = uS + 50
If uS >= 1000 Then
uS = uS - 1000
Inc mS() gets hung up here?
EndIf
Inc(Red_DutyVal)
| | #11 |
Clock = 8
Include "Utils.bas"
Red_Duty As Byte,
Green_Duty As Byte,
Blue_Duty As Byte,
RandomVal As Byte
Dim uS As Word,
mS(2) as byte
//dim mSb As Word
//dim mSg As Word
High(Signal_Pin)
uS = uS + 50
If uS >= 1000 Then
uS = uS - 1000
Inc mS()
EndIf
Inc(Red_DutyVal)
Inc(Green_DutyVal)
Inc(Blue_DutyVal)
Red_Pin = 0
Else
Red_Pin = 1
EndIf
Green_Pin = 0
Else
Green_Pin = 1
EndIf
Blue_Pin = 0
Else
Blue_Pin = 1
EndIf
EndIf //
Low(Signal_Pin)
End Interrupt
// 3:6 = Postscale
End Sub
Low(Red_Pin)
Low(Green_Pin)
Low(Blue_Pin)
Red_Duty = 0
Green_Duty = 2
Blue_Duty = 0
Red_DutyVal = 0
Green_DutyVal = 4
Blue_DutyVal = 0
uS = 0
mS(0) = 0
mS(1) = 0
mS(2) = 0
While (True) // Create an infinite loop
//Case 0 To 42
And Blue_Duty < 255
mS(0) = 0
mS(1) = 0
mS(2) = 0
Repeat
Until mS(0) = 19
And mS(1) = 19
And mS(2) = 19
Inc(Red_Duty)
Inc(Green_Duty)
Inc(Blue_Duty)
Wend
// Case 43 To 84
While Red_Duty > 0
And Green_Duty > 0
And Blue_Duty > 0
mS(0) = 0
mS(1) = 0
mS(2) = 0
Repeat
Until mS(0) = 19
and mS(1) = 19
and mS(2) = 19
Dec(Red_Duty)
Dec(Green_Duty)
Dec(Blue_Duty)
Wend
// Case 84 To 127
// mS = 0
// Repeat
// Until mS = 19
// Inc(Green_Duty)
//Wend
// Case 128 To 170
// mS = 0
// Repeat
// Until mS = 19
// Dec(Green_Duty)
//Wend
// Case 170 To 212
// mS = 0
// Repeat
// Until mS = 19
// Inc(Blue_Duty)
// Wend
// Case 212 To 255
// mS = 0
// Repeat
// Until mS = 19
// Dec(Blue_Duty)
// Wend
// End Select
Wend
| candle, effect, led, pwm |
| Led candle with 16f84a | gregted | Micro Controllers | 4 | 3rd March 2009 02:01 PM |
| And you though the candle and nail hoax was bad! | Andy1845c | Chit-Chat | 62 | 25th November 2007 10:41 PM |
| Candle circuit needed... | captainkirksdog | General Electronics Chat | 14 | 20th February 2005 04:17 AM |
| Candle Light | Dudeler | General Electronics Chat | 2 | 29th April 2004 07:13 PM |
| Way to Light A candle | yojo77 | General Electronics Chat | 10 | 23rd December 2003 03:30 AM |
