+ Reply to Thread
Page 3 of 3
First 1 2 3
Results 31 to 37 of 37
Thread: Two 7-seg Up-down counter with two switches
  1. #31
    Mike, K8LH Excellent Mike, K8LH Excellent Mike, K8LH Excellent Mike, K8LH Excellent Mike, K8LH Excellent Mike, K8LH Excellent Mike, K8LH Excellent
    Join Date
    Jan 2005
    Location
    Michigan, USA
    Posts
    2,512
    If anyone is interested, here's another version of that example program using a single "packed bcd" variable instead of a single "binary" variable (eliminating the need for a bin2bcd routine). This version rolls over from 99 to 00 when incrementing or from 00 to 99 when decrementing but you can implement "hard" limits of 00 and 99 when decrementing or incrementing, respectively, by simply changing two instructions.
    The program is reasonably tight and clean and weighs in at a respectable 75 words and 4 variables without any real effort to try and optimize it.
    I'll try to post an ISR version with "auto repeat" and "switch press beep" in a couple days.
    Regards, Mike, K8LH
    ;  (C) K8LH 2-Digit Up/Dn Counter, Isochronous Loop Example v2    *
            processor PIC16F88
            include "p16f88.inc"
            errorlevel -302
            __CONFIG  _CONFIG1, _LVP_OFF&_WDT_OFF&_INTRC_IO&_MCLR_OFF
            __CONFIG  _CONFIG2, _IESO_OFF & _FCMEN_OFF
    number  equ     0x20            ; packed BCD, 0x00..0x99
    swlatch equ     0x21            ; switch state latch variable
    swflags equ     0x22            ; switch flag bits
    DelayHi equ     0x23            ; DelayCy() subsystem variable
    #define Dn      3               ; RA3
    #define Up      2               ; RA2
    ;  K8LH DelayCy() subsystem macro generates four instructions
            radix   dec
    clock   equ     8               ; clock frequency in Megahertz
    usecs   equ     clock/4         ; cycles/microsecond multiplier
    msecs   equ     usecs*1000      ; cycles/millisecond multiplier
    DelayCy macro   delay           ; 11..327690 cycle range
            movlw   high((delay-11)/5)+1
            movwf   DelayHi
            movlw   low ((delay-11)/5)
            call    uDelay-((delay-11)%5)
            endm
    ;  init hardware and program variables
            org     0x000
    Init
            bsf     STATUS,RP0      ; bank 1                          |B1
            movlw   b'01110000'     ;                                 |B1
            movwf   OSCCON          ; select 8-MHz INTOSC clock       |B1
    Stable  btfss   OSCCON,IOFS     ; INTOSC Freq Stable bit set?     |B1
            goto    Stable          ; no, branch, else                |B1
            clrf    ANSEL           ; setup PORT A for digital I/O    |B1
            movlw   b'00001100'     ;                                 |B1
            movwf   TRISA           ; RA3-RA2 inputs, others outputs  |B1
            clrf    TRISB           ; portb all outputs               |B1
            bcf     STATUS,RP0      ; bank 0                          |B0
            clrf    PORTB           ; clear portb output latches      |B0
            movlw   b'00000001'     ; digit select bits (RA1-RA0)     |B0
            movwf   PORTA           ; select the 'ones' display       |B0
            clrf    swlatch         ; clear switch state latch        |B0
            clrf    swflags         ; clear switch flags              |B0
            clrf    number          ; number = 00                     |B0
    ;  isochronous 8 msec program loop (62.5 Hz display refresh rate)
    Display
            clrf    PORTB           ; blank the display               |B0
            movf    PORTA,W         ;                                 |B0
            xorlw   b'00000011'     ; flip digit select bits          |B0
            movwf   PORTA           ;                                 |B0
            swapf   number,W        ; W = tens in right nybble        |B0
            btfss   PORTA,1         ; 10's display? yes, skip, else   |B0
            movf    number,W        ; W = ones in right nybble        |B0
            call    segtbl          ; get segment data                |B0
            movwf   PORTB           ; display new digit               |B0
    Buttons
            comf    PORTA,W         ; sample active low switches      |B0
            andlw   b'00001100'     ; on RA3 and RA2 pins             |B0
            xorwf   swlatch,W       ; changes (press or release)      |B0
            xorwf   swlatch,F       ; update switch state latch       |B0
            andwf   swlatch,W       ; filter out "new release" bits   |B0
            movwf   swflags         ; save any "new press" bits       |B0
    CountUp
            movf    number,W        ;                                 |B0
            addlw   7               ; increment + bcd adjust?         |B0
            skpdc                   ; yes, skip, else                 |B0
            addlw   -6              ; increment only                  |B0
            btfsc   swflags,Up      ; Up press? no, skip, else        |B0
            movwf   number          ; update 'number'                 |B0
            movf    number,W        ;                                 |B0
            xorlw   0xA0            ; upper limit 99?                 |B0
            skpnz                   ; no, skip, else                  |B0
            clrf    number          ; reset to 00 (rollover mode)     |B0 <-
    CountDn
            movf    number,W        ; lower limit 00?                 |B0
            movlw   0xA0            ; reset to 99 (rollover mode)     |B0 <-
            addlw   -1              ; decrement only?                 |B0
            addlw   -6              ; decrement + bcd adjust          |B0
            btfsc   swflags,Dn      ; Dn press? no, skip, else        |B0
            DelayCy(8*msecs-41)     ; precise 8 msec loop timing      |B0
            goto    Display         ; loop                            |B0
    ;  segment data table (caveat, non-boundary tolerant)
    segtbl
            andlw   0x0F            ; strip off upper nybble          |B0
            addwf   PCL,F           ;                                 |B0
            retlw   b'00111111'     ; "0"   -|-|F|E|D|C|B|A           |B0
            retlw   b'00000110'     ; "1"   -|-|-|-|-|C|B|-           |B0
            retlw   b'01011011'     ; "2"   -|G|-|E|D|-|B|A           |B0
            retlw   b'01001111'     ; "3"   -|G|-|-|D|C|B|A           |B0
            retlw   b'01100110'     ; "4"   -|G|F|-|-|C|B|-           |B0
            retlw   b'01101101'     ; "5"   -|G|F|-|D|C|-|A           |B0
            retlw   b'01111101'     ; "6"   -|G|F|E|D|C|-|A           |B0
            retlw   b'00000111'     ; "7"   -|-|-|-|-|C|B|A           |B0
            retlw   b'01111111'     ; "8"   -|G|F|E|D|C|B|A           |B0
            retlw   b'01101111'     ; "9"   -|G|F|-|D|C|B|A           |B0
    ;  K8LH DelayCy() subsystem 16-bit timing subroutine
            nop                     ; entry for (delay-11)%5 == 4     |B0
            nop                     ; entry for (delay-11)%5 == 3     |B0
            nop                     ; entry for (delay-11)%5 == 2     |B0
            nop                     ; entry for (delay-11)%5 == 1     |B0
    uDelay  addlw   -1              ; subtract "loop" cycle time      |B0
            skpc                    ; borrow? no, skip, else          |B0
            decfsz  DelayHi,F       ; done?  yes, skip, else          |B0
            goto    uDelay          ; do another loop                 |B0
            return                  ;                                 |B0
            end
  2. #32
    Banned nike6 Bad
    Join Date
    May 2009
    Location
    Ireland
    Posts
    123
    well I see quite a bit of a creep here, the timing macro, which is sort of complicated.
    I would like to post my demo code for 2-digit LED display, which includes up/dn counter as program 1, and some random display as program 2, but it goes over 4 or 5 pages.
    I always query the TIMER as the subject of the main program loop, so that is synchronized to the clock frequency.
    there are no delays!
    the proper ratio are derived from additional pseudo-timer-dividers, simple file register counters, together with compare/overflow logic.
    All i have to change is the prescaler, if neccessary!
    I could post my code if asked for, or put it on a web page in a matter of minutes. I think this one is even documentated.
  3. #33
    prabhuvip1977 Newbie
    Join Date
    Aug 2008
    Posts
    4
    Default help please
    Hello there,
    Can you please send the code for the same circuit(2 digit up down using PIC16F628Aor what ever) for displaying "00" when connected to a potentiometer(10k or what ever) at its least position and "99" at its maximum position.
    Thanks and Regards,
    Prabhu.R
    golden_litho@yahoo.co.in
  4. #34
    colin55 Newbie
    Join Date
    Feb 2009
    Location
    Melbourne Australia
    Posts
    1,493
    Go to Talking Electronics website and look for the PIC Lab-1 project. It has an A to D code for a pot to 7-segment display. Just connect the pot to an input line and add a capacitor and use the same code.
  5. #35
    Join Date
    Aug 2008
    Posts
    4
    Default Two 7 segment display
    Dear collin55, thankyou for your help.kindly help me to get output in two digit format(decimal not required).The site has data for only one segment.
    Thanks and regards,
    prabhu
  6. #36
    colin55 Newbie
    Join Date
    Feb 2009
    Location
    Melbourne Australia
    Posts
    1,493
    Combine the code for the A to D of the PIC Lab-1 project with the code for the 2 digit up/down counter using a PIC16F628.
  7. #37
    julusa07 Newbie
    Join Date
    Mar 2010
    Posts
    1
    hello nike6
    please contact me, I'm interested in your circuit
    I am very interested
    email: tecref@yahoo.es
    thanks
    Quote Originally Posted by nike6 View Post
    I have a 16f54 PCB which includes 2 buttons, a 2-way DIL switch,
    it's on ebay right now (link is on my website)
    not a very good design, indeed one of my first PCBs,
    but it works, good brightness, and source code for
    hex up/down counter, and random numbers is included.
    I could even give the source code seperately if interested (just it is explicitely customized to specific PORT bits).
    I use plain 2n3904, and no resistors, one 74hc595 buffer.
    yes the 16f54 does not have A/D, and also otherwise is limited, only 512 words.
    PS. i do not really intend to sell large numbers of this design, it was just an experimental prototype. Indeed, i have made a new design recently.
    still have a few unpopulated PCBs around.
    money i made out of each PCB was $2 or $3.
+ Reply to Thread
Page 3 of 3
First 1 2 3
  1. Very particular and old switches
    By poutpout in forum General Electronics Chat
    Latest: 19th November 2008, 12:51 PM
  2. Innovation for Cash Counter>>Letter Size Page Counter-Is This Possible
    By mycam524 in forum Electronic Projects Design/Ideas/Reviews
    Latest: 26th November 2007, 09:29 AM
  3. Switches.
    By Baske7Cas3 in forum General Electronics Chat
    Latest: 23rd July 2007, 07:13 AM
  4. switches
    By vieri in forum Micro Controllers
    Latest: 2nd October 2003, 04:35 PM
  5. Where Can I Buy These Switches?
    By less_than_jake_2002 in forum Datasheet/Parts Requests
    Latest: 17th July 2003, 05:59 AM
Tags for this Thread
