| | #31 |
heh Thanks a bunch! i would be happy just to be in the running ![]() I dont do PWM lol hate trying to do 3 at a time arg.. i get lost.. maybe because all my pics have 2 hardware only and the third would have to be in software Im going to clean up the code for the menu. Its a mess
__________________ AtomSofts eBay Store AtomSoftTech: C18 TIPS & TRICKS v9 PDF Nokia 6100 Driver/Software My Name: Jason Lopez http://atomsofttech.info/ | My YouTube Videos! My Favorite Store: dipmicro Electronics Last edited by AtomSoft; 26th May 2009 at 06:56 PM. | |
| | #32 |
Jason, 1) The photos might look a little clearer if you removed the protective film. 2) Have you confirmed the resolution? --David | |
| | #33 |
I wouldn't touch that protective film until it's in a unit to be used. Mike2545 sent me a butterlfy a ways back, the protective cover is still on it.
| | #34 |
I would never remove the protective film. I might be smart but im a messy guy lol it would be unreadable if i had removed it lol Yes I can fit : 12 (x 8 bits = 96 pixels) letters on screen from left to right and 8 (x 8 bits = 64 pixels ) down from top so thats 96x64. The only wierd thing is the pixels on the left start at 18 aka 0x12. But its still 96 pixels from there on. Here is my code for the menu. Its not the best coding but works like a charm. Even include a last menu to turn off leds and hide arrow on screen. Ill take a picture of the 4 stages. Code: void UpdateMenu(void){
unsigned char leftL, leftH, topV,x;
char left = 104; //88 + 18 = 104 //I add 18 becuase the LCD starts on pixel 18 not 1
leftH = left >> 4; //Calculate The Left Pixel
leftH |= 0x10; //Get upper byte in LeftH OR with 0x10 to prodcuce a valid command
leftL = left & 0x0F; //Get lower byte in LeftL
// Older Code remove with next 2 lines
leftH = 22; //Since this is a constant value i did the math
leftL = 8; //to save some time and placed it here
topV = 0xB0 + Top_POS; //Get the Top position and add 0xB0 to set the row (TOP)
if(Menu_POS > 3) { //If in Item 4 aka 0 erase arrow on 3
LCD_Send((topV-1),0); //Send Top Position - 1 this way we get the arrow on 3
LCD_Send(leftH,0); //Send Upper Left Position
LCD_Send(leftL,0); //Send Lower Left Position
for(x=0;x<8;x++) //Clear the arrow by setting to all 0's
LCD_Send(0x00,1);
Menu_POS = 0; //Clear the Menu Position
Top_POS = Top_STA; //Reset the Top Start
if(Menu_POS > 0){ //If item is greater than 0 do below
if(Menu_POS > 1){ //If in Item 2 erase arrow on 1 or 3 erase arrow on 2
for(x=0;x<8;x++) //clear the old arrow
LCD_Send(0x00,1);
LCD_Send(topV,0); //Send New Top Position
for(x=0;x<8;x++) //Send out our arrow which is added to the FontA and FontB
LCD_Send(FontB[96][x],1);
switch(Menu_POS){ //This is the actual command to set the LEDs
case 0:
LATB = 0b00000111; //Common Anode so to turn on i need Logic Low to turn on led.
break;
case 1:
LATB = 0b00000110;
break;
case 2:
LATB = 0b00000101;
break;
case 3:
LATB = 0b00000011;
break;
Code: while(1){
if(button == 0){
Menu_POS++;
Top_POS++;
UpdateMenu();
Delay10KTCYx(100);
__________________ AtomSofts eBay Store AtomSoftTech: C18 TIPS & TRICKS v9 PDF Nokia 6100 Driver/Software My Name: Jason Lopez http://atomsofttech.info/ | My YouTube Videos! My Favorite Store: dipmicro Electronics Last edited by AtomSoft; 26th May 2009 at 08:10 PM. | |
| | #36 |
Just noticed pictures wont show my LED Color. So i took off the flash lol and here ya go from left to right is Menu items 0-3:
__________________ AtomSofts eBay Store AtomSoftTech: C18 TIPS & TRICKS v9 PDF Nokia 6100 Driver/Software My Name: Jason Lopez http://atomsofttech.info/ | My YouTube Videos! My Favorite Store: dipmicro Electronics | |
| | #37 |
New top banner! lol bored:
| | #38 |
Hi everybody, Does anyone know where to find the connector for these LCD's. Thank you. Geraldes | |
| | #39 |
heh would you believe there isnt one ? i dont but i doubt there is one. I think it was pushed against the PCB and held there. Im designing a board and holder right now in 3d studio max (3D CAD software) to hopefully get it produced as a board so i can stock em and sell em. Im make a rough draft drawing now.
| | #40 |
Looking at the pictures, it's an FPC connector of some kind. It doesn't look standard though, since the FPC seems to extend to the left and right even when the contacts stop. I ordered a few of the E-Bay $1 ones. I really don't have a specific use right now, but I'm thinking maybe add it to an RF remote with an MSP430 and a CC1100 low power RF transceiver. It'll give much better visual feedback on controlled devices and use very little power for a battery operated device.
__________________ Mark Higgins | |
| | #41 |
This is a extremely rough draft. Im waiting for Autodesk Inventor Trial to come in. i know it will be way better to play with that.
| | #42 |
What is the connector pin pitch ?
__________________ Please post questions to the forums. PM's are for personal communication. BCHS/3v0's Tutorials Junebug USB PIC programmer kit., USB Bit Whacker, The 15 Minute Printed Circuit Board! (+drill time) | |
| | #43 |
not sure i need a ruler lol. its smaller than soic bit
| | #44 | |
Yeah I found a good "standard lcd" 5x7 font a couple weeks back on google, I think I posted the link on this forum, I dont seem to have a record of it on my PC sorry. | ||
| | #45 |
The space between pins is 1mm. The space bewteen rows is 3mm. The 2 rows are staggered on centers. The contacts protrude less than 1mm. Since the sides of the connector are open, I'm thinking there might be fingers on the phone which clamp like those old DIP test headers. Somebody needs to take apart an old phone and see how it's done. ![]() --David | |
| 96x64, controller, graphic, lcd, nokia7110, sed1565, w or |
| Graphic LCD | baberjaved | Micro Controllers | 2 | 13th November 2007 05:01 PM |
| Graphic LCD | flemmard | Micro Controllers | 1 | 13th September 2007 03:32 AM |
| interfacing of PIC16F877A with graphic LCD controller T6963c | rosamma | Micro Controllers | 1 | 24th March 2007 12:29 PM |
| graphic LCD PIC MCU | tom_electronic | Micro Controllers | 4 | 28th February 2006 12:29 PM |
| graphic lcd help | jijita | General Electronics Chat | 1 | 18th August 2004 07:32 AM |
