+ Reply to Thread
Page 2 of 3
First 1 2 3 Last
Results 16 to 30 of 33
Thread: USART/UART data receiving problem
  1. #16
    Join Date
    Nov 2003
    Location
    Derbyshire, UK
    Posts
    29,794
    Quote Originally Posted by Sceadwian View Post
    The sync can't be 100% perfect every time if the baud rate isn't the same, when the error is high enough and the two clocks are at their worst sync point is where the errors occur, once the bit error occurs in a stream synchronization is lost and can't be regained until there's a break in the transmition because it won't be reading the start and stop bits properly anymore.
    But you're talking about a baud rate error larger than a single byte, if the baud error is smaller than that, then it can't lose synchronisation, because the stop bit and subsequent start bit resyncronise at every byte.
  2. #17
    Sceadwian Excellent Sceadwian Excellent Sceadwian Excellent Sceadwian Excellent Sceadwian Excellent Sceadwian Excellent Sceadwian Excellent
    Join Date
    Oct 2006
    Location
    Rochester, NY U.S.
    Posts
    9,826
    Blog Entries
    1
    Not sure how to do the math on that, so what baud error are you saying is required for it to no longer sync?
    straight answer, har har."
  3. #18
    Pommie Excellent Pommie Excellent Pommie Excellent Pommie Excellent Pommie Excellent Pommie Excellent Pommie Excellent Pommie Excellent Pommie Excellent Pommie Excellent Pommie Excellent
    Join Date
    Mar 2005
    Location
    Brisbane Australia
    Posts
    6,813
    The error has to be less than half a bit width which works out about 5%. I have found that if I only have 1 stop bit the bit error does become accumulative. Two stop bits allows enough time for the start bit to cause a resync.
    Join Date
    Oct 2006
    Location
    Rochester, NY U.S.
    Posts
    9,826
    Blog Entries
    1
    Okay you stated some numbers Pommie, how'd you come up with them? Cause I've had corrupted data at around 3%
  5. #20
    Join Date
    Mar 2005
    Location
    Brisbane Australia
    Posts
    6,813
    Think about when the signal is sampled. After the (leading edge of the) start bit is received there is a wait of 1½ bits before the first data bit is sampled. Errors will occur if the sample is ½ a bit either way when the 8th bit is received. So, from the start bit to the final sample is 9½ bit lengths. One half in nine and a half is around 5%.
    Some software routines don't sample as often and so miss the start of the start bit and thus the acceptable error is smaller.
  6. #21
    Mr RB Excellent Mr RB Excellent Mr RB Excellent Mr RB Excellent Mr RB Excellent Mr RB Excellent Mr RB Excellent
    Join Date
    Jul 2008
    Location
    Out there
    Posts
    1,761
    If the PIC only needs to read data from that particular GPS receiver, you can try adjusting the PIC baud rate generator up and down to find the hi/lo baudrate limits where you start to get errors.
    Then pick the baud generator value right in the middle giving you the best possible reliability with that GPS device.
    This is because it is likely the GPS device uses a non-perfect baudrate as well.
  7. #22
    Join Date
    Oct 2006
    Location
    Rochester, NY U.S.
    Posts
    9,826
    Blog Entries
    1
    It's more than likely the GPS unit has a baud rate compatible crystal. Mbarren has hopefully already moved on. I've never taken apart a commercial device that doesn't work with a baud rate compatible frequency on the output stage of it's serial devices.
  8. #23
    Join Date
    Nov 2003
    Location
    Derbyshire, UK
    Posts
    29,794
    Quote Originally Posted by Pommie View Post
    Perhaps a little 'nit-picky', but the way I do it (which I think is pretty universal?), is to resample the start bit half a bit after it's detected, then sample each bit after a one bit time.
    The reason for this is so you can abort the read if the start bit isn't still valid after half a bit time, which of course it still should be.
  9. #24
    Join Date
    Oct 2006
    Location
    Rochester, NY U.S.
    Posts
    9,826
    Blog Entries
    1
    That's good for start bit detection, what happens if it confuses the start bit with a data bit? You'll get garbage out, for at least that byte, and every sequential byte if the next data byte happens to have a data bit set in the receivers perceived start bit spot.
  10. #25
    Join Date
    Nov 2003
    Location
    Derbyshire, UK
    Posts
    29,794
    That's how RS232 works, and is in no way affected by clock accuracy (within reason) - obviously it shouldn't confuse the start bit with a data bit, because the start bit 'should' come along first.
    It's an obvious reason why RS232 commonly uses 'packets' and error checking.
  11. #26
    Join Date
    Oct 2006
    Location
    Rochester, NY U.S.
    Posts
    9,826
    Blog Entries
    1
    Define 'within reason'
    The start bit only comes along first _IF_ the baud rates are perfectly in sync. Desync near the end of a byte and all hell breaks lose. Once the sync is lost the receiver will lock onto the next start bit which may be a data bit, it'll look for 8 bits which it'll get no matter what they are, and look for another stop bit and try to resync which is more than likley goign to be another data bit. It's also why there is an option for 2 stop bits, which is many times a blanket cure for sync issues.
    Nigel, seriously, I'm not guessing here, I've actually tested and observed this, just not the threshold of what the baud difference needs to be for it to occur, cause honestly it's UART and clock drive dependant.
  12. #27
    Join Date
    Nov 2003
    Location
    Derbyshire, UK
    Posts
    29,794
    'Within reason' is within the acceptable baud rate error, which a previous poster calculated as 5% - anything under that 5% error is just as good as 0% error.
    The two stop bits is more to give the receiver time to process the previous byte than an error prevention tactic - otherwise it might miss the next start bit because it's not ready in time. It was far more common in the old days, when you had mechanical printers and no buffers.
  13. #28
    mbarren Good mbarren Good mbarren Good
    Join Date
    May 2009
    Posts
    9
    Found sometime to go over this in details and here're are my findings, which may be not be correct at all, so please hint out the problems.
    Let's start with a perfect baud rate match between the transmitter and receiver:
    Hopefully the image is self explanatory. I have assumed the receiver can poll the line status/voltage many times faster than the baud rate, to simplify things (I read about programming a PIC to handle 115200 baud rate with 4Mhz clock). That's why there is a solid gray area which shows constant monitoring of the line by the receiver. I've also assumed perfect vertical rising/falling edges.
    Now here's where the receiver is running at a faster baud rate than the transmitter. This is what I think the maximum difference between the two baud rates can be:
    Note that when receiver polls the line in where it expects the middle of the stop bit to be, it's just after the rising edge of the actual stop bit. If you stretch out the bottom wave any further, the receiver will read in the 8th data bit instead of the stop bit.
    However, staying within the range shown in the graph, there will be no errors even in back to back transmission, since the receiver syncs to the start bit for each byte.
    In situations where the baud rate of receiver is less than that of the transmitter, I'm not quite sure what would happen. If we assume that the receiver waits for the entire length of stop bit before polling the line for the next start bit, there is no way the receiver can keep in sync in back to back transmissions, unless the baud rates differ only by less than half a bit!
    However, if we assume that the receiver will start polling the line for the next start bit right after checking for the stop bit (which is half way through it), then:
    Putting the two situations together, I came up with this formula to find out if two different bit rates can work without errors in back to back transmissions:
    which simply means, maximum +/- 5.2% of transmitter baud rate
    This formula only works for a 8 bit data, 1 stop bit settings.
    And here's a graph of it:
    The red shaded areas are the safe areas.
  14. #29
    Join Date
    Mar 2005
    Location
    Brisbane Australia
    Posts
    6,813
    It's late here and so I can't work that out. Can you give us a percentage value? My initial view is 0.5 in 9.5.
    Join Date
    May 2009
    Posts
    9
    For the transmission baud rate of 38400, the receiver rate should be between -5% and +5.5% of 38400. as you mentioned before.
+ Reply to Thread
Page 2 of 3
First 1 2 3 Last
  1. Replies: 8
    Latest: 19th April 2009, 04:51 PM
  2. USART Receiving a String Problem
    By Suraj143 in forum Micro Controllers
    Latest: 17th June 2008, 06:53 AM
  3. PIC16F628A USART receiving problem
    By AWHF in forum Micro Controllers
    Latest: 15th March 2008, 04:26 PM
  4. USART not receiving correct characters
    By HakBot in forum Micro Controllers
    Latest: 9th October 2007, 01:33 PM
  5. Problem in applying configuration data to UART
    By tkvenki in forum Micro Controllers
    Latest: 22nd March 2007, 10:59 AM
Tags for this Thread
