Old 5th July 2009, 10:44 PM   #166
darn ok cool thanks!
I guess eeprom or editing the linker is the only way to gain ram(SPACE)
AtomSoft is offline
Old 5th July 2009, 11:04 PM   #167
Can someone help me create a 800 byte buffer lol its for a 18F2525
This is my usage so far:
Graphic LCD 96x64 w/ SED1565 Controller-usage.jpg
AtomSoft is offline
Old 5th July 2009, 11:07 PM   #168
You can reflash pages within your program, same way you do with a boot loader or serial programmer, but that's really meant for permanent storing variables that you don't want lost in a power down.
If you want RAM, you can use SRAM rather than EEPROM, which is faster, but obviously you lose everything on power down.
Mark Higgins
DirtyLude is online now
Old 5th July 2009, 11:09 PM   #169
You just want a FIFO buffer? If you search 'ring buffer' and 'C library' and combinations, there's lots of example code for it out there.
Mark Higgins
Old 5th July 2009, 11:10 PM   #170
oh man i even forgot about the option for external ram lol thanks!
Any thoughts of internal (software) type fixes for now?
AtomSoft is offline
Old 5th July 2009, 11:11 PM   #171
I need it to store the entire screen. Like this dude did but on a ARM7. Its a pain in the butt for C18
AtomSoft is offline
Old 5th July 2009, 11:22 PM   #172
If you are getting the error
Error [1300] stack frame too large
A simple way to fix it is to make the variable global.
If you put it inside main or any other function it will allocate memory from the stack. If you make it global it does not.
Give it a try.
3v0
BCHS/3v0's Tutorials
3v0 is offline
Old 5th July 2009, 11:36 PM   #173
im getting this:
MPLINK 4.31, Linker
Copyright (c) 2009 Microchip Technology Inc.
Error - section '.udata_nokia7110.o' can not fit the section. Section '.udata_nokia7110.o' length=0x00000304
Errors    : 1
Im trying to create:
unsigned char ScreenBuff[770];
AtomSoft is offline
Old 5th July 2009, 11:37 PM   #174
You could make up a scheme to code everything. It's complex, but since there's mostly blank columns your buffer could be encoded sort of like RLE (run length encoding), but modified. I can envision what it would take, but it would be complicated to maintain. Your buffer would be dynamic and data would need to be moved around a lot. It would also mean that you couldn't have too much data on the screen or your buffer would have the potential to grow larger than a straight dedicated buffer.
Mark Higgins
Old 5th July 2009, 11:40 PM   #175
The only fix i know of is :
#pragma idata bigdata
#pragma idata
Linker Modification :
DATABANK   NAME=gpr10      START=0xA00          END=0xDFF	//END=0xAFF
//DATABANK   NAME=gpr11      START=0xB00          END=0xBFF
//DATABANK   NAME=gpr12      START=0xC00          END=0xCFF
//DATABANK   NAME=gpr13      START=0xD00          END=0xDFF
SECTION    NAME=bigdata    RAM=gpr10
AtomSoft is offline
Old 6th July 2009, 01:01 AM   #176
Thanks guys here are some of the functions i have working.
void LCDCircle(char top, char left, char radius);
void SetPixel(unsigned char top, unsigned char left);
void LCDRect(char x0, char y0, char width, char height);
void LCDImage(rom unsigned char *image,char left, char top);
void LCDLine(char top0, char left0, char top1, char left1);
void LCDChar(unsigned char letter,unsigned char font,unsigned char style,unsigned char top, unsigned char left);
void LCDString(rom unsigned char *str,unsigned char font,unsigned char style,unsigned char top, unsigned char left);
All working 100% so far. Will release in a week or so
AtomSoft is offline
Old 6th July 2009, 01:33 AM   #177
heh look :
Main Code:
#include <p18f2525.h>
#include "nokia7110.h"
#pragma config WDT = OFF, LVP = OFF, OSC = INTIO67, XINST = OFF
unsigned rom char foot[770] = { 96,64,
 0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,
 0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  128,  128,  128,  192,  192,  128,  128,  128,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,
 0,  0,  0,  0,  0,  0,  0,  0,  192,  224,  240,  240,  248,  248,  252,  252,  252,  252,  252,  248,  248,  240,  240,  224,  192,  128,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  128,  224,  240,  248,  252,  254,  255,  255,  255,  255,  255,  255,  255,  255,  255,  255,  252,  0,  0,  56,  124,  124,  252,  252,  252,  252,  252,  248,  248,  112,  0,  0,  0,  0,  0,  0,  0,
 0,  0,  0,  0,  0,  0,  0,  31,  255,  255,  255,  255,  255,  255,  255,  255,  255,  255,  255,  255,  255,  255,  255,  255,  255,  255,  255,  254,  254,  252,  248,  248,  240,  240,  224,  224,  192,  192,  192,  128,  128,  128,  128,  128,  128,  128,  128,  128,  192,  192,  224,  224,  240,  240,  248,  252,  254,  255,  255,  255,  255,  255,  255,  255,  255,  255,  255,  255,  255,  255,  255,  127,  31,  7,  3,  0,  0,  48,  112,  248,  248,  248,  240,  240,  97,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,
 0,  0,  0,  0,  0,  0,  0,  0,  0,  1,  3,  3,  7,  7,  15,  15,  15,  31,  31,  31,  31,  31,  31,  31,  31,  31,  31,  31,  31,  63,  63,  63,  63,  127,  127,  255,  255,  255,  255,  255,  255,  255,  255,  255,  255,  255,  255,  255,  255,  255,  255,  255,  255,  255,  255,  255,  255,  255,  255,  255,  255,  255,  255,  255,  255,  255,  255,  255,  255,  127,  15,  0,  128,  128,  196,  142,  158,  158,  30,  62,  30,  28,  8,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,
 0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  1,  1,  3,  3,  3,  7,  7,  7,  15,  15,  31,  31,  31,  63,  63,  63,  127,  127,  127,  127,  127,  127,  127,  127,  63,  63,  31,  31,  15,  3,  49,  112,  240,  240,  243,  227,  71,  7,  7,  7,  3,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,
void main(void);
void main(void){
    char a,b,c,d;
	OSCCON = 0x72;      			//8MHz clock
	while(!OSCCONbits.IOFS);		//wait for osc stable
	LCD_Init();
    ClearBuff();
	while(1){
	    CLS();
        LCDString((unsigned rom char*)"AtomSoftTech    ",0,None,0,0);
        LCDString((unsigned rom char*)"   .info        ",0,None,1,0);
        LCDString((unsigned rom char*)" Nokia 7110 LCD ",0,None,3,0);
        LCDString((unsigned rom char*)"Author:",1,Underline,5,0);
        LCDString((unsigned rom char*)"Jason Lopez     ",0,None,7,0);
        while(bitchk(LCD_PORT,BTN));
        Delay10KTCYx(10);
	    CLS();
	    LCDImage(foot,0,0);
        Delay10KTCYx(10);
	    CLS();
        for(d=0;d<8;d++){
            b=0;
            for(a=0;a<96;a++){
                SetPixel(b+(d*8),a);
                b++;
                if(b==8)b=0;
        SendBuff();
        ClearBuff();
        Delay10KTCYx(10);
	    CLS();
        LCDLine(5,10,5,80);
        SendBuff();
        ClearBuff();
        Delay10KTCYx(10);
	    CLS();
        LCDCircle(20,20,10);
        LCDCircle(30,30,10);
        LCDCircle(36,36,10);
        SendBuff();
        ClearBuff();
        Delay10KTCYx(10);
	    CLS();
        LCDRect(20,20,40,20);
        SendBuff();
        ClearBuff();
        Delay10KTCYx(10);
AtomSoft is offline
Old 6th July 2009, 11:42 AM   #178
Hey guys! look at what i just won on ebay:
Olimex LPC-P2148 Prototype Board LPC2148 ARM NXP USB/SD - eBay (item 250454529025 end time Jul-05-09 15:15:34 PDT)
$24 !!!!! omg i just payed now lol i saved about $53 ($77 at sparkfun) shipping was about same price as sparkfun too!
SparkFun Electronics - Prototyping Board for LPC2148
AtomSoft is offline
Old 6th July 2009, 03:29 PM   #179
New cube function:
void LCDCube(char Sq0T,char Sq0L,char Sq1T,char Sq1L,char width, char height) {
unsigned char x,y;
unsigned char a,b;
        x = Sq0L + width;
        y = Sq1L + width;
        a = Sq0T + height;
        b = Sq1T + height;
        LCDRect(Sq0T,Sq0L,width,height);
        LCDRect(Sq1T,Sq1L,width,height);
        LCDLine(Sq0T,Sq0L,Sq1T,Sq1L);
        LCDLine(Sq0T,x,Sq1T,y);
        LCDLine(a,Sq0L,b,Sq1L);
        LCDLine(a,x,b,y);
Testing:
AtomSoft is offline
Old 6th July 2009, 04:20 PM   #180
Is hidden line removal next ???
Just kidding. Great job, I am looking forward to using your code.
3v0
3v0 is offline
96x64, controller, graphic, lcd, nokia7110, sed1565, w or
Graphic LCD baberjaved Micro Controllers 2 13th November 2007 05:01 PM
Graphic LCD flemmard Micro Controllers 1 13th September 2007 03:32 AM
interfacing of PIC16F877A with graphic LCD controller T6963c rosamma Micro Controllers 1 24th March 2007 12:29 PM
graphic LCD PIC MCU tom_electronic Micro Controllers 4 28th February 2006 12:29 PM
graphic lcd help jijita General Electronics Chat 1 18th August 2004 07:32 AM
