I been trying to get a keypad to work on porta because I need portb for pwm. The reading of the keys work. But I've been trying to save how many keys was pressed and can't for the life of me get it to. What I'm trying to do
is count to see if key8 was pressed 4 times in a row. thanks for any help
Code:Device = 18F1220 Clock = 8 Config OSC = INTIO2 Config MCLRE = OFF Include "INTOSC8.bas" Dim counter As Word Dim key1 As Bit Dim key2 As Bit Dim key3 As Bit Dim key4 As Bit Dim key5 As Bit Dim key6 As Bit Dim key7 As Bit Dim key8 As Bit Dim key9 As Bit Dim key10 As Bit Dim key11 As Bit Dim key12 As Bit Dim col1 As PORTA.0 Dim col2 As PORTA.1 Dim col3 As PORTA.2 Dim roll1 As PORTA.3 Dim roll2 As PORTA.4 Dim roll3 As PORTA.6 Dim roll4 As PORTA.7 Dim out0 As PORTB.0 Dim out1 As PORTB.1 SetAllDigital Input (roll1) Input (roll2) Input (roll3) Input (roll4) Output (col1) Output (col2) Output (col3) Output (PORTB.1) Output (PORTB.0) counter = 0 While true High (col1) Low (col2) Low (col3) // col 1 this scans keys If col1 = 1 And col2 =0 And col3 = 0 And roll1 = 1 Then key1 = 1 Else key1 =0 EndIf High (col1) Low (col2) Low (col3) If col1 = 1 And col2 =0 And col3 = 0 And roll2 = 1 Then key2 = 1 Else key2 = 0 EndIf High (col1) Low (col2) Low (col3) If col1 = 1 And col2 =0 And col3 = 0 And roll3 = 1 Then key3 = 1 Else key3 = 0 EndIf High (col1) Low (col2) Low (col3) If col1 = 1 And col2 =0 And col3 = 0 And roll4 = 1 Then key4 = 1 Else key4 = 0 EndIf Low (col1) High (col2) Low (col3) // col 2 If col2 = 1 And col1 =0 And col3 = 0 And roll1 = 1 Then key5 = 1 Else key5 = 0 EndIf Low (col1) High (col2) Low (col3) If col2 = 1 And col1 =0 And col3 = 0 And roll2 = 1 Then key6 = 1 Else key6 = 0 EndIf Low (col1) High (col2) Low (col3) If col2 = 1 And col1 =0 And col3 = 0 And roll3 = 1 Then key7 = 1 Else key7 =0 EndIf Low (col1) High (col2) Low (col3) If col2 = 1 And col1 = 0 And col3 = 0 And roll4 = 1 Then key8 = 1 Else key8 = 0 EndIf Low (col1) Low(col2) High (col3) // col 3 If col3 = 1 And col1 =0 And col1 = 0 And roll1 = 1 Then key9 = 1 Else key9 = 0 EndIf Low (col1) Low (col2) High (col3) If col3 = 1 And col2 =0 And col1 = 0 And roll2 = 1 Then key10 = 1 Else key10 = 0 EndIf Low (col1) Low (col2) High (col3) If col3 = 1 And col2 =0 And col1 = 0 And roll3 = 1 Then key11 = 1 Else key11 = 0 EndIf Low (col1) Low (col2) High (col3) If col3 = 1 And col2 =0 And col1 = 0 And roll4 = 1 Then key12 = 1 Else key12 = 0 EndIf Low (out1) Low (out0) If key8 = 1 Then // lights a led if key8 is pressed Toggle (out0) // EndIf If key8 = 1 And out0 = 1 And counter < 0 Then // this is what I can't get to work Inc (counter) // the counter dosn't change value EndIf If counter = 4 Then // should hit 4 and turn on the led High (out1) EndIf Wend![]()
