hi people, here is my problem: y do mathematic operations y binary (microcontrollers code) but i need to print the result in an LCD. I kown that having a BCD code plus 0x30 is equal to ASCII, but i don't know how to convert binary code to BCD (i know it in paper, but no in assembler way)..... can you help me please????
This routine is copied from the piclist and modified a bit - Takes a 8 bit binairy value in BinDisplay and coverts it to BCD into Val1, Val2 and Val3 If you need a 16 bit routine then go to nigels tutorials (www.winpicprog.cu.uk) and look at the LCD tutor, it has a 16bit routine Code: Bin2BCD
CLRF Val1
SWAPF BinDisplay, W ;w = A0*16+A1
ADDWF BinDisplay, W ;w = A0+A1
ANDLW b'00001111' ;w = A0+A1 % 16
SKPNDC ;if A0+A1 > 16
ADDLW 0x16 ; w += 16
SKPNDC ;if w % 16 > 10
ADDLW 0x06 ; w += 6
ADDLW 0x06 ;w += 6
SKPDC ;if w < 10
ADDLW -0x06 ; w -= 6
BTFSC BinDisplay,4
ADDLW 0x16 - 1 + 0x6
SKPDC
ADDLW -0x06
BTFSC BinDisplay, 5
ADDLW 0x30
BTFSC BinDisplay, 6
ADDLW 0x60
BTFSC BinDisplay, 7
ADDLW 0x20
ADDLW 0x60
RLF Val1, F
BTFSS Val1, 0
ADDLW -0x60
MOVWF Val3
BTFSC BinDisplay, 7
INCF Val1, F
SWAPF Val3, W
ANDLW b'00001111'
MOVWF Val2
MOVLW b'00001111'
ANDWF Val3, F
RETURN
For my LCD purposes, I use the follow code to convert Hex to Dec. I am sure others may be more optimized, but this is just my own example. Code: HEX_TO_DEC
;CONVERTERING HEX TO DEC.
CLRF HUNDREDS
CLRF TENS
CLRF ONES
CHECK_H
MOVF HEXNUM, W
MOVWF TEMP
MOVLW 0X64
SUBWF TEMP, F
BTFSS STATUS, C
BTFSC STATUS, Z
GOTO $ + 2
GOTO CHECK_T
INCF HUNDREDS, F
MOVF TEMP, W
MOVWF HEXNUM
GOTO CHECK_H
CHECK_T
MOVF HEXNUM, W
MOVWF TEMP
MOVLW 0X0A
SUBWF TEMP, F
BTFSS STATUS, C
BTFSC STATUS, Z
GOTO $ + 2
GOTO CHECK_O
INCF TENS, F
MOVF TEMP, W
MOVWF HEXNUM
GOTO CHECK_T
CHECK_O
MOVF HEXNUM, W
MOVWF TEMP
MOVLW 0X01
SUBWF TEMP, F
BTFSS STATUS, C
BTFSC STATUS, Z
GOTO $ + 2
GOTO ENDHEXDEC
INCF ONES, F
MOVF TEMP, W
MOVWF HEXNUM
GOTO CHECK_O
ENDHEXDEC
RETURN
Here is for 16 bits. I hope this does not exceed a single posting limit. Shut, the bottom half of the display is misbehaving. Code: ;---------------------------------------
;PREREQUISITE: LOADF HIGH_BYTE
; LOADF LOW_BYTE
HEX_TO_DEC
;0X2710=10,OOO, 0X3E8=1,000, 0X64=100, 0X0A=10, 0X01=1
;0X270F = 9999
MOVF_F LOW_BYTE, TEMP_LOW
CLRF THOUSANDS
CLRF HUNDREDS
CLRF TENS
CLRF ONES
CHECK_H
MOVF_F TEMP_LOW, TEMP
MOVLW .100
SUBWF TEMP, F
BTFSC STATUS, C
GOTO $ + 2
GOTO CHECK_T
INCF HUNDREDS, F
MOVF_F TEMP, TEMP_LOW
GOTO CHECK_H
CHECK_T MOVF_F TEMP_LOW, TEMP
MOVLW .10
SUBWF TEMP, F
BTFSC STATUS, C
GOTO $ + 2
GOTO CHECK_O
INCF TENS, F
GOTO CHECK_T
CHECK_O MOVF_F TEMP_LOW, TEMP
MOVLW .1
SUBWF TEMP, F
BTFSC STATUS, C
GOTO $ + 2
GOTO HEXDEC2
INCF ONES, F
GOTO CHECK_O
HEXDEC2
HI_0 BTFSC HIGH_BYTE, 0
GOTO $ + 2
GOTO HI_1
MOVLW .2
ADDWF HUNDREDS, F
MOVLW .5
ADDWF TENS, F
MOVLW .6
ADDWF ONES, F
HI_1 BTFSC HIGH_BYTE, 1
GOTO $ + 2
GOTO HI_2
MOVLW .5
ADDWF HUNDREDS, F
MOVLW .1
ADDWF TENS, F
MOVLW .2
ADDWF ONES, F
HI_2 BTFSC HIGH_BYTE, 2
GOTO $ + 2
GOTO HI_3
MOVLW .1
ADDWF THOUSANDS, F
MOVLW .2
ADDWF TENS, F
MOVLW .4
ADDWF ONES, F
HI_3 BTFSC HIGH_BYTE, 3
GOTO $ + 2
GOTO HI_4
MOVLW .2
ADDWF THOUSANDS, F
MOVLW .4
ADDWF TENS, F
MOVLW .8
ADDWF ONES, F
HI_4 BTFSC HIGH_BYTE, 4
GOTO $ + 2
GOTO HI_5
MOVLW .4
ADDWF THOUSANDS, F
MOVLW .9
ADDWF TENS, F
MOVLW .6
ADDWF ONES, F
HI_5 BTFSC HIGH_BYTE, 5
GOTO $ + 2
GOTO ENDBITSUM
MOVLW .8
ADDWF THOUSANDS, F
MOVLW .1
ADDWF HUNDREDS, F
MOVLW .9
ADDWF TENS, F
MOVLW .2
ADDWF ONES, F
ENDBITSUM
;PROCESS OVERFLOW
ONES_OVER
MOVLW .9
SUBWF ONES, W
BTFSC STATUS, Z
GOTO TENS_OVER
BTFSS STATUS, C
GOTO TENS_OVER
INCF TENS, F
MOVLW .10
SUBWF ONES, F
TENS_OVER
MOVLW .9
SUBWF TENS, W
BTFSC STATUS, Z
GOTO HUNDREDS_OVER
BTFSS STATUS, C
GOTO HUNDREDS_OVER
INCF HUNDREDS, F
MOVLW .10
SUBWF TENS, F
HUNDREDS_OVER
MOVLW .9
SUBWF HUNDREDS, W
BTFSC STATUS, Z
GOTO ENDHEX_TO_DEC
BTFSS STATUS, C
GOTO ENDHEX_TO_DEC
INCF THOUSANDS, F
MOVLW .10
SUBWF HUNDREDS, F
ENDHEX_TO_DEC
RETURN
Here is an 8-bit routine that I use on the enhanced core 18F series of PICs. It can very easily be adapted to handle 16 bit numbers. The value being converted is stored in "convertbuf." The converted value is stored in "decl, decm, dech". Code: ;************************************* ; This function takes an 8 bit hex * ; value and converts it into 3 ASCII * ; values for display purposes * ;************************************* hextodec clrf decl clrf decm clrf dech loop100 movlw D'100' ; Check to see if value is 100 or greater cpfslt convertbuf, 1 ; if 100 or higher bra 100 handler bra handler100 ; otherwise check the 10s loop10 movlw D'10' ; Check to see if value is 10 or greater cpfslt convertbuf, 1 ; if 10 or higer bra 10 handler bra handler10 movff convertbuf, decl ; otherwise move remainder to 1s bra makeascii ; and then make into ASCII handler100 incf dech, 1, 1 ; increment dech, store in dech, banked movlw D'100' ; subtract 100 from subwf convertbuf, 1, 1 ; convertbuf, store it convertbuf, banked bra loop100 ; start process over again handler10 incf decm, 1, 1 ; increment decm, store in decm, banked movlw D'10' ; subtract 10 from subwf convertbuf, 1, 1 ; convertbuf, store in convertbuf, banked bra loop10 makeascii movlw 0x30 ; Add 30h to: (Adding 30h converts hex to ASCII) addwf decl, 1, 1 ; decl - stored in decl - banked addwf decm, 1, 1 ; decm - stored in decm - banked addwf dech, 1, 1 ; dech - stored in dech - banked return -Bill | |
well thanks a lot to all people who answer my question, i think i must be more clearly.... so here it is, my number is only an 8 bit number, but i need to print in the lcd 4 digits. the idea is to make a stepper motor controller using pic 16f877 with keypad and lcd, so the degrees go from 0 º to 360º, but because of the motor resolution (0.9 º) i'm supposed to print decimal values, but i do not know how to do it so i am printing dDEG, i mean instead of printing 360 DEG i will print 3600 dDEG, instead of pirnting 1,8 DEG i will print 18 dDEG, got the idea????????, so as you saw 3600 is a 4 digit number, so i will be more thanfull if you have a routin that converts a number to a 4 digit ASCII code, or maybe you can explain how to do it, so i will do the asm code, the problem is that i have no idea how toi do it!!!!!!!! thanks a lot | |
| | #6 |
If you are only using a byte to store the angle, then I assume that: 0º = 0 360º = 256 Is that your internal representation of the motor position? If so then your internal precision is actually 1.40625º, not 0.9. So what will happen is that in some cases a single increment of your internal value will result in two steps of the motor. In other words it will be impossible to put the motor into every position it can physically achieve, if that will be an issue. If you are still going to use a byte to represent the motor position, then you could simply use tables to store the preculcated ASCII representations of the position. You have 256 values times 4 characters. However your value will only be from 0 to 9, so you can pack 2 characters into a single byte. So you would need 512 bytes for the table. Just put one value (0 to 9) in the low nibble and the other in the high nibble. To extract the ascii value mask (ANDF) the byte by 0x0f, then add d'48' to convert it to ASCII. Then swap the nibbles (SWAPF) and do the mask / add again to get the second character. Dan East | |
| | #7 |
yeah now i realized, you are right, well, as i wrote before, i do not konw to handle decimal values, so instead of printing 360 GED in the LCD i'll print 3600 dDEG. and now the problem is that the nember entered must be stored in 2 registers, and then, after multiplying, substracting, adding, etc etc, i must convert the binary number (2 registers) into 4 BDC digits and then adding 0x30 i finally will obtain ASCII code. thank you Dan East. by the case, did somebody know how to operate a number of 2 bytes??? now my problem has increased..... help is needed, the operations i must do are: multiplication (16 bits X 8 bits) substraction(16 bits - 16 bits) convertion from binary to BCD (16 bits to 4 BCD digits) thans a lot people. | |
| | #8 | |
http://www.piclist.com | ||
| ascii, binary, code, converting, number |
