+ Reply to Thread
Page 2 of 2
First 1 2
Results 16 to 21 of 21
Thread: Implementation of manchester coding
  1. #16
    Join Date
    Nov 2003
    Location
    Derbyshire, UK
    Posts
    29,791
    Looks OK on a quick glance, however the last of my RS232 tutorials uses the hardware UART and shows how to set it up.
  2. #17
    MessUpMymind Newbie
    Join Date
    Oct 2008
    Posts
    64
    hi nigel ,
    okay , i will try it out...btw can i send those data from RCREG into single pin in microcontroller for eg PORTC.1??? i know i can use RLF,RRF or shift register from parallel to serial but is there anyway else??
    Thanks for your reply =)..
  3. #18
    Join Date
    Nov 2003
    Location
    Derbyshire, UK
    Posts
    29,791
    Quote Originally Posted by MessUpMymind View Post
    hi nigel ,
    I'm not really sure what you mean?, if you want to send it out again as RS232 you could always use the hardware UART.
  4. #19
    MessUpMymind Newbie
    Join Date
    Oct 2008
    Posts
    64
    hi nigel ,
    sorry for those mess in previous , now i can send data to PIC from PC using UART... after i read 1 byte of data from RCREG and i wan to test it so i send those data that i read from RCREG to GPIO lets say PORTC and i will test it by using 8 LEDs on PORTC to see whether it receive the correct data. and it works out fine till this point
    what i need to do now is:
    now i wan to make my data sending to 1 of the GIPO PIN in SERIAL so that i can send it to my RF transmitter data pin in serial , make it short i need to put all 8 bits sending in 1 PIN serially instead of the whole PORT in parallel.
    as i know those method that can achieve this will be the following methods:
    1)using RLF/RRF and loop it 8 times to read every single bits
    2)using shift register to make those parallel data to Serial
    is there any other method that actually i can use to send out those data in serial from a pin to my RF transmitter data pin??
    Thanks for helping out =).
  5. #20
    Join Date
    Nov 2003
    Location
    Derbyshire, UK
    Posts
    29,791
    Like I said above, you could use the hardware UART transmitter, as you're not already using it.
    However, as you're sending it to a radio transmitter you should use my Manchester routines instead.
  6. #21
    MessUpMymind Newbie
    Join Date
    Oct 2008
    Posts
    64
    hi nigel ,
    thanks a lot!! i got it now , you are just great =)..
+ Reply to Thread
Page 2 of 2
First 1 2
  1. Manchester routines in C for PIC ?
    By pkshima in forum Micro Controllers
    Latest: 15th September 2009, 05:25 PM
  2. Manchester Decoder
    By dilipkumar09 in forum General Electronics Chat
    Latest: 31st July 2008, 08:58 AM
  3. Writting Manchester line coding
    By ahmedragia21 in forum Micro Controllers
    Latest: 11th March 2008, 08:24 PM
  4. MANCHESTER CODING in C language
    By Anniyan_x in forum Micro Controllers
    Latest: 19th April 2007, 02:55 AM
  5. manchester coding
    By darvaish in forum Micro Controllers
    Latest: 7th April 2005, 01:28 AM
Tags for this Thread
