hi, in the data sheet of the pic24f , it is written that every pin can behave as a normal digital output or a open drain output. open drain output can be selected with the ODCx register. can any one please tell me what is the difference between the two? thanks Puneet Gupta | |
A normal digital output can be driven HI and LOW by the PIC- it's what you would normally think of a digital pin. Normal digital pins have a pull-up transistor and a pull-down transistor. One transistor pulls the pin HI (by connecting the pin to +V), and the other pulls the pin LO (by connecting the pin to GND). An open-drain output has no pull up transistor and only has the pull-down transistor. This means that instead of being able to make the pin go HI or LO like a normal digital pin, the pin can only go LO or high impedance/floating. This means you need a pull-up resistor to make the pin HI. The "drain" on the LO transistor is "open" (not connected to a pull-up transistor). Open collector means the exact opposite (the drain on a MOSFET is the equivelant of the collector on a BJT)- it can go HI, but goes high impedance instead of going LO and a pull-down resistor is needed. http://en.wikipedia.org/wiki/Open_collector
__________________ Tanaka Sensei (avatar) says: Please spell it "ridiculous" correctly! Not "rediculous". ^^ Last edited by dknguyen; 28th May 2009 at 07:12 AM. | |
| | #3 | |
![]() Mike. Last edited by Pommie; 28th May 2009 at 07:35 AM. Reason: typo | ||
thanks for the information.... so in the normal pin case : in pull up transistor if Vcc is equal 3.3V and if i make the pin high...pin will have 3.3 V... in the open drain case , i want pin should have 5.5 V making it high, so i have to connect pull up resistor to the 5.5V?? | |
| b or w, difference, drain, normal, open, output, pic |
| open drain output. | alphacat | General Electronics Chat | 15 | 23rd May 2009 07:12 PM |
| Is a 12f output pin an open drain? | smanches | Micro Controllers | 3 | 28th March 2009 08:38 AM |
| Pic16f628a - Ra4 Open Drain Output | fenderman | Micro Controllers | 19 | 10th February 2009 02:15 AM |
| PWM on normal output pins? | MrMikey83 | Micro Controllers | 4 | 23rd February 2005 03:52 AM |
| The difference in open-drain and push-pull | elarson | General Electronics Chat | 4 | 3rd January 2004 10:38 AM |
