Hello, I'm using an Arduino (5v) and the device is a Skytraq-Venus634FLPx GPS module that is 3.3v LVTTL UART http://www.sparkfun.com/datasheets/G...Px_DS_v051.pdf I've heard about Bipolar transistors that can do the job. I don't know more and can't go any further as my skills reach the limit at this point. Anyone ? Thanks! | |
Hi, So many level translators are available in the market and also it's very cheap.And for your reference some of the level translator part~ for 5V to 3.3V and vice versa Voltage Level Translation - Dual Supply Translators - SN74LVC2T45 - TI.com This device will solve your problem.Any further clarifications please mail me on aarupk@gmail.com | |
I have had the 74HCT125 recommended to me. Works great in my SD Project.
The 74HCT125 is awesome for SD since its a QUAD piece. You might find it more usefull using that part. The SN74LVC2T45 is a OCTAL part which may be a overkill. I think its ok if you connect the 3.3v output to a 5v input aka 3.3v Tx pin to micro but for the input pin use that IC. You could use the IC for both if you wish. I never tried this but maybe you can convert the 3.3v logic to a 5v logic: I assume you need to setup like 1A = 3.3v 1Y = 3.3v Rx Pin on GPS module 1OE = TX on PIC 2A = 5v 2Y = Rx on PIC 2OE = 3.3v TX Pin on GPS module If im wrong please correct me. ![]() Be aware that this IC : "outputs enable inputs (OE = active LOW)" A "74AHC126" would be the best for this i think
__________________ AtomSofts eBay Store AtomSoftTech: C18 TIPS & TRICKS v9 PDF Nokia 6100 Driver/Software My Name: Jason Lopez http://atomsofttech.info/ | My YouTube Videos! My Favorite Store: dipmicro Electronics Last edited by AtomSoft; 28th May 2009 at 01:46 PM. | |
| | #6 |
I will not recommed the HCT,HC series buffer.And 74HCT125 is not a level translator.Use level translator only.Level translator only solves your problem
| | #7 |
@Arumugam, i let you know if i suceed. Thanks for all the help gals and guys!
| | #8 |
If you can find them in your area the Texas chips TXB0104 - 4 bit and TXB0108 - 8 bit, are much simpler to use - although only available in smd. They are true 4 / 8 bit dual voltage bidirectional voltage level translators with auto direction sensing. see - http://focus.ti.com/lit/ds/symlink/txb0104.pdf | |
| 33v, interfacing, rd or tx, tx or rx |
| interfacing a PC | uranium05r | Electronic Projects Design/Ideas/Reviews | 9 | 1st February 2009 06:30 AM |
| Interfacing A Car | hgfd7ert | Micro Controllers | 6 | 21st October 2007 03:47 AM |
| Interfacing USB with PIC | Pirasath | Electronic Projects Design/Ideas/Reviews | 7 | 15th September 2005 11:24 AM |
| INTERFACING WITH C | aibelectronics | Electronic Projects Design/Ideas/Reviews | 16 | 5th August 2005 04:40 PM |
| Interfacing between 5.0V and 3.3V IC | StupidDum | General Electronics Chat | 3 | 5th November 2004 03:02 PM |
