Old 2nd June 2009, 05:11 PM   #1
Exclamation help pic 16f84a
i want to make a circuit to make a led turn on when i push the push button
by using these code
void main()
TRISA=0B00011111;
TRISB=0;
loop:
if (PORTA.F0==0) { PORTB.F0=1; }
else {PORTB.F0=0; }
goto loop;
killer_007 is offline
Old 2nd June 2009, 07:20 PM   #2
That should be like this
  void main()
    TRISA=0B00011111;
     TRISB=0;
 loop:
     if (PORTA.0==0) { PORTB.0=1; }
     else {PORTB.0=0; }
     goto loop;
be80be is offline
Old 2nd June 2009, 07:47 PM   #3
Welcome to the forums. You will need a little bit more code than that in order to make a successful program. What language are you using?
It would be worth looking at Nigel's site WinPicProg Page. He has some very good tutorials that explain how to wire up the hardware. He also uses a more up-to-date PIC that is still produced.
edeca is offline
Old 2nd June 2009, 10:09 PM   #4
i want the circuit not the code plz
because i want to make it and the code is not a problem
Old 2nd June 2009, 10:23 PM   #5
Any of the following will help you:
Nigel's PIC Tutorial Switch Board
PIC Tutorial
PIC Tutorial
Have a read and come back with some specific questions. Do you have any parts and a breadboard to practise with?
Private messages are for personal communication, please do not use them to ask for help.
edeca is offline
Old 2nd June 2009, 11:12 PM   #6
does there is more simple circuits
Old 2nd June 2009, 11:23 PM   #7
What's the problem with the circuit? Hook the switch up to the input line, and the led to the output line...
straight answer, har har."
Sceadwian is offline
Old 2nd June 2009, 11:41 PM   #8
Killer you don't check to see if PORTA.F0 there isn't a port like that on a pic
Here this should get you started
be80be is offline
Old 2nd June 2009, 11:52 PM   #9
be8, I did a quick google search there is PIC code out there that refers to the ports exactly as he did.. Might be the compiler.
Old 3rd June 2009, 12:31 AM   #10
thanxxxxxxxxxxxxxxxxxxxxxxx
every one
Old 3rd June 2009, 02:21 AM   #11
There some things I haven't tried. mikroC thats it.
be80be is offline
16f84a, pic
H e l p me please :S Relay 16f84a tred13 Electronic Projects Design/Ideas/Reviews 3 22nd November 2008 10:27 AM
C++ in PIC 16f84a sheng_james Micro Controllers 6 12th January 2008 07:53 AM
PIC 16f84A problem prasanna_km Electronic Projects Design/Ideas/Reviews 4 26th May 2005 06:01 PM
16F84A urgent iceman83 Micro Controllers 4 8th April 2005 10:23 AM
HELP with 16f84a i2c PIC Dummy Micro Controllers 0 20th February 2004 05:59 PM
