Old 29th May 2009, 12:36 AM   #16
I've done wonders with TQFP PIC16F887's (capable and cheap) and ULN2803A (also cheap)
jimmythefool is offline
Old 29th May 2009, 01:28 AM   #17
Originally Posted by ronsimpson View Post
Harvey,
ATtiny13 what compiler? what tools? Nice to know about the 1.5 volts.
Mostly AVR Studio, but learning BASCOM Basic.
They also work from a Joule Thief, if you add a diode and capacitor...
HarveyH42 is offline
Old 29th May 2009, 01:58 AM   #18
Great Info the more the better. It would nice if someone can move this to chit chat. Since its not really a technical thing.
Thanks.
AtomSoft is offline
Old 29th May 2009, 05:44 AM   #19
If you are thinking commercial I would suggest that you consider supporting the lower end PICs, like 16F628A, 12F675, 16F887 etc. Hobbyists have these in stock, also the hobby oriented parts suppliers stock these (+ heaps of them on Ebay etc) so they are seen as "standards" in a way. If you use the newer/bigger PICs exclusively you will alienate many potential customers who would like to use the chips they know/have/can get/can program.
Mr RB is online now
Old 29th May 2009, 12:16 PM   #20
I like the tiny11's myself, unfortunately they've been discontinued, they didn't have a lot of features but they were only 50 cents. I miss them terribly, I still have a few from my last Digikey purchase, they make great LED blinkers. The Tiny25/45/85 (different memory sizes) are my next favorite, massive features in an 8pin package. The tiny15's are nice for switch mode or motor drive applications because it has a PLL module which allows a PWM out of up to 100khz at 8 bit. For a few extra pins the tiny26/46/86's are nice, for real projects the Mega series has everything including the kitchen sink built in.
I prefer AVRs over PICs, for many reasons, mainly it's because AVR's are newer than PIC's the feature set is much more standardized across the entire line of products so it's much easier to 'change gears' than it is with a PIC. Even the tiny11 has the same core features as the Mega series. The same can not be said for PIC's where moving from say the 12 series to the 18 series is basically re-learning the whole chip from scratch.
straight answer, har har."
Sceadwian is online now
Old 29th May 2009, 12:33 PM   #21
Sweet! thanks guys. i see these seem to be a fav.
ATTINY45
ATTINY46
PIC16F628A
PIC16F887
someone referred to a AT91SAM7.. Those are so expensive i can see why a jump to a LPC would be nice. Its about the same price and has more features.
check out the sale:
NXP ARM7 32-bit Microcontroller LPC2364FBD100 $6.23
NXP ARM7 32-bit Microcontroller LPC2364FBD100 - dipmicro electronics
AtomSoft is offline
Old 29th May 2009, 01:03 PM   #22
The tiny25/45/85 26/46/86 are all effectively the same part. The odd part numbers are 8pin the evens are 20pins The 2/4/8 is available programming memory, also from low to high it's 128/256/512 bytes of eeprom and SRAM each.
Old 29th May 2009, 01:07 PM   #23
heh thanks. Even tho they are basically the same, Physical size changes alot since there are more pins to work with. Different Project ranges.
AtomSoft is offline
Old 30th May 2009, 05:21 AM   #24
I like them all. But I have to say the 18f1220 which is just less ram then it brother the 18f1320 I like the best It easy 18fxxx chip to start with and I don't need a lot of pins to control two motors and some Ir sensors. But the neatest thing I did with it was a combination lock with 3/4 keypad and a light dimmer.
be80be is offline
micro, popular
most popular electronics forum? mailint General Electronics Chat 4 17th September 2008 10:22 PM
Most popular Micro-controllers? jack23 Micro Controllers 15 16th June 2007 05:00 PM
looking for popular RTC for use with Z8 encore! covinataz Electronic Projects Design/Ideas/Reviews 2 22nd May 2005 07:13 PM
popular electronics mstechca General Electronics Chat 5 26th April 2005 02:11 AM
What is most popular micro-controller in industry today? cubdh23 Micro Controllers 12 11th July 2004 04:53 PM
