Old 28th May 2009, 09:00 PM   #1
Default Help to identify a chip
I request your help in order to identify a microcontroller chip which is in a board I have to repair. I have been browsing a lot of datasheets from Microchip and Phillips and none fits:
Total number of pins: 14
Power VDD: pin 4
GND Vss: pin 11
pins 1,2,3, and 13 and 14: data input
pins 6, 9 and 10: data output
Pins 7, 8 and 12 are not connected on my board.
Most of datasheets I have seen from Microchip have Vdd on pin 1 and Gnd on pin 14 which is not the case on my circuit.
Any ideas will be welcomed.
nicky314 is offline
Old 28th May 2009, 09:14 PM   #2
There are no numbers printed on the chip package?
kpatz is offline
Old 28th May 2009, 10:24 PM   #3
No numbers or reference at all. It has been erased.
nicky314 is offline
Old 28th May 2009, 10:38 PM   #4
If it is a microcontroller and the part numbers sanded off you can bet the IC is copy protected.
Bill
Smart Kits build Smart People
Old 28th May 2009, 10:44 PM   #5
What circuit? What does it do (did)?
ronsimpson is offline
Old 28th May 2009, 10:45 PM   #6
It doesnīt matter if I canīt copy the contents.
What I am thinking is to prepare a new program myself.
I would prefer not to use a different microcontroller from the one on the circuit.
Regards.
nicky314 is offline
Old 28th May 2009, 10:47 PM   #7
The circuit is a remote control. Only has a multitone dtmf decoder, the IC I think is the microcontroler and one output relay.
nicky314 is offline
Old 28th May 2009, 10:52 PM   #8
Pick a microcontroller you're familiar with and make a carrier PCB.
It might be a simple DTMf IC.
Bill
Old 29th May 2009, 09:11 AM   #9
Assuming it's a micro-controller, it would certainly be copy protected, so there seems little point in erasing the number off of it. It's more likely to be a standard chip, which is why erasing it's number makes more sense.
If it's DTMF remote control, presumably it's really old?, as the crude DTMF system was only ever used for a short period, probably 25-30 years ago?.
Old 29th May 2009, 05:18 PM   #10
Question
Nigel Goodwin wrote:" Assuming it's a micro-controller, it would certainly be copy protected, so there seems little point in erasing the number off of it. It's more likely to be a standard chip, which is why erasing it's number makes more sense."
Yes, your point is very interesting. But I donīt see how to do with a single chip - not being a microcontroller- the following:
A sequencial 4-digit ( 4 tones) password is received at the dtmf decoder which passes to the microcontroller different codes for each tone. if the password is correct then wait for a tone and depending on which tone, command a relay. If tone is #1 then set on relay #1, if tone is #2 then set on relay 2. Also if tone is #3 then set off relay #1 and so on...
Can this be achieved with a single chip (leaving dtmf tone decoding apart ) ?
nicky314 is offline
Old 29th May 2009, 05:23 PM   #11
Sure it could even be a custom chip. What's it out of?
Bill
Old 29th May 2009, 05:26 PM   #12
It could well be a microcontroller, but there seems no reason to destroy it's markings if it is one.
So you have a DTMF decoder chip, and this outputs the value of the button pressed, presumably as a digital value on a four bit bus? - and passes that value to the next chip.
An extra concern for it not been a microcontoller is the absense of any clock components.
Old 29th May 2009, 06:12 PM   #13
Nigel, security through obfuscation, very effective. I do agree though that the chances of it being a micro controller aren't very high. With no markings there's nothing left to go on.
straight answer, har har."
Sceadwian is offline
Old 30th May 2009, 05:06 AM   #14
I never seen a micro controller sanded off. Number over but not sanded.
If you have to repair and don't no what chip it is how do you no
whats it in
be80be is offline
Old 1st June 2009, 09:47 AM   #15
Exactly like you say.
There is a xtal connected to dtmf decoder.
So, going back to my first post, anyone knows the reference of a 14 pin microcontroller with Vdd on pin 4 and gnd on pin 11 ?
nicky314 is offline
chip, identify
How to identify pin 1 on SOT-23 Pommie Micro Controllers 23 1st September 2008 08:57 PM
can any one help me to identify this kep General Electronics Chat 1 29th January 2008 05:08 AM
help identify baudmiksen Chit-Chat 3 20th July 2007 02:06 PM
identify this imgemini General Electronics Chat 6 17th August 2004 01:07 PM
Help Identify This? rstark18 General Electronics Chat 10 8th August 2003 04:23 PM
