Old 28th May 2009, 05:35 PM   #1
Default Popular Micro and why.
Hey my friends i know this is kinda not a technical issue or anything but a informational request.
If possible i would like the users here to post the PIC/AVR/ARM they use the most and why. Meaning post what you like about the pic the most. Also if they have any links to projects with them.
Please don't post all the Micros you own just the ones you use the most. I am trying to gather information is all.
Thank for your time.
EDIT:
Extending this post to other ICs as well.
EXAMPLE:
USB To USART Interface FT232RL.
AtomSoft is offline
Old 28th May 2009, 05:40 PM   #2
Availability of through-hole parts (though that may not be such a big deal anymore but it certainly used to be), availibility from vendors, and free compilers. THe datasheets of a PIC are also among the easiest to understand in my opinion.
dknguyen is offline
Old 28th May 2009, 05:52 PM   #3
Thanks but im asking more for what item in specific.
Something like... ill post my fav pic.
I like the 18F4620 mainly because its a large pic with 40 pins. Has all the needed hardware like USART, SPI/i2c and more. Also has a large amount of memory on board.
You can post anything like that. I dont care if its about PICs,AVRs or ARMs MCUs. Its a question of popularity. Like i plan to make some tools and projects later on and would like to know whats most likely to sell. I want to know what the users are interested in.
If i teach something it wont be what i want to teach its more of what others want to learn. I want to know whats popular and why (custom opinions).
AtomSoft is offline
Old 28th May 2009, 06:01 PM   #4
18F4550. It is very similar to the 18F4620 but has USB capability.
speakerguy79 is offline
Old 28th May 2009, 06:19 PM   #5
Thanks speakerguy79.
ADDED TO FIRST POST:
EXAMPLE:
AtomSoft is offline
Old 28th May 2009, 06:26 PM   #6
Personally I like the Pic24s or pic33s for most of my projects. I use the 28-pin dip version for breadboarding, and try to select the model with the most memory and features that's in stock.
Almost all my projects are power based of some sort (smps, motor controls, intverters, chargers, etc) and these particular pics have some additional features that make it very easy. Plus I like having a 16-bit core.
smanches is offline
Old 28th May 2009, 06:56 PM   #7
I like PICxxHVxx because I can run then at 12 volts.
I like the 6 pin PICs because I do very small projects.
Many PICs will work form 5.5 volts to 2.0 volts. (battery project)
I like Tiny AVR because 1.8 volts and two fast hardware PWM.
For BIG projects I like ARM.
ronsimpson is online now
Old 28th May 2009, 07:14 PM   #8
The only micro I use on your list is the ARM7 and specifically the AT91SAM7, but I'd like to move to the LPC's. There's more hardware options.
The only practical project I have with these is my more advanced Ethernet controller/server. (I say 'more advanced' because I have an 8bit ethernet controller/server as well)
http://www.higginstribe.com/sam7/w53...0-sam7-001.jpg
http://www.higginstribe.com/sam7/w53...0-sam7-002.jpg
Mark Higgins
DirtyLude is offline
Old 28th May 2009, 07:48 PM   #9
Thanks guys:
smanches and ronsimpson can you specify a Micro specifically that you've recently used please.
Mark :
That is beautiful. i like the way it plugs into the breadboard. Did you make that yourself? Like sent out for the board i assume... but did you hand solder / oven solder it yourself? I ask because it came out so professional.
AtomSoft is offline
Old 28th May 2009, 09:10 PM   #10
PIC10F202, 12F580, 16F690, 16F873 and the 18F??? that is pin compatable with the16F873. I like micros with internal OSC. & internal RESET.
I use the little 6 pin micros that are the same size as a transistor.
Old 28th May 2009, 09:34 PM   #11
I like the ATtiny13, since most of my projects are small, and seldom use more than one or two of the hardware features at a time. Works fine off a single AA rechargeable battery, although the datasheet says 1.8 volts. Bought 25, at 78 cents each last time, so don't worry about my abusive nature while experimenting. Use the Attiny2313 for LCD stuff...
HarveyH42 is offline
Old 28th May 2009, 09:43 PM   #12
24HJ128GP202's and 33FJ128MC202's
smanches is offline
Old 28th May 2009, 09:48 PM   #13
Harvey,
ATtiny13 what compiler? what tools? Nice to know about the 1.5 volts.
Old 28th May 2009, 10:02 PM   #14
Originally Posted by AtomSoft View Post
Mark :
Thanks. I soldered everything with an iron except for the tiny QFN16 RTC chip on the top of the board. I applied a bit of paste as centered as I could on the contacts and hit it with some hot air from my rework station.
Mark Higgins
Old 29th May 2009, 12:15 AM   #15
Awesome Guys. Thanks.
I extended it to other ICs also. Like max232.
Mark that is great work! I wish i had that skill
AtomSoft is offline
micro, popular
most popular electronics forum? mailint General Electronics Chat 4 17th September 2008 10:22 PM
Most popular Micro-controllers? jack23 Micro Controllers 15 16th June 2007 05:00 PM
looking for popular RTC for use with Z8 encore! covinataz Electronic Projects Design/Ideas/Reviews 2 22nd May 2005 07:13 PM
popular electronics mstechca General Electronics Chat 5 26th April 2005 02:11 AM
What is most popular micro-controller in industry today? cubdh23 Micro Controllers 12 11th July 2004 04:53 PM
