+ Reply to Thread
Results 1 to 5 of 5
Thread: FIR/FFT/IIR on dsPIC
  1. #1
    krazy Newbie
    Join Date
    Apr 2009
    Posts
    50
    Default FIR/FFT/IIR on dsPIC
    Does *anyone* here have any experience with performing any kind of filtering on the dsPIC?
  2. #2
    kchriste Excellent kchriste Excellent kchriste Excellent kchriste Excellent kchriste Excellent kchriste Excellent kchriste Excellent kchriste Excellent kchriste Excellent
    Join Date
    Jul 2006
    Location
    Victoria BC, Canada
    Posts
    3,681
    Microchip has a DSP library that does all those functions. I've used their FFT routines with success. Haven't tried their FIR and IIR routines.
  3. #3
    krazy Newbie
    Join Date
    Apr 2009
    Posts
    50
    Do you have any sample code around that I could take a look at? I cannot get any filtering of anything going for the life of me.
  4. #4
    krazy Newbie
    Join Date
    Apr 2009
    Posts
    50
    Also, do you notice anything wrong here:
    C30 Madness Again...
    For some reason, it will not work and it is the most basic implementation of this.
  5. #5
    Join Date
    Jul 2006
    Location
    Victoria BC, Canada
    Posts
    3,681
    Here is some messy code I wrote that works with a GLCD. My original post on that topic is here:
    dsPIC + GLCD = Spectrum Analyzer :D
    #include <p33FJ64MC802.h>
    #include <dsp.h>
    #include "fft.h"
    #include "sqrtX.h"
    _FOSC(OSCIOFNC_ON & FCKSM_CSDCMD & POSCMD_NONE);	//Oscillator Configuration
    _FOSCSEL(FNOSC_FRC);								//Oscillator Selection
    _FWDT(FWDTEN_OFF);									//Turn off WatchDog Timer
    _FGS(GCP_OFF);										//Turn off code protect
    _FPOR( FPWRT_PWR1 );								//Turn off power up timer
    #define CS2		LATBbits.LATB12
    #define CS1		LATBbits.LATB11
    #define	DI		LATBbits.LATB10
    #define RW		LATBbits.LATB9
    #define E		LATBbits.LATB8
    #define LCD_RESETTING	PORTBbits.RB4
    void e_togg(void)
    	unsigned int x;
    	E = 1;
    	for( x=0; x<6; x++){;} //Delay apx 10us
    	E = 0;
    void cmd_write(unsigned char data)
    	unsigned int temp;
    	DI = 0;
    	RW = 0;
    	temp = LATB;
    	temp &= 0xff00;
    	temp |= data;
    	LATB = temp;
    	e_togg();
    void clearGLCD(void)
    	unsigned int page, y;
    	for( page=0xB8; page<0xC0; page++)
    		cmd_write(0x40);		//Set Y address to 0
    		cmd_write(page);		//Set pages 0-7
    			   //FEDCBA9876543210
    		LATB = 0b0001110000000000u;	//CS1,CS2 & DI=1	All others & data =0
    		for( y=0; y<64; y++)
    			{ e_togg(); }		//Clear byte
    void WaitTilReady(void)
    	unsigned int x;
    	TRISB = 0x00ff;
    	LATB = 0b0000101000000000u; // CS1 = 1; CS2 = 0; RW = 1; DI = 0;
    	for( x=0; x<72; x++){;} //Delay apx 100us
    	E = 1;
    	while((PORTB & 0x0090) != 0);
    	RW = 0;
    	E = 0;
    	CS1 = 0;
    	CS2 = 1;
    	RW = 1;
    	DI = 0;
    	E = 1;
    //	while(LCD_RESETTING);
    	RW = 0;
    	E = 0;
    	TRISB = 0x0000;
    unsigned char sqrtI( unsigned int sqrtArg )
    	unsigned char answer, x;
    	unsigned int temp;
    	if ( sqrtArg < 0x2 ) { return sqrtArg; }
    	answer = 0x00;
    	for( x=0x80; x>0; x>>=1 )
    		answer |= x;
    		temp = answer * answer;
    		if (temp > sqrtArg)
    			{ answer ^= x; }
    		if (temp == sqrtArg)
    			{ break; }
    	return answer;
    /* Global Definitions */
    unsigned int x,page,RevPage,temp,bin;
    unsigned int *TestPtr;
    fractcomplex sigCmpx[FFT_BLOCK_LENGTH] __attribute__ ((space(ymemory),far,aligned(FFT_BLOCK_LENGTH * 2 *2)));
    #ifndef FFTTWIDCOEFFS_IN_PROGMEM
    fractcomplex twiddleFactors[FFT_BLOCK_LENGTH/2] 	/* Declare Twiddle Factor array in X-space*/
    __attribute__ ((section (".xbss, bss, xmemory"), aligned (FFT_BLOCK_LENGTH*2)));
    #else
    extern const fractcomplex twiddleFactors[FFT_BLOCK_LENGTH/2]	/* Twiddle Factor array in Program memory */
    __attribute__ ((space(auto_psv), aligned (FFT_BLOCK_LENGTH*2)));
    #endif
    void initAdc1(void);
    int	peakFrequencyBin = 0;				/* Declare post-FFT variables to compute the */
    unsigned long peakFrequency = 0;			/* frequency of the largest spectral component */
    int main(void)
    	int i = 0;
    	fractional *p_real = &sigCmpx[0].real ;
    	fractcomplex *p_cmpx = &sigCmpx[0] ;
    	AD1PCFGL = 0xfffe;	//make ADC pins all digital except RA0
    	TRISA = 0x0001;			//Make all PORTs all outputs except AN0
    	TRISB = 0;
    	initAdc1();
    	WaitTilReady();
    	for ( x=0; x<3500; x++){;}
    	cmd_write(0x3f);		//turn on display
    	clearGLCD();
    	for ( i=0; i<256; i++)
    		{ x = sqrtX(i);}
    	x=0;
    		{ x = sqrtI(i);}
    	x=0;
    while(1){
    //	for ( x=0; x<35000; x++){;}
    #ifndef FFTTWIDCOEFFS_IN_PROGMEM					/* Generate TwiddleFactor Coefficients */
    	TwidFactorInit (LOG2_BLOCK_LENGTH, &twiddleFactors[0], 0);	/* We need to do this only once at start-up */
    #endif
    	for ( i = 0; i < FFT_BLOCK_LENGTH; i++ )/* The FFT function requires input data */
    	{					/* to be in the fractional fixed-point range [-0.5, +0.5]*/
    	LATBbits.LATB15 = 1; //ADC Sample flag 1.7uS
    		AD1CON1bits.DONE = 0;
    		AD1CON1bits.SAMP = 1; 		// start sampling then... after 31Tad go to conversion.
    		while (!AD1CON1bits.DONE);	// conversion done?
    	LATBbits.LATB15 = 0; //ADC Sample flag 200ms
    		sigCmpx[i].real = (signed)ADC1BUF0 >> 1;	/* So, we shift all data samples by 1 bit to the right. */
    		sigCmpx[i].imag = 0x0000;
    	/* Perform FFT operation */
    	FFTComplexIP (LOG2_BLOCK_LENGTH, &sigCmpx[0], &twiddleFactors[0], COEFFS_IN_DATA);
    #else
    	FFTComplexIP (LOG2_BLOCK_LENGTH, &sigCmpx[0], (fractcomplex *) __builtin_psvoffset(&twiddleFactors[0]), (int) __builtin_psvpage(&twiddleFactors[0]));
    #endif
    	/* Store output samples in bit-reversed order of their addresses */
    	BitReverseComplex (LOG2_BLOCK_LENGTH, &sigCmpx[0]);
    	/* Compute the square magnitude of the complex FFT output array so we have a Real output vetor */
    	SquareMagnitudeCplx(FFT_BLOCK_LENGTH, &sigCmpx[0], &sigCmpx[0].real);
    	/* Find the frequency Bin ( = index into the SigCmpx[] array) that has the largest energy*/
    	/* i.e., the largest spectral component */
    	VectorMax(FFT_BLOCK_LENGTH/2, &sigCmpx[0].real, &peakFrequencyBin);
    	/* Compute the frequency (in Hz) of the largest spectral component */
    	peakFrequency = peakFrequencyBin*(SAMPLING_RATE/FFT_BLOCK_LENGTH);
    	for( x=0; x<465; x++){;} //Delay apx 1ms
    	E = 0;
    	CS1 = 1;
    	CS2 = 1;
    	cmd_write(0xb8);		//go to page 0
    	DI = 1;
    	RW = 0;
    	LATBbits.LATB13 = 1; //Display write flag 150ms
    	TestPtr = (unsigned int *)&sigCmpx[0];
    	RevPage = 8;
    	for( page = 0xBF; page >= 0xB8; page-- )
    		CS1 = 1; CS2 = 0; cmd_write(page); cmd_write(0x40);
    		for( bin = 0; bin <= 127; bin++ )
    			if( bin == 64)
    				{ CS1 = 0; CS2 = 1; cmd_write(page); cmd_write(0x40); }
    			DI = 1; RW = 0;
    			if ( TestPtr[bin] > 0x0FFF ) { x = 0x0FFF; }
    			else { x = TestPtr[bin] << 3; }
     			if ( x > 0x0FFF ) { x = 0x0FFF; }
    			temp = sqrtI(x); //Calculate linear amplitude of frequency bin.
    //			temp = sqrtI(TestPtr[bin]); //Calculate linear amplitude of frequency bin.
    			if( temp >= RevPage )
    				{ LATB |= 0x00FF; } // Make 8 bit bargraph fully ON
    			else
    				temp = 255 << (RevPage-temp); // Convert to 8 bit bargraph
    				temp &= 0x00ff;
    				LATB &= 0xff00;
    				LATB |= temp;
    			e_togg();
    		RevPage += 8;
    	LATBbits.LATB13 = 0; //Display write flag 150ms
    	return 0;
    initAdc1() is used to configure A/D to convert channel 5 on Timer event.
    It generates event to DMA on every sample/convert sequence. ADC clock is configured at 625Khz
    void initAdc1(void)
    		AD1CON1 = 0x00E0; 			// SSRC bit = 111 implies internal counter ends sampling and starts converting.
    		AD1CON1bits.FORM   = 3;		// Data Output Format: Signed Fraction (Q15 format)
    		AD1CON1bits.AD12B  = 1;		// 12-bit ADC operation
    		AD1CON2 = 0;				// Converts CH0
    		AD1CON3bits.SAMC = 4;	 	// Sample time = 4Tad, Tad = internal 2Tcy
     		AD1CON3bits.ADRC=0;			// ADC Clock is derived from Systems Clock
    		AD1CON3bits.ADCS = 8;		// ADC Conversion Clock Tad=Tcy*(ADCS+1)= (1/7.37M)*64 = 8.7us (115Khz)
    									// ADC Conversion Time for 12-bit Tc=14*Tad = 22.4us
            AD1CHS0bits.CH0SA=0;		// MUXA +ve input selection (AN0) for CH0
    		AD1CHS0bits.CH0NA=0;		// MUXA -ve input selection (Vref-) for CH0
      		AD1PCFGL=0xFFFE;			// AN0 as Analog Input
            IFS0bits.AD1IF = 0;			// Clear the A/D interrupt flag bit
            IEC0bits.AD1IE = 0;			// Do Not Enable A/D interrupt
            AD1CON1bits.ADON = 1;		// Turn on the A/D converter
    Like I said the code is messy and contains redundant code such as two versions of square root for testing purposes. The twiddleFactors table comes with the MicroChip DSP library, so I won't include it here.
    Code for the assembler version of square root:
    ; sqrtX.s: Integer square root function.
    ; Input:
    ;       (w0) unsigned int x
    ; Output:
    ;       (w0) unsigned char square root of x
    ; Description:
    ;       Computes the square root of the argument x.
            .global _sqrtX
    _sqrtX:
     		cp		w0,#2
    		bra		geu, _domore
    		return
    _domore:
    		clr		w1				;answer reg
    		mov		#0x0080,w2		;loop reg x
    _sqrtLoop:
    		ior		w2,w1,w1		;answer |= x;
    		mul.uu	w1,w1,w4		;temp w4 = answer * answer;
    		cp		w0,w4			;if (temp w4 > sqrtArg)
    		bra		geu, _donext
    		xor		w2,w1,w1		;answer ^= x;
    _donext:
    		cp		w0,w4
    		bra		z, _quit		;if (temp w4 == sqrtArg)
    		lsr		w2,w2
    		bra		nz,_sqrtLoop
    _quit:
    		mov		w1,w0
            return                  ; Done
            .end
+ Reply to Thread
  1. DMA in dspic
    By Angy in forum Micro Controllers
    Latest: 21st April 2009, 06:19 PM
  2. PLL in DSPIC
    Latest: 21st April 2009, 06:11 PM
  3. Looking for a little help with dspic
    By jkmadsci in forum Micro Controllers
    Latest: 12th December 2008, 04:19 AM
  4. Need help with dsPIC ADC in/ PWM out
    By ag in forum Micro Controllers
    Latest: 5th November 2008, 05:02 AM
  5. dsPIC
    By Oznog in forum Micro Controllers
    Latest: 6th April 2006, 02:08 AM
Tags for this Thread
