+ Reply to Thread
Results 1 to 2 of 2
Thread: PIC PWM voltage regulator to build a variable V power
  1. #1
    togtoo Newbie
    Join Date
    Jun 2009
    Posts
    4
    Default PIC PWM voltage regulator to build a variable V power
    should I use pid logic inside PIC? Don't know how to use pid
    in voltage regulation.
    I found it is hard to get steady output V, in a such control system.
    Output V is always changing, changing!!!
    I tried to get constant current source also. Same thing, unsteady output!
    how to control voltage regulator properly by PIC?
  2. #2
    Mr RB Excellent Mr RB Excellent Mr RB Excellent Mr RB Excellent Mr RB Excellent Mr RB Excellent Mr RB Excellent
    Join Date
    Jul 2008
    Location
    Out there
    Posts
    1,761
    I would suggest taking the PIC outside the voltage regulation loop, and using the PIC just to generate a reference voltage. Smooth this reference voltage, then use discrete output voltage regulation that is based upon the reference voltage.
+ Reply to Thread
  1. creating a variable voltage power supply
    By rebirth in forum Electronic Projects Design/Ideas/Reviews
    Latest: 4th March 2009, 11:44 PM
  2. 12 volt variable voltage regulator
    By iflymyhelishigh in forum Electronic Projects Design/Ideas/Reviews
    Latest: 4th March 2009, 05:42 PM
  3. Need variable high voltage power supply
    By ksquared in forum Electronic Projects Design/Ideas/Reviews
    Latest: 8th January 2009, 10:25 PM
  4. How to build a variable voltage supply(with requirements)???
    By Alston_villa in forum Electronic Projects Design/Ideas/Reviews
    Latest: 10th May 2008, 09:18 AM
  5. variable voltage power supply
    By mahmoud shendy in forum General Electronics Chat
    Latest: 28th December 2007, 05:23 PM
Tags for this Thread
