| | #196 |
going to try it soon!
__________________ Rεσllγ !!! Mγ Σ×ρer!ence is Directly Propotional τΘ the NΦ of Electronic Items I have Me§§eD µρ . .. | |
| | #197 | |
here is my complete code but its for the LPC2148 and im using the Olimex board. Code is written using Crossworks for ARM. This code will show a start screen with my info then after 2 seconds show another screen for collecting SONY (SIRC) infrared data and displaying it to user. Also makes a special tone for each code recieved from 0-9 and POWER. For power it will tone a going up hill type tone and when pressed again it will sound like somethings falling lol I was bored it sounds real nice tho. My cam wont pick it up well tho. Too noisy i guess.Ill have to post a C file or another post cuz it wont fit in this one ![]() Quote:
__________________ AtomSofts eBay Store AtomSoftTech: C18 TIPS & TRICKS v9 PDF Nokia 6100 Driver/Software My Name: Jason Lopez http://atomsofttech.info/ | My YouTube Videos! My Favorite Store: dipmicro Electronics Last edited by AtomSoft; 2nd August 2009 at 08:16 PM. | ||
| | #198 |
Now with a UART1 interface at 115200 8-n-1 : Called it Olimex.c now since its for that board...
__________________ AtomSofts eBay Store AtomSoftTech: C18 TIPS & TRICKS v9 PDF Nokia 6100 Driver/Software My Name: Jason Lopez http://atomsofttech.info/ | My YouTube Videos! My Favorite Store: dipmicro Electronics | |
| | #199 |
Thank you for making the video available Jason. | |
| | #200 |
hey np at all
| | #201 |
hey guys im trying something here... do you think this is helpful at all? http://atomsofttech.info/cross/1/
__________________ AtomSofts eBay Store AtomSoftTech: C18 TIPS & TRICKS v9 PDF Nokia 6100 Driver/Software My Name: Jason Lopez http://atomsofttech.info/ | My YouTube Videos! My Favorite Store: dipmicro Electronics Last edited by AtomSoft; 4th August 2009 at 01:44 AM. | |
| | #202 |
The thing that can bite you on this is that the web pages or IDE you use in the demo may change. Often sooner then you would image. 3v0
__________________ Please post questions to the forums. PM's are for personal communication. BCHS/3v0's Tutorials Junebug USB PIC programmer kit., USB Bit Whacker, The 15 Minute Printed Circuit Board! (+drill time) | |
| | #203 |
heh that makes sense i guess ill skip that or write a hand tutorial and then hopefully they wont change it much
| | #204 |
Ok im no guru but im sure this will help alot of people.... I have to show how the delay is counted for. This is a 12 mhz clock solution right now ![]() Code: /*--
Company:.... AtomSoft
Author:..... Jason Lopez
/*-- Please download --- UM10139: Volume 1: LPC214x User Manual --*/
/*-- As i will refer to it for more info here... --*/
#include <LPC214x.h>
/*-- We use defines to make the code easy to see and change in the future --*/
/*-- Here i am defining 1 LED as a number. The number is the bit/pin that --*/
/*-- the LED is connect to on the IC. --*/
#define LED1 10 /*-- Replace LED1 with 10 --*/
/*-- This will Return (0/1) the value of the bit number specified in the variable --*/
/*-- This is done by getting the current value of the VAR and AND'ing it with --*/
/*-- the value of 1 shifted to the left by the bit number.
EX: GETBIT(someVar,1)
Where someVar is originally 0x03 aka 0b00000011
Would Produce: 0x01
#define GETBIT(var,bit) (((var)>>(bit))&1)
/*-- This will SET (1) the value of the specified bit in the variable --*/
/*-- This is done by getting the current value of the VAR and OR'ing it with --*/
EX: SETBIT(someVar,2)
Would Produce: 0x07 aka 0b00000111
#define SETBIT(var,bit) ((var)|=(1<<(bit)))
/*-- This will Clear (0) the value of the specified bit in the variable --*/
/*-- the "opposite" (~) value of 1 shifted to the left by the bit number.
EX: CLRBIT(someVar,2)
Where someVar is originally 0x07 aka 0b00000111
Would Produce: 0x03 aka 0b00000011
#define CLRBIT(var,bit) ((var)&=(~(1<<(bit))))
/*-- Prototypes --*/
void Initialize(void);
int main(void);
/*-- Initialize is used to set the speed of the CPU and any other init. settings --*/
/*-- This can be named anything but Initialize is a standard --*/
void Initialize(void) {
PLL0CON=0x0; /*-- Disable the PLL --*/
PLL0FEED=0xAA; /*-- These 2 lines are the feed lines --*/
PLL0FEED=0x55; /*-- These are a REQUIRED part of the PLL SETUP --*/
VPBDIV=0x00; /*-- Setting peripheral Clock (pclk) to System Clock (cclk) --*/
/*-- Main is the program start. This is where you start it all --*/
int main(void){
int x; /*-- Local Variable. Using this one for local loops --*/
Initialize(); /*-- Call our Initialize Function/Prototype --*/
/*-- PINSELx is used to setup the pins usage. --*/
/*-- In the manual starting on page: 76 --*/
/*-- You will see for each pin in the PINSELx register there are 2 bits to set its purpose --*/
/*-- For example on page 76 you will see that pin ( P0.1 ) can be used for 4 different things --*/
00 = GPIO Port........ is general Input or Ouput Pin...On most if not all this is always 00
01 = RxD (UART0)...... is UART0 Recieve Data Pin
10 = PWM3............. is Pulse Width Modulation Pin #3
11 = EINT0............ is External Interrupt Pin #0
/*-- Knowing this you can easily set the bits in the register --*/
/*-- Since all we need for this lesson is to blink a LED then GPIO for all --*/
PINSEL0=0x00000000; /*-- Set all pins as GPIO pins --*/
/*-- IODIRx is used to setup the pins direction. Input/Output --*/
/*-- Page 83 refers to this as: --*/
8.4.1 GPIO port Direction register (IODIR, Port 0: IO0DIR - 0xE002 8008 and
Port 1: IO1DIR - 0xE002 8018; FIODIR, Port 0: FIO0DIR - 0x3FFF C000
and Port 1:FIO1DIR - 0x3FFF C020)
/*-- One of the cool things is that the header LPC214x.h lets you use IOxDIR or IODIRx --*/
/*-- Where x is the port aka 0 or 1 --*/
/*-- You can see how confusing it would be to use IO0DIR instead of IODIR0 hence the below code --*/
/*-- Note that when you set a 1 to any bit in this variable it sets the coresponding pin to output --*/
/*-- and when you set it to a 0 you can guess what will happen... its a input. --*/
IODIR0=0xFFFFFFFF; /*-- Set all pins as output pins --*/
/*-- Almost all programs have this while(1) loop. This is a endless loop. --*/
while(1){
SETBIT(IOPIN0,LED1); /*-- This will set the pin/bit LED1 (10) on IOPIN0 hence sending a 1 (HIGH) --*/
for(x=0;x<100000;x++); /*-- This is a loop for xxxx ticks. Its a rough count --*/
CLRBIT(IOPIN0,LED1); /*-- This will clear the pin/bit LED1 (10) on IOPIN0 hence sending a 0 (LOW) --*/
__________________ AtomSofts eBay Store AtomSoftTech: C18 TIPS & TRICKS v9 PDF Nokia 6100 Driver/Software My Name: Jason Lopez http://atomsofttech.info/ | My YouTube Videos! My Favorite Store: dipmicro Electronics Last edited by AtomSoft; 4th August 2009 at 08:33 AM. | |
| | #205 | |
I can't say that installing the processor support was all that difficult to figure out myself. The video tutorial is a good idea, but I'm not sure the subject matter is needed.
__________________ Mark Higgins | ||
| | #206 |
Ok cool. I wasnt sure about it at first. Its that when i first started i didnt know i had to install these packages and took me a day or so to figure out why i didnt have have anything in my New ProJect window ![]() Ill make a small PDF on it with the newer version.
| | #207 |
Here is the new code with my final understanding of loops... Code: /*--
Would Produce: 0x01
int main(void);
/*-- Initialize is used to set the speed of the CPU and any other init. settings--*/
int main(void){
while(1){
/*-- A for loop like: for(x=0;x<1;x++); with 1 takes approx 12 cycles to complete.............. --*/
/*-- A loop with 2 takes 25 Cycles know this we can calculate how long it will take for 500ms.. --*/
/*-- Since we are at 12 MHz thats 12,000,000 Cycles for 1 second. So it would take............. --*/
/*-- 6,000,000 cycles for 500mSaka 1/2 second delay and since the loop takes 12-13 cycles for 1 --*/
/*-- 6,000,000 / 12 = 500000..... So we will use 500000 for our loop........................... --*/
/*-- If you should need exact timing i suggest you create a delay function and make sure........--*/
/*-- that it is delaying 6,000,000 cycles. This will do about 4,500,009 cycles due to the.......--*/
/*-- compiler optimizing the code it will run the empty loop quicker ........--*/
/*-- You have to manually ajust the number. I found that 666666 would gibe me 6,000,003 cycles..--*/
for(x=0;x<666666;x++); /*-- This is a loop for 666666 cycles aka instructions. 500mS --*/
__________________ AtomSofts eBay Store AtomSoftTech: C18 TIPS & TRICKS v9 PDF Nokia 6100 Driver/Software My Name: Jason Lopez http://atomsofttech.info/ | My YouTube Videos! My Favorite Store: dipmicro Electronics Last edited by AtomSoft; 4th August 2009 at 10:09 AM. | |
| | #208 |
Here is my full source for the PIC version includes a altered linker file for 18f2525 and complete project ...
| | #209 |
I am in the process of working on getting Matt's connector setup working. I have the board and the clamp drilled. It looks like it will align and hold down as it should. To finish it I just need to align the toner mask and etch. It has been a while since we talked about this display. Any new developments. Has anyone had connection problems as the copper ages ? I wonder if one sprayed it with clear acrylic if the pins would poke through and make connection ? Has anyone put one in a case ? Matt's connection solution
| | #210 |
not yet on my side. Soon!! tho. Im making a order from dipMicro on friday for the toner paper and laminator. Ill make some PCBS and let them age and see how it goes. I have some blue acrylic ill test
| 96x64, controller, graphic, lcd, nokia7110, sed1565, w or |
| Graphic LCD | baberjaved | Micro Controllers | 2 | 13th November 2007 05:01 PM |
| Graphic LCD | flemmard | Micro Controllers | 1 | 13th September 2007 03:32 AM |
| interfacing of PIC16F877A with graphic LCD controller T6963c | rosamma | Micro Controllers | 1 | 24th March 2007 12:29 PM |
| graphic LCD PIC MCU | tom_electronic | Micro Controllers | 4 | 28th February 2006 12:29 PM |
| graphic lcd help | jijita | General Electronics Chat | 1 | 18th August 2004 07:32 AM |
