Old 5th June 2004, 07:48 PM   (permalink)
Default I2C Memory expanding
I'm building a datalogger for r/c use from the internet. The latest version uses a 24C1024 I2C eeprom. I can source 24C512 I2C eeproms. An earlier version of the software can handle these so I can build me a working logger. I was wondering if I could do something simple to use 2 24C512 as one 24C1024. For instance can I simply add both 24C512 to the I2C bus or am I facing adressing problems.
For your information the logger I'm building is http://home.arcor.de/d_meissner/d_logg2_engl.htm
EJK
KOEZE is offline   Reply With Quote
Old 6th June 2004, 06:50 AM   (permalink)
Default Re: I2C Memory expanding
Try checking the datasheet for the 24C512, if it has address lines you can connect more than one to the same bus, by setting them to different addresses. Failing that, you can give them different I/O lines, so use a common data line, but have seperate clock lines - but it means using three lines instead of two, and more rewriting of the code.
Old 7th June 2004, 07:59 AM   (permalink)
That is all way bove my head. I was hoping that the 24c1024 2 24c512 in a single unit was. I haven't been able to find anything about that chip other than in combination with Funcards. The fact that microchip nor atmel has the 24c1024 gave me the impression that the 1024 was something else than usual.
Since I only have access to the hex-listing changing the program is way out of my league.
Thank you for your reply.
EJK
Old 7th June 2004, 06:08 PM   (permalink)
What Nigel was saying is that with a number of I2C eproms on the market (I believe all Microchip eproms can do this) you can hook multiple chips to the same I2C bus. Externally by way of 3 pins, you can give each eprom a specifice address or "code word" if you prefer. All I2C devices have to have a unique "code word" in order to allow multiple devices to exist on the same two wires. What happens next is in the firmware of your PIC. When the PIC issues its first data transfer over the I2C bus, it first transmits the "code word". Every device on the bus receives the "code word" but only the one with the same code will respond to any further commands until you stop your data transfers by setting a "stop condition".
This bus arbitration is handled by the microcontroller. Speaking from experience, it is VERY convenient to use a microcontroller that has a hardware I2C controller built in. It will make your life a lot easier.
-Bill
phalanx is offline   Reply With Quote
« ya | PIC + L293D »
