Old 25th May 2009, 03:57 AM   #1
Default humble request...,,,,shall be very thankful.
How to calculate frequency of square wave with unknown frquency coming on P3.5 of 8051 controller in c?
my effort is as follows.plz help by modifying it.
i am not sure ,will the following program keep on counting or will calculate the pulses in one second..?
#include <AT89X51.H>
void msdelay(unsigned int);
void main()
unsigned char value;
T1=1; //make t1 an input
TMOD=0x06; //counter 1,mode 2 ,8 bit auto reload mode
TH1=0; //set count to 0
while(1) //repeat forever
do
TR1=1; //start timer
value=TL1; //store tL1 in value
P1=value; //place value on pins of p1
while(TF1==0); //wait here
TR1=0; //stop timer
TF1=0; //clear flag
void msdelay(unsigned int itime)
unsigned int i,j;
for(i=0;i<itime;i++)
for(j=0;j<1275;j++);
arsal.javaid is offline
Old 2nd June 2009, 07:41 PM   #2
Disclaimer first, I do not know anything about Amtel. However, I will do my best.
You need to look up what "mode 2" means for the timer. Does it count up? Count down?
The timer appears to be set to auto-reload, that probably means it will keep going after the first overflow (or underflow). It will output the value on the pins of p1 (port one?). However, I do not know what the delay will be. It does not appear that there is any delay in the timer steps, so it will probably run at full speed and count faster than you can see.
The function msdelay() is never called, so it is quite redundant.
Do not forget code tags around your program next time, it makes it easier to read.
edeca is online now
humble, request, thankful
Hi! New here - and help request :) Brianonymous Electronic Projects Design/Ideas/Reviews 3 7th December 2008 10:15 PM
A new request Bryan76 General Electronics Chat 9 21st December 2006 05:30 AM
Request (please Help) mos3ad Datasheet/Parts Requests 0 22nd June 2005 11:07 AM
request help imgemini Electronic Projects Design/Ideas/Reviews 0 19th June 2004 10:04 PM
Request marwahadhoud Electronic Projects Design/Ideas/Reviews 1 7th February 2004 12:53 AM
