Old 25th May 2004, 05:08 PM   (permalink)
Default MICROCHIPC bootloader - Can't download code into PIC16LF871
Hi all,
Since I can't understand what I am doing wrong I just want to check if anybody has any suggestions.
I have a PIC16LF871 with "01619 - bootldr-v26-16F870-71-16Mhz-19200bps.hex" programmed inside with the following configuration:
Oscillator:HS / Code Protect off / Fuses: WDT 0,PWRT 0,BODEN 0,LVP 0,CPD 1,WRT 1,DEBUGGER 1
In my board I am using a 16MHz crystal, MCLR is connected to VDD by 1K2 res and RB3 is connected to ground by another 1K2 res.
I am able to see the PIC oscillating signal with a scope.
In order to load the test code "_19160 - Test_16F87x_Serial_Port_19200baud_16Mhz.hex" I use the "PIC downloader 1.08" software.
It presents the message "searching for bootloader" and I can see some signals (don't know if the correct ones) in the RC7/RX pin, just after an ICL232 -RS232toTTL- converter.
Shouldn't something happen after I reset the PIC?
Do you see anything wrong in the PIC configuration?
Do you see anything wrong in my short schematic description?
Any ideas would be appreciated...
Thank you,
VSC
vamaro is offline
