Right, so you're using a crystal oscillator, presumably 4MHz or so?.
When you get a brand new chip and read it, what do you get? - every memory location should read all ones.
Yes, theres a 4.0mhz crystal...
When I read it I get all F7F... I'm guessing thats all ones?
Is there another program I should try to use to burn these? Maybe the MPLAB is doing something thats causing the problem?
okay, I tried to program another PIC, programming seems okay as usual, but the pic still does not work. Heres the screen from MPLAB, when I hit 'program' I get a screen that says
Device NOT blank, Program Memory Configuration Bits (Even though it is blank??)
I programmed it and then did a verify
PICSTART Plus Firmware Version 04.50.11
Device is NOT blank:
Program Memory
Configuration Bits
PICSTART Program\Verify Report
30-May-2009, 17:35:04
Device Type: PIC16C57
Address Range 0-7ff
Programming/Verification completed successfully
30-May-2009, 17:35:18
Address Range 0-7ff
Program Memory Errors
Address Good Bad
0001: 08A0 0820
0004: 08D7 0857
0006: 089E 081E
000B: 0881 0801
000C: 08B8 0838
000D: 08CC 084C
0011: 08FC 087C
0012: 08D0 0850
001C: 0C87 0C07
0048: 04C7 0447
0049: 0996 0916
0059: 0AA9 0A29
005E: 0ACF 0A4F
0063: 05A3 0523
0069: 05A3 0523
006A: 0ABA 0A3A
006F: 05A3 0523
0070: 0AB0 0A30
0072: 06E7 0667
0075: 07FA 077A
0078: 0DE0 0D60
007D: 099F 091F
0080: 05C7 0547
0081: 02A4 0224
0087: 0990 0910
008A: 0990 0910
008B: 0388 0308
0091: 06E7 0667
0092: 0A90 0A10
0093: 0CFF 0C7F
0095: 04C7 0447
0097: 07E7 0767
Any additional errors are not displayed.
It's a 12 bit device, when it's blank it should read all 'FFF', whereas the 14 bit devices read '3FFF' because of the extra two bits.
If it's reading 'F7F' then it's not blank, or at least not working correctly.
If you check the error log you posted, that's the problem, bit 7 is always zero.
Do you know someone else who has a PICStart+, who could check one of your blank chips for you?.
No I don't, I have a Willem and a Data I/O 3900, I'll check if one of those two can supports PICs.. I'm guessing that its the PicStart and not the new PICs from mouser.
No luck, neither programmers support this PIC
You should not be using the C series PICs for prototyping as they cannot be erased unless they're the JW versions.
It should not be difficult to migrate to a Flash device.
I would love to migrate to a flash version (PIC16f57) but I don't have the source code for my project just the .hex and .bin files to burn. Can it still be done easily with these or do I have to have the source code?
Can you post the .hex file?
it's from an old game. I was wanting to figure out what it does so I can change it and the game settings.
removed now....
Good news, I contacted Microchip about my problem and they gave me a work around. The PIC16c57 needs Pin 26 not connected to be programmed correclty in the Picstart Plus. So I made an adapter and it works perfectly and I was able to program and verify a working PIC.
blueroomelectronics- Did you get a chance to DL the .hex yet?
I actually had to pay to have the rights to use the file for what ever I wanted. So I don't want to leave it out there too long. Its kinda worthless though if you dont know application it goes to which is why I posted it anyways.
I would just like to be able to decipher that table of values now so I can play with it more.
I also got it converted to a PIC16F57 today, still working on what the RETLW lines are doing at the top of the file.
okay, Is there a way that I can add some code to the .asm and make it show me the value of each of the items it is looking up? Like using the Debugger in MPLAB ? Some kind of Print type command that will show up in the output window of the debugger?
Heres the table from the .asm
; Created By: PIC Disassembler
; Version: 0.3.0.476
; Created On: 6/4/2009 3:43:50 PM
; Processor Type
LIST P=PIC16F
; Equ
W EQU H'0000'
F EQU H'0001'
; Code
org 0x0
RETLW 0x4D
RETLW 0xA0
RETLW 0x74
RETLW 0x05
RETLW 0xD7
RETLW 0x51
RETLW 0x9E
RETLW 0x0A
RETLW 0x64
RETLW 0x14
RETLW 0x68
RETLW 0x81
RETLW 0xB8
RETLW 0xCC
RETLW 0x14
RETLW 0x1C
RETLW 0x2C
RETLW 0xFC
RETLW 0xD0
CLRWDT
CLRW
