| | #121 |
here is what I have for a true glcd presentation. the program starts with drawing pixels, then characters, and then strings. so it is more portable but will not be as fast. it uses DirtyLube's idea of using a video ram. it can address 132x65 pixels so it can be used with other sed1565-based glcd. no fancy graphics function yet. I still need to fix the right columns, through. | |
| | #122 |
cool you guys are going to end up making me create a screen buffer and stuff lol
__________________ AtomSofts eBay Store AtomSoftTech: C18 TIPS & TRICKS v9 PDF My Name: Jason Lopez http://atomsofttech.info/ | My YouTube Videos! My Favorite Store: dipmicro Electronics | |
| | #123 |
here is the first half of the code. Code: //#include <htc.h>
//#include "delay.h"
#include <LPC210x.h>
//#include "always.h"
#define GETBIT(var,bit) (((var)>>(bit))&1) /* read bit from var */
#define SETBIT(var,bit) ((var)|=(1L<<(bit))) /* set bit from var to 1 */
#define CLRBIT(var,bit) ((var)&=(~(1L<<(bit)))) /* clear bit from var (set it to 0) */
#define uint unsigned int
#define byte unsigned char
//#define delay_ms() DelayMs()
// Description : This firmware for Nokia 7110 (SED1565 controller) 96*65 TEST //
// Hardware : PIC16F875 , LCD NOKIA7110 //
// Firmware : Rev 0.1 //
// Date : 6/14/2009 //
// by : Hello world //
// Compiler : PICC-Lite 9.6L1 / TIDE //
//#include <16F877.h>
//#fuses HS,NOPUT,NOWDT,NOPROTECT,NOBROWNOUT,NOLVP
//#use delay(clock=20000000,RESTART_WDT)
//#byte lcdport = 6 // (PORTB address value 6 for PIC16F628 device)
// hardware configuration
// PIC SIDE LCD SIDE
/*#bit nok_sda = lcdport.0 // RB0 pin-19 pin-13 Serial data
#bit nok_sclk = lcdport.1 // RB1 pin-20 pin-05 Serial clock
#bit nok_dc = lcdport.2 // RB2 pin-21 pin-04 Data or Command mode
#bit nok_cs = lcdport.3 // RB3 pin-22 pin-02 LCD Chip select
#bit nok_res = lcdport.4 // RB4 pin-23 pin-14 LCD Reset
#zero_ram
// change this section if your pin connection is different
#define lcd_res 0 //lcd_res connected to p0.0, pin13
#define lcd_sda 1 //lcd_sda connected to p0.1, pin14
#define lcd_led 2 //led backlight connected to p0.2, pin18
#define lcd_sclk 3 //lcd_sclk connected to p0.3, pin21
#define lcd_dc 4 //lcd_dc connected to p0.4, pin22
#define lcd_cs 5 //lcd_cs connected to p0.5, pin23
// end hardware configuration
// display attributes
#define NORMAL 0x00 // normal black on green
#define UNDERLINE 0x80
#define STRIKE 0x10
#define OVERLINE 0x01
#define REVERSE 0xff //green on black
#define negative_lcd lcd_write_command(lcd_reverse)
#define normal_lcd lcd_write_command(lcd_normal)
LCD Commands
#define pow_ctrl 0x20 // (16) power control set value (contrast level --> 0x00 lightest to 0x3F darkest), from 0b00101000 to 0b00101111.
#define v5_ratio 0x22 //(17) V5 resistor ratio, from 0b00100000 to 0b00100111. need to add some ratio
#define start_line 0x40 // start line - set the display line start address.
#define elec_vol 0x81 // (18) electronic volume mode
#define adc_normal 0xA0 // (8) <ADC select> (0xA1/0b10100001 reverse lcd - 0xA0/0b10100000 select normal)
#define adc_reverse 0xA1
#define lcd_bias_1_over_9 0xA2 // (11) lcd bias (1/9 0xA2/0b10100010 - 1/7 0xA3/0b10100011)
#define lcd_bias_1_over_7 0xA3
#define lcd_all_off 0xA4 //turn all pixels off
#define lcd_all_on 0xA5 //lcd all points on - turn on all pixels. 0xA4: normal display.
#define lcd_normal 0xA6 // 0b10100110 = 0xA6, lcd in normal display mode (0xA7/0b10100111 negative mode)
#define lcd_reverse 0xA7
#define lcd_off 0xAE //
#define lcd_on 0xAF // lcd on - display on. 0xAE: display off.
#define comm_normal 0xC0 // (15) common output normal (0xC8 reverse)
#define comm_reverse 0xC8
#define lcd_nop 0xE3 // nop (command for no-operation, 0b11100011.
#define lcd_1st_col 0x12 //first displayable column. datasheet didn't mention this. WEIRD!
Global Variable
char page;
//char lcd_row,lcd_col; //current row and column
char VidRAM[8][132]; //video ram, 8 rows and 132 column, each a byte.
Function Prototype
void lcd_write_dorc(char byteforlcd);
void lcd_write_command(char byteforlcd_command);
void lcd_write_data(char byteforlcd_data);
void lcd_setpixel(char lcd_row, char lcd_col);
void lcd_clrpixel(char lcd_row, char lcd_col);
void lcd_write_byte(char lcd_row, char lcd_col, char charsel, char attribute);
//void lcd_gotoxy(char lcd_row, char lcd_col); //go to lcd_row / 0-8; and lcd_col / 0-95
//void lcd_pixel(char x, char y); // not used.
void lcd_chr(char lcd_row, char lcd_col, char charsel, char attribute);
void lcd_str(char lcd_row, char lcd_col, const char *str, char attribute);
void lcd_reset(void);
void lcd_cls(void);
void lcd_init(void);
void mcu_init(void);
void DelayUs(int);
void DelayMs(int);
ASCII table for 5x7 dots font
const char Char_Table [] = {
0x00,0x00,0x00,0x00,0x00, // 20 space
0x00,0x00,0x5f,0x00,0x00, // 21 !
0x00,0x07,0x00,0x07,0x00, // 22 "
0x14,0x7f,0x14,0x7f,0x14, // 23 #
0x24,0x2a,0x7f,0x2a,0x12, // 24 $
0x23,0x13,0x08,0x64,0x62, // 25 %
0x36,0x49,0x55,0x22,0x50, // 26 &
0x00,0x05,0x03,0x00,0x00, // 27 '
0x00,0x1c,0x22,0x41,0x00, // 28 (
0x00,0x41,0x22,0x1c,0x00, // 29 )
0x14,0x08,0x3e,0x08,0x14, // 2a *
0x08,0x08,0x3e,0x08,0x08, // 2b +
0x00,0x50,0x30,0x00,0x00, // 2c ,
0x08,0x08,0x08,0x08,0x08, // 2d -
0x00,0x60,0x60,0x00,0x00, // 2e .
0x20,0x10,0x08,0x04,0x02, // 2f /
0x3e,0x51,0x49,0x45,0x3e, // 30 0
0x00,0x42,0x7f,0x40,0x00, // 31 1
0x42,0x61,0x51,0x49,0x46, // 32 2
0x21,0x41,0x45,0x4b,0x31, // 33 3
0x18,0x14,0x12,0x7f,0x10, // 34 4
0x27,0x45,0x45,0x45,0x39, // 35 5
0x3c,0x4a,0x49,0x49,0x30, // 36 6
0x01,0x71,0x09,0x05,0x03, // 37 7
0x36,0x49,0x49,0x49,0x36, // 38 8
0x06,0x49,0x49,0x29,0x1e, // 39 9
0x00,0x36,0x36,0x00,0x00, // 3a :
0x00,0x56,0x36,0x00,0x00, // 3b ;
0x08,0x14,0x22,0x41,0x00, // 3c <
0x14,0x14,0x14,0x14,0x14, // 3d =
0x00,0x41,0x22,0x14,0x08, // 3e >
0x02,0x01,0x51,0x09,0x06, // 3f ?
0x32,0x49,0x79,0x41,0x3e, // 40 @
0x7e,0x11,0x11,0x11,0x7e, // 41 A
0x7f,0x49,0x49,0x49,0x36, // 42 B
0x3e,0x41,0x41,0x41,0x22, // 43 C
0x7f,0x41,0x41,0x22,0x1c, // 44 D
0x7f,0x49,0x49,0x49,0x41, // 45 E
0x7f,0x09,0x09,0x09,0x01, // 46 F
0x3e,0x41,0x49,0x49,0x7a, // 47 G
0x7f,0x08,0x08,0x08,0x7f, // 48 H
0x00,0x41,0x7f,0x41,0x00, // 49 I
0x20,0x40,0x41,0x3f,0x01, // 4a J
0x7f,0x08,0x14,0x22,0x41, // 4b K
0x7f,0x40,0x40,0x40,0x40, // 4c L
0x7f,0x02,0x0c,0x02,0x7f, // 4d M
0x7f,0x04,0x08,0x10,0x7f, // 4e N
0x3e,0x41,0x41,0x41,0x3e, // 4f O
0x7f,0x09,0x09,0x09,0x06, // 50 P
0x3e,0x41,0x51,0x21,0x5e, // 51 Q
0x7f,0x09,0x19,0x29,0x46, // 52 R
0x46,0x49,0x49,0x49,0x31, // 53 S
0x01,0x01,0x7f,0x01,0x01, // 54 T
0x3f,0x40,0x40,0x40,0x3f, // 55 U
0x1f,0x20,0x40,0x20,0x1f, // 56 V
0x3f,0x40,0x38,0x40,0x3f, // 57 W
0x63,0x14,0x08,0x14,0x63, // 58 X
0x07,0x08,0x70,0x08,0x07, // 59 Y
0x61,0x51,0x49,0x45,0x43, // 5a Z
0x00,0x7f,0x41,0x41,0x00, // 5b [
0x02,0x04,0x08,0x10,0x20, // 5c 55
0x00,0x41,0x41,0x7f,0x00, // 5d ]
0x04,0x02,0x01,0x02,0x04, // 5e ^
0x40,0x40,0x40,0x40,0x40, // 5f _
0x00,0x01,0x02,0x04,0x00, // 60 `
0x20,0x54,0x54,0x54,0x78, // 61 a
0x7f,0x48,0x44,0x44,0x38, // 62 b
0x38,0x44,0x44,0x44,0x20, // 63 c
0x38,0x44,0x44,0x48,0x7f, // 64 d
0x38,0x54,0x54,0x54,0x18, // 65 e
0x08,0x7e,0x09,0x01,0x02, // 66 f
0x0c,0x52,0x52,0x52,0x3e, // 67 g
0x7f,0x08,0x04,0x04,0x78, // 68 h
0x00,0x44,0x7d,0x40,0x00, // 69 i
0x20,0x40,0x44,0x3d,0x00, // 6a j
0x7f,0x10,0x28,0x44,0x00, // 6b k
0x00,0x41,0x7f,0x40,0x00, // 6c l
0x7c,0x04,0x18,0x04,0x78, // 6d m
0x7c,0x08,0x04,0x04,0x78, // 6e n
0x38,0x44,0x44,0x44,0x38, // 6f o
0x7c,0x14,0x14,0x14,0x08, // 70 p
0x08,0x14,0x14,0x18,0x7c, // 71 q
0x7c,0x08,0x04,0x04,0x08, // 72 r
0x48,0x54,0x54,0x54,0x20, // 73 s
0x04,0x3f,0x44,0x40,0x20, // 74 t
0x3c,0x40,0x40,0x20,0x7c, // 75 u
0x1c,0x20,0x40,0x20,0x1c, // 76 v
0x3c,0x40,0x30,0x40,0x3c, // 77 w
0x44,0x28,0x10,0x28,0x44, // 78 x
0x0c,0x50,0x50,0x50,0x3c, // 79 y
0x44,0x64,0x54,0x4c,0x44, // 7a z
0x00,0x08,0x36,0x41,0x00, // 7b {
0x00,0x00,0x7f,0x00,0x00, // 7c |
0x00,0x41,0x36,0x08,0x00, // 7d }
0x10,0x08,0x08,0x10,0x08, // 7e ~
0x78,0x46,0x41,0x46,0x78}; // 7f ¦
//7e,43,40,43,7e //Ü
//7e,43,42,43,7e //Ö
//1e,21,21,71,21 //Ç
//3c,42,53,53,72 //Ð
lcd clear LCD function
void lcd_cls(void) {
char x, y;
for (page=0; page<9; page++) // 9 page, fill display RAM with 0s.
lcd_write_command(0xB0 | page); // page address ie:0xB0,0xB1,...,0xB7
lcd_write_command(0x11); // 0x11, most 4 bit column address command 0001 0011
lcd_write_command(0x01); // 0x02, least 4 bit column address command 0000 0011
for (x=96; x>0; x--) { // 96 column
lcd_write_data(0x00);
for (y=0; y<8; y++)
VidRAM[y][x]=0; //initialize the video ram
Reset LCD Function
void lcd_reset(void) {
IOSET = 1<<lcd_cs; //select the lcd
DelayMs(10);
IOCLR = 1<<lcd_res; //lcd_res low to reset the display. the lcd going into default state.
DelayMs(10); //give the lcd time to reset.
IOSET = 1<<lcd_res; //pulling the lcd out of reset.
DelayMs(100);
Initial LCD Function
void lcd_init(void) {
lcd_reset();
// the following initialization sequence per datasheet. All needs to be done in 5ms. (X) where X is the command on pg 8-56 of datasheet
lcd_write_command(lcd_normal); // 0b10100110 = 0xA6, lcd in normal display mode (0xA7/0b10100111 negative mode)
lcd_write_command(lcd_bias_1_over_7); // (11) lcd bias (1/9 0xA2/0b10100010 - 1/7 0xA3/0b10100011)
lcd_write_command(adc_reverse); // (8) <ADC select> (0xA1/0b10100001 reverse lcd - 0xA0/0b10100000 select normal)
lcd_write_command(comm_normal); // (15) common output normal (0xC8 reverse)
lcd_write_command(v5_ratio+2); // (17) V5 resistor ratio, from 0b00100000 to 0b00100111
lcd_write_command(elec_vol); // (18) electronic volume mode
lcd_write_command(pow_ctrl+0x0E); // (16) power control set value (contrast level --> 0x00 lightest to 0x3F darkest), from 0b00101000 to 0b00101111.
//this concludes the mandatory initialization, as specified on pg 8-56 of the datasheet
lcd_write_command(0x2F); // power control set value, from 0b00101000 to 0b00101111. see pg 8-52 of datasheet.
lcd_write_command(lcd_nop); // nop (command for no-operation, 0b11100011.
lcd_write_command(0x40); // start line - set the display line start address.
lcd_write_command(lcd_on); // lcd on - display on. 0xAE: display off.
// lcd_write_command(lcd_all_on); // lcd all points on - turn on all pixels. 0xA4: normal display.
DelayMs(50);
// lcd_write_command(lcd_off); // lcd off - turn display off.
lcd_cls();
// lcd_write_command(lcd_on); // lcd on
// lcd_write_command(lcd_all_off); // lcd normal display mode
sent 8 bit data to LCD by series
void lcd_write_dorc(char byteforlcd) { // same lcdai 3310
char caa;
for (caa=8;caa>0;caa--)
IOCLR=1<<lcd_sclk; //data sent on the rising edge of sclk line
// DelayUs(2);
if ((byteforlcd&0x80)==0) // tramission starts from D7, D6, .., D1, D0. if D7 is 0, send 0.
{IOCLR=1<<lcd_sda;}
else
{IOSET=1<<lcd_sda;}
IOSET=1<<lcd_sclk; //clock out the data
byteforlcd=byteforlcd<<1; //shift left the next bit.
Sent Command to LCD Function
void lcd_write_command(char byteforlcd_command) {
IOCLR=1<<lcd_dc; // dc=0 signals lcd command mode. A0 in the datasheet. dc=data or command.
IOCLR=1<<lcd_cs; // chip enabled, negative logic. _cs
lcd_write_dorc(byteforlcd_command); //send the command.
IOSET=1<<lcd_cs; // chip disabled
Sent Data to LCD Function
void lcd_write_data(char byteforlcd_data) {
IOSET=1<<lcd_dc; // display data mode. A0 in the datasheet. dorc=data or command.
lcd_write_dorc(byteforlcd_data); //send the data.
| | #124 |
and here is the 2nd half of the code Code: /**********************************************************
goto xy PIXEL position on LCD Function
void lcd_gotoxy(char lcd_row, char lcd_col) { //lcy_row: 0 - 8 (8th column has only 1 line / D0, lcd_col: 0 - 15.
char col_addr;
lcd_write_command(0xB0 + lcd_row); // page address set. pg 8-48 in the datasheet.
col_addr = (lcd_col*6); // each font has five columns + 1 blank column. xaddr: 0 - 95 on nokia 7110. no offset.
//lcd_1st_col=0x12: the first column of display starts here. Weird! the datasheet didn't mention it.
lcd_write_command(0x10 | (col_addr>>4)); // column address 4 most bit set
lcd_write_command(0x0f & col_addr); // column address 4 least bit set
set pixel at lcd_row and lcd_col
void lcd_setpixel(char lcd_row, char lcd_col) { //row: 0 - 63, col: 0-131
char x,y;
if (lcd_row>64) return;
if (lcd_col>0x83) return; //check for illegal addresses
x=lcd_row/8;
y=1<<(lcd_row % 8);
// VidRAM[x][lcd_col]=0;
VidRAM[x][lcd_col] |= y; //set the bit;
lcd_write_command(0xB0 + x); // page address set. pg 8-48 in the datasheet.
lcd_write_command(0x10 | (lcd_col>>4)); // column address 4 most bit set
lcd_write_command(0x0f & lcd_col); // column address 4 least bit set
lcd_write_data(VidRAM[x][lcd_col]);
clear pixel at lcd_row and lcd_col
void lcd_clrpixel(char lcd_row, char lcd_col) { //row: 0 - 63, col: 0-131
char x=lcd_row/8,y=1<<(lcd_row % 8);
x=lcd_row/8;
y=1<<(lcd_row % 8);
VidRAM[x][lcd_col] &= (~y); //set the bit;
write a byte / column to charractor Function
void lcd_write_byte(char lcd_row, char lcd_col, char charsel, char attribute) {
char i;
if (lcd_row>63) return;
if (lcd_col>0x83) return; //check for illegal address;
if (attribute == REVERSE)
charsel = ~charsel;
else
charsel |= attribute;
for (i=0; i<8; i++) {
if ((charsel & (1<<i)) == 0)
lcd_clrpixel(lcd_row+i, lcd_col);
else
lcd_setpixel(lcd_row+i, lcd_col);
Convert bitmap to charractor Function
void lcd_chr(char lcd_row, char lcd_col, char charsel, char attribute) {
char char_data, col;
int char_pos;
if (charsel < 0x20) return;
if (charsel > 0x7f) return; //check for illegal characters
for (col = 0; col < 5; col++) // 5 columns for 5 bytes;
char_pos=charsel-0x20;
char_data=Char_Table[char_pos*5+col];
// lcd_write_data(~char_data); // send font data to lcd, white char on black background
lcd_write_byte(lcd_row, lcd_col+col, char_data, attribute);
// lcd_write_data(~0x00); // blank side pixels for each font, white char on black background
lcd_write_byte(lcd_row, lcd_col+5, 0x00, attribute);
Write a string at current screen position
void lcd_str(char lcd_row, char lcd_col, const char *str, char attribute) {
char i=0;
while (*str) {
lcd_chr(lcd_row, lcd_col+i, *str++, attribute);
i+=6;
delay routines
void DelayUs(int us) {
for (; us>0; us--);
void DelayMs(int ms) {
for (; ms>0; ms--)
DelayUs(1000);
void mcu_init(void) {
// need to initialize the mcu here.
PINSEL0=0x00;
IODIR=0xff; //pin p0.0..p0.7 used for gpio.
Main Progarm
int main(void)
mcu_init();
lcd_init();
while (1) {
// lcd_chr('c');
// lcd_chr('b');
lcd_str(00, 18, "0-Hello, World!", NORMAL);
lcd_str(10, 19, "1-Hello, World!", NORMAL);
lcd_str(25, 20, "2-hello, world!", OVERLINE);
lcd_str(30, 21, "3-ABCDEFGHIJKLMN", UNDERLINE);
lcd_str(40, 22, "4-abcdefghijklmn", STRIKE);
lcd_str(50, 23, "5-OPQRSTUVWXYZ", OVERLINE | STRIKE);
// lcd_gotoxy(8,0);
// lcd_str("0-HELLO, WORLD!", NORMAL);
// lcd_cls();
/*void main(void) {
while (1){
//TODO Auto-generated main function
| | #125 |
the function calls are basically the same - those I am going away with the old "gotoxy" call. the only big difference is that rather than using row 0 - 7, we are using (pixel) row 0 - 64.
| | #126 |
My code probably would be slower because i was thinking of writing to the buffer then dumping buffer to screen. Meaning the entire screen. So i would write/edit some bits in the buffer then send the entire thing to the GLCD.
__________________ AtomSofts eBay Store AtomSoftTech: C18 TIPS & TRICKS v9 PDF My Name: Jason Lopez http://atomsofttech.info/ | My YouTube Videos! My Favorite Store: dipmicro Electronics Last edited by AtomSoft; 20th June 2009 at 04:43 PM. | |
| | #127 |
Jason: that doesn't sound very efficient. in my program, I update the byte that is changing: since the controller doesn't allow bit-by-bit addressing. | |
| | #128 |
what happens if the user crosses bytes? Like if i want to make a big X or O over the whole screen?
| | #129 |
in my program, the lcd_setpixel() and lcd_clrpixel() takes care of that. however, the font is pre-determined at 8x6 (8x5+1 actually), so to display a big X or O, you will have to define your font, or write a routine to draw it as an image. | |
| | #130 |
let me add a little bit: the lcd_setpixel() / lcd_clrpixel() routines will find the right byte, set or clear the right bits in that byte, in order to render the font, or images. Code: /**********************************************************
char x,y;
x=lcd_row/8;
y=1<<(lcd_row % 8);
after that, it is just drawing it on the lcd. | |
| | #131 |
sorry i mean the X is like 2 lines crossed over entire screen and the O is a circle not actual letters but i see what you mean now... thats awesome dude!
| | #132 |
millwood whats your name again? Also i was trying to learn from your mcu_init() function ... would you say this is a good comment: Code: void mcu_init(void) {
//Initialize the mcu here.
PINSEL0=0x00; //Pin Function Select Register 0 = P0.0:P0.7 are GPIO
IODIR=0xFF; //GPIO Port Direction (0=Input,1=Output)
i have my main like:Code: int main(void)
mcu_init();
lcd_init();
lcd_gotoxy(0,0);
lcd_str(" AtomSoftTech ", NORMAL);
lcd_gotoxy(6,0);
lcd_str(" Thanks ", NORMAL);
while (1) {
__________________ AtomSofts eBay Store AtomSoftTech: C18 TIPS & TRICKS v9 PDF My Name: Jason Lopez http://atomsofttech.info/ | My YouTube Videos! My Favorite Store: dipmicro Electronics Last edited by AtomSoft; 20th June 2009 at 07:49 PM. | |
| | #133 |
Jason: yeah, I think so - but I am new to ARM too. yes, I did want it to loop in main(). | |
| | #134 |
I am working on the actual drawing functions - need to figure out a way to do it without using floating point routines. the way I did it is quite portable but at the expense of speed / performance. it sounds like DirtyLube did it differently and I would love to see how. | |
| | #135 |
now, the line function, lcd_setline() is here. It was based on Jim Lynch's work for 6100 which itself is based on Jack Bresenham's line algorithm. it works beautifully, .the code is here: Code: /**********************************************************
draw a line between two points
code shamelessly stolen from Jim Lynch's 6100 driver
void lcd_setline(char x0, char y0, char x1, char y1) {
int dy = y1 - y0;
int dx = x1 - x0;
int stepx, stepy;
if (dy < 0) { dy = -dy; stepy = -1; } else { stepy = 1; }
if (dx < 0) { dx = -dx; stepx = -1; } else { stepx = 1; }
dy <<= 1; // dy is now 2*dy
dx <<= 1; // dx is now 2*dx
lcd_setpixel(x0, y0);
if (dx > dy) {
int fraction = dy - (dx >> 1); // same as 2*dy - dx
while (x0 != x1) {
if (fraction >= 0) {
y0 += stepy;
fraction -= dx; // same as fraction -= 2*dx
x0 += stepx;
fraction += dy; // same as fraction -= 2*dy
} else {
int fraction = dx - (dy >> 1);
while (y0 != y1) {
x0 += stepx;
fraction -= dy;
y0 += stepy;
fraction += dx;
| 96x64, controller, graphic, lcd, nokia7110, sed1565, w or |
| Graphic LCD | baberjaved | Micro Controllers | 2 | 13th November 2007 05:01 PM |
| Graphic LCD | flemmard | Micro Controllers | 1 | 13th September 2007 03:32 AM |
| interfacing of PIC16F877A with graphic LCD controller T6963c | rosamma | Micro Controllers | 1 | 24th March 2007 12:29 PM |
| graphic LCD PIC MCU | tom_electronic | Micro Controllers | 4 | 28th February 2006 12:29 PM |
| graphic lcd help | jijita | General Electronics Chat | 1 | 18th August 2004 07:32 AM |
