Old 30th May 2009, 01:43 AM   #1
Default Sony Infared Code in C18
Here ya go:
;	Filename: SIRC															*
;	Date: May 29, 2009														*
;	File Version: 001														*
;	Author:   Jason Lopez													*
;	Company:  AtomSoft														*
; Notes:
; I am delaying in this code a nice even number every 200uS. Mainly because if
; i count each pulse it would be accurate but too many counts for a char type
; and i dont want to use a int. So i can get a 600 count by skipping every 300uS
; and the count will be a nice low number...3
; For a 1.2mS aka HIGH i should get a count of 6 and for the start 2.4mS i should
; get a count of 12. Since this isnt too accurate i range it about 1-2 numbers
; above or below the standard.
#include <p18f2525.h>
#include <delays.h>
#include <string.h>
#pragma config WDT = OFF, LVP = OFF, OSC = INTIO67, XINST = OFF
unsigned char lTime;
unsigned char MyAdd;
unsigned char MyCmd;
#define irTris TRISCbits.TRISC4
#define irPin PORTCbits.RC4
void main(void);
void GetSIRC(unsigned char *address, unsigned char *command);
void main(void){
    char tmp;
    OSCCON = 0x72;                  //8MHz clock
    while(!OSCCONbits.IOFS);        //wait for osc stable
    TRISC = 0;
    irTris = 1;
    while(1){
        GetSIRC(&MyAdd,&MyCmd);
void GetSIRC(unsigned char *address, unsigned char *command){
    unsigned char ir_add;
    unsigned char ir_cmd;
    char x;
StartLook:
    ir_add = ir_cmd = 0;
    while(irPin);               //wait for it to be low
    lTime = 0;                  //reset the counter
    while(irPin == 0){          //while the pin is low which is our pulse count
        lTime++;                //increment every 200uS until pin is high
        Delay100TCYx(4);        //200uS delay
    if(lTime <= 10)             //Start too short
        goto StartLook;         //Restart
    if(lTime >= 14)             //Start too long
    lTime = 0;
    for(x=0;x<7;x++){           //repeat 7 times for command
        ir_cmd >>= 1;           //if it was skipped or is done ORing then shift over the 1
        if(lTime >= 6)          //If its high then OR a 1 in else skip
            ir_cmd |= 0x40;     //if its less than 6 its a 0 so dont OR it
    for(x=0;x<5;x++){           //repeat 5 times for address/device
        ir_add >>= 1;           //if it was skipped or is done ORing then shift over the 1
            ir_add |= 0x10;     //if its less than 6 its a 0 so dont OR it
    *address = ir_add;
    *command = ir_cmd;
I even made a little RBG led test using digits 1-7. Ill make a small vid and show in a bit.
AtomSoft is online now
Old 30th May 2009, 01:54 AM   #2
Hi Jason,
You have been busy lately. I wrote the same code a while back but mine is slightly different. I notice that you are oring the received bit into bit 7 and so your data is left justified. By oring into the lower bits you get the values published by Sony.
Here's mine for comparison,
#define IR_in   PORTAbits.RA6
#define IR_tris TRISAbits.TRISA6
unsigned char GetPulse(void){
unsigned char count;
    count=0;
    IR_tris=1;
    while(IR_in==1);
    while(IR_in==0){
        count++;
        Delay100TCYx(1);   //50uS assumes 8MHz
    return count;
void GetIR(char *cmd,char *dev){
char i;
    *cmd=0;
    *dev=0;
    while(GetPulse()<40);    //wait for start pulse
    for(i=0;i<7;i++){
        *cmd=*cmd>>1;
        if(GetPulse()>18)
            *cmd|=0x40;
    for(i=0;i<5;i++){
        *dev=*dev>>1;
        if(GetPulse()>18)
            *dev|=0x10;
Pommie is online now
Old 30th May 2009, 02:37 AM   #3
Darn i knew i miscounted bits since its 7 bits you or 0x40 for the 7th and since its 5 bits for address you or with 0x10
Thanks i fixed my code now your a great fixer dude!
Old 30th May 2009, 02:39 AM   #4
Mike the thing is i do you tabs. The code is formatted well in MPLAB i dont use spaces i use tabs. But when i post here its hideous.
Old 30th May 2009, 02:43 AM   #5
Code in first post is now updated. May also look cleaner.
Old 30th May 2009, 03:14 AM   #6
Jason,
If you set MPLAB to convert tabs to spaces then it comes out fine.
Old 30th May 2009, 03:20 AM   #7
OOPS i knew i forgot to do something when i redid my PC lol thanks i forgot about that option completely lol. heh look at this:
I had to attach the code. I set the tab to space thing and closed and reopened but still ugly looking lol.
Old 30th May 2009, 03:29 AM   #8
Looks good. It's always pleasing when something like this finally works.
Old 30th May 2009, 03:35 AM   #9
i fixed the coding issue! I had to manually replace all the spacing with new tabs lol
;	Filename: SIRC															*
; Notes:
#include <delays.h>
#include <string.h>
#define Led_Red LATCbits.LATC1
#define Led_Blue LATCbits.LATC2
#define Led_Green LATCbits.LATC3
void main(void);
void main(void){
char tmp;
TRISC = 0;
irTris = 1;
while(1){
switch(MyCmd){
    case 0:
        Led_Red = 0;
        Led_Blue = 1;
        Led_Green = 1;
        break;
    case 1:
        Led_Red = 1;
        Led_Blue = 0;
        Led_Green = 1;
        break;
    case 2:
        Led_Red = 1;
        Led_Blue = 1;
        Led_Green = 0;
        break;
    case 3:
        Led_Red = 0;
        Led_Blue = 0;
        Led_Green = 1;
        break;
    case 4:
        Led_Red = 1;
        Led_Blue = 0;
        Led_Green = 0;
        break;
    case 5:
        Led_Red = 0;
        Led_Blue = 0;
        Led_Green = 0;
        break;
    case 6:
        Led_Red = 1;
        Led_Blue = 1;
        Led_Green = 1;
        break;
    char x;
StartLook:
    lTime = 0;
    *address = ir_add;
    *command = ir_cmd;
Thanks Pommie (MIKE) and MIKE lol. I fixed the first post code with the nice looking code so everyone can understand it better lol
Old 30th May 2009, 04:28 AM   #10
Atom that's great work i'm just starting some c18. looked at some lcd code you did it was very good to. Maybe i can to lol.
be80be is online now
Old 30th May 2009, 11:51 AM   #11
Nice work. Looks much nicer with tabs 4 instead of tabs 8.
Mike, K8LH is offline
Old 30th May 2009, 12:20 PM   #12
heh thanks guys. i hope people find this useful.
Old 30th May 2009, 09:13 PM   #13
I just made a nice remote using SONY (SIRC) Protocol.
;	Filename: SIRC															*
; Notes:
#include <p18f1320.h>
#include <delays.h>
#include <string.h>
#pragma config WDT = OFF, LVP = OFF, OSC = INTIO2, MCLRE = OFF
#define irTris TRISAbits.TRISA0
#define irPin  LATAbits.LATA0
#define UpTris  TRISBbits.TRISB5
#define DwnTris TRISBbits.TRISB4
#define Up_Btn  PORTBbits.RB5
#define Dwn_Btn PORTBbits.RB4
void main(void);
void SendSIRC(unsigned char Dev, unsigned char Cmd);
void PulseIt(unsigned char time);
void main(void){
    char tmp;
    ADCON1 = 0xFF;
    UpTris = 1;
    DwnTris = 1;
    irTris = 0;
    SendSIRC(1,1);
    while(1){
        if(Up_Btn == 0){
            SendSIRC(1,0);
            Delay10KTCYx(1);
        if(Dwn_Btn == 0){
            SendSIRC(1,1);
            Delay10KTCYx(1);
void SendSIRC(unsigned char Dev, unsigned char Cmd){
    char x;
    PulseIt(4);             //Logic Start
    for(x=0;x<7;x++){
        if(Cmd & 0x01)
            PulseIt(2);     //Logic 1
        else
            PulseIt(1);     //Logic 0
        Cmd <<= 1;
    for(x=0;x<5;x++){
        if(Dev & 0x01)
        else
        Cmd <<= 1;
    Delay10KTCYx(90);       //45mS Delay
void PulseIt(unsigned char time){
    unsigned char x,y,z;
for(y=0;y<time;y++){
    for(x=0;x<24;x++){          //600uS worth
        irPin = 1;
        Delay10TCY();
        Nop();
        Nop();
        Nop();                  //About 7uS
        irPin = 0;
        Nop();
        Nop();
        Nop();
        Nop();
        Nop();
        Nop();
        Nop();
        Nop();
        Delay10TCY();
        Delay10TCY();           //About 18uS
        irPin = 0;
        Delay10TCY();
        Nop();
        Nop();
        Nop();                  //About 7uS
        irPin = 0;
        Nop();
        Nop();
        Nop();
        Nop();
        Nop();
        Nop();
        Nop();
        Nop();
        Delay10TCY();
Old 30th May 2009, 09:27 PM   #14
Everytime I check the new posts on this forum, you've created something new. Good work.
colin mac is offline
Old 30th May 2009, 09:35 PM   #15
We keep trying to tell him "quality not quantity" but he won't listen (lol)...
c18, code, infared, sony
NEED help in connecting infared sensor to MCU(18f4520) meijunfun Micro Controllers 4 17th April 2009 12:15 AM
infared circuit lovelyman72 General Electronics Chat 1 16th May 2005 11:33 AM
Laser or Infared Lap Counter WoomaHodal Electronic Projects Design/Ideas/Reviews 1 29th April 2005 07:14 PM
infared remote blackbag General Electronics Chat 0 22nd July 2003 12:27 AM
