Hi All ; I Want To Program This Circuit And I Want To Use Pic16f877 Not Pic 16f84 So ... See The Schematic ... And Reply Me Please Thanks | |
What do want help with?
battary monitor .. how to do that , and if you see the schematic you see that only analog is battary
Do you have the source code for the 16F84?
#;---------------------------------------------------- ; UPS.ASM ; Program for Blaster Control Board (INTROMARIN-C). ;---------------------------------------------------- LIST p=16F84 ; PIC16F84 is the target processor #include p16f84.inc ;#define PROC16C71 ; variables definition ; ًهمèًٌٍû T EQU 10H ; ٌ÷هٍ÷èê ïهًèîنà ىàêٌ=200 LEN EQU 11H ; نëèٍ. àêٍèâي. ٌîٌٍîےيèے ىàêٌ=100 PP EQU 12H ; ٌ÷هٍ÷èê ïîëَïهًèîنà BAT EQU 13H ; ïًèçيàê ًàلîٍû îٍ لàٍàًهé FRONT EQU 14H ; ïًèçيàê ïهًهنيهمî ôًîيٍà ٌèيًُîيèçàِèè SIN_OK EQU 15H ; ïًèçيàê ٌèيًُîيèçàِèè SHORT EQU 16H ; êًàٍêîâًهىهييûé لَôهً FLAG_F EQU 17H ; ôëàم ôًîيٍà ٌèيًُîيèçàِèè PWcnt EQU 18H ; ٌ÷هٍ÷èê نëèٍ. ٌهٍهâîمî ïèٍàيèے SINcnt EQU 19H ; ٌ÷هٍ÷èê ïهًèîنà ٌهٍهâîمî ïèٍàيèے t EQU 20H ; âيًٍَهييèé ٌ÷هٍ÷èê ïهًèîنà BATime EQU 21H ; time EQU 22H ; ٌ÷هٍ÷èê 20ىٌ ىàêٌ=5.12ٌهê zumm EQU 23H ; ïًèçيàê âêë÷هيèے çَىىهًà ; êîيٌٍàيٍû period EQU .165 ; ïهًèîن len EQU .80 ; لèٍû ïîًٍà A OS EQU 2 ; âُîن خر ïًهîلًàçîâàٍهëے LOWBAT EQU 3 ; âُîن LOW BATTERY ; EQU 4 ; âُîن ; لèٍû ïîًٍà B SINH EQU 0 ; âُîن ٌèيًُîيèçàِèè PWGOOD EQU 1 ; âُîن POWER_GOOD ; EQU 2 ; âûُîن RELAY EQU 3 ; âûُîن َïًàâëهيèه ًهëه BASE0 EQU 4 ; âûُîن لàçà ًٍàيçèٌٍîًà BASE1 EQU 5 ; âûُîن لàçà ًٍàيçèٌٍîًà ; EQU 6 ; âûُîن ZUMM EQU 7 ; âûُîن çَىىهً GOTO Start ;------------------------------------------; ; MAIN ; ;------------------------------------------; ORG 200 ; حà÷àëüيûه ٌٍَàيîâêè Start: ; حà÷àëüيûه ٌٍَàيîâêè ; Initialize PORTA by BCF STATUS, RP0 CLRF PORTA BSF STATUS, RP0 MOVLW 0x1f ; Set RA0-RA4 as inputs MOVWF TRISA #ifdef PROC16C71 MOVLW 0x00 ; Set RA0-RA4 as analog MOVWF ADCON1 #endif ; Initialize PORTB by BCF STATUS, RP0 CLRF PORTB BSF STATUS, RP0 MOVLW 0x03 ; Set RB0,Rb1 as inputs, all other as output MOVWF TRISB ; TIMER INTERRUPT ENABLE BSF STATUS, RP0 MOVLW 0xA0 MOVWF INTCON ; SET_TIMER BSF STATUS, RP0 ; çàïًîمًàىىèًîâàٍü ٍàéىهً ; NEW !!!! WDT movlw 0x58 movwf OPTION_REG ; èٌٍî÷يèê âيًٍَهييèé, ; ïîنêë÷èٍü نهëèٍهëü ê WDT, ; êîôôèِèهيٍ نهëèٍهëے 1 ; NEW !!! WDT BCF STATUS, RP0 BCF INTCON, T0IF ; ٌلًîٌèٍü ôëàم ;MOVF period ; MOVLW period MOVWF TMR0 ; PRESET REGISTERS BCF STATUS, RP0 MOVLW .199 MOVWF T MOVLW .80 MOVWF LEN BSF BAT, 0 CLRF FRONT CLRF BATime CLRF time CLRF zumm ; رàىîٍهٌٍèًîâàيèه ;BCF PORTB, 3 ;CALL ZUMM ;CALL ZUMM ;CALL ZUMM ;BSF PORTB, 3 ; خئبؤہحبإ دذإذغآہحبك GOTO $ ;------------------------------------------; ; خلًàلîٍêà ïًهًûâàيèé ; ;------------------------------------------; ORG 4 ;__interrupt{ ;------------------------------__SET_TIMER ------------------ BCF STATUS, RP0 btfss TMR0, 0 ; êîًًهêِèے goto $+1 BCF INTCON, T0IF ; ٌلًîٌèٍü ôëàم MOVLW period ; êàê êîيٌٍàيٍَ MOVWF TMR0 ;------------------------------------------------------------- INCF T, 1 ; حہذہظبآہحبإ ر×إز×بتہ دإذبخؤہ MOVF T, 0 SUBLW .199 BTFSS STATUS, C CLRF T ; رءذخر ر×إز×بتہ دإذبخؤہ ;------------------------------------------------------------- INCF t, 1 MOVF T, 1 ; رءذخر آحسزذإححإأخ ر×. دإذبخؤہ BTFSC STATUS, Z CLRF t ;------------------------------------------------------------- clrwdt ; !!!! NEW WDT !!!! ;------------------------------------------------------------- ;__if(t==0)||(t==99) { PP++ MOVF t, 0 SUBLW .0 BTFSS STATUS, Z GOTO INT1 CLRF PP ; رءذخر دذباحہتہ دخثسدإذبخؤہ MOVLW len ; دإذإسرزہحخآتہ LEN MOVWF LEN GOTO INT2 INT1: MOVF t, 0 SUBLW .99 BTFSS STATUS, Z GOTO INT2 BSF PP, 0 ; سرزہحخآتہ دذباحہتہ دخثسدإذبخؤہ MOVLW len ; دإذإسرزہحخآتہ LEN MOVWF LEN INT2: MOVF LEN, 1 ; ؤإتذإجإحز LEN BTFSS STATUS, Z DECF LEN, 1 ;__} ;******************* دذبحكزبإ ذإطإحبة ************************ ;-------------------------- دإذإصخؤ حہ ءہزہذإب --------------- BTFSC PORTB, PWGOOD GOTO POWER BSF BAT, 0 CLRF PWcnt CLRF SIN_OK POWER: ;-------------------------- دإذإصخؤ حہ رإزـ ------------------ BTFSS PORTB, PWGOOD GOTO DESIGN BTFSS PWcnt, 7 GOTO DESIGN BTFSS SIN_OK, 0 GOTO DESIGN CLRF BAT DESIGN: ;************************************************* ************ ;-------------------------- آتثق×بزـ ذإثإ -------------------- BTFSC BAT, 0 BCF PORTB, RELAY BTFSS BAT, 0 BSF PORTB, RELAY ;-------------------------- سدذہآثإحبإ زذہحابرزخذہجب ------- ;__if(BAT==1){ BTFSS BAT, 0 GOTO INT4 ;__if(LEN!=0){ MOVF LEN, 1 BTFSC STATUS, Z GOTO INT4 ;__if(PP==0){ BTFSC PP, 0 GOTO INT3 BSF PORTB, BASE0 BCF PORTB, BASE1 GOTO INT5 INT3: BCF PORTB, BASE0 BSF PORTB, BASE1 GOTO INT5 ;__} ;__} ;__else{} INT4: BCF PORTB, BASE0 BCF PORTB, BASE1 INT5: ;__} ;------------------------- ربأحہث دذب دذخدہؤہحبب رإزب -------- MOVF t, 0 BTFSS STATUS, Z GOTO Z1 INCF time, 1 INCF BATime, 1 BTFSC BAT, 0 GOTO Z2 CLRF BATime BCF zumm, 0 GOTO Z1 Z2: MOVF BATime, 0 ; if(BATime>64) BATime=64 SUBLW .255 BTFSS STATUS, Z GOTO $+5 MOVLW .254 MOVWF BATime BCF zumm, 0 GOTO $+2 BSF zumm, 0 ; آتثق×بزـ اسججإذ Z1: ;------------------------- اسججإذ ---------------------------- BTFSS zumm, 0 GOTO NOZUMM BTFSS time, 5 GOTO NOZUMM BTFSC t, 1 BSF PORTB, 7 BTFSS t, 1 NOZUMM: BCF PORTB, 7 ;------------- دذخآإذتہ حہثب×بك رإزإآخأخ حہدذكئإحبك ---------- ; if(T==0){ MOVF T, 0 BTFSS STATUS, Z GOTO NO_PW ; if(!PWGOOD) { BTFSS PORTB, PWGOOD CLRF PWcnt ;} INCF PWcnt, 1 ; if(PWcnt>128) PWcnt=128 { MOVF PWcnt, 0 SUBLW .128 BTFSC STATUS, C GOTO $+3 MOVLW .128 MOVWF PWcnt ;} ; } NO_PW: ;-------------------------- ربحصذخحباہضبك دخ شہاإ ---------- ; if(رإزإآخإ حہدذكئإحبإ){ BTFSS PWcnt, 7 GOTO NO_SIN ; } INCF SINcnt, 1 ;_if(نëèيà èىï. > 0.5 ىٌ){ BTFSS PORTB, SINH CLRF FRONT INCF FRONT, 1 MOVF FRONT, 0 SUBLW .5 BTFSS STATUS, Z GOTO INT6 ;_ôًîيٍ îليàًَوهي ; ïًîâهًêà ïهًèîنà ٌهٍهâîمî يàïًےوهيèے MOVF SINcnt, 0 MOVWF SHORT CLRF SINcnt SUBLW .195 ; >195 BTFSC STATUS, C GOTO NO_SIN MOVF SHORT, 0 SUBLW .205 ; >205 BTFSS STATUS, C GOTO NO_SIN ; رخءرزآإححخ ربحصذخحباہضبك MOVF T, 0 SUBLW .5 BTFSC STATUS, C GOTO SIN1 MOVF T, 0 SUBLW .194 BTFSS STATUS, C GOTO SIN1 MOVF T, 0 ADDLW 3 MOVWF T GOTO NO_SIN SIN1: MOVLW .199 MOVWF T BSF SIN_OK, 0 GOTO $+2 NO_SIN: CLRF SIN_OK ;__} INT6: RETFIE ;__} END # | |
| | #6 |
Why would you want to change it to a 16F877? A 16F628 would be a better match. Also use code tags and it would be helpful if the comments were in English.
| | #7 |
ok .. can you explain the last code ?? thanks for your replies | |
| | #8 |
| hi Bill, I think youv'e opened Pandora's box.
__________________ Eric " Good enough is Perfect " I will NOT answer PM's requesting technical help, please use the Forum PIC tutorials: Nigel's www.winpicprog.co.uk/ Bill's: www.blueroomelectronics.com/ | |
| | #9 |
ok .. thanks
| | #10 |
I like the Code: BTFSS PWcnt, 7 GOTO NO_SIN | |
| program |
| MP Lab Program Help | bamafan54 | Micro Controllers | 5 | 7th January 2009 03:16 PM |
| "Program verify failed at program address 0x000, progra | Jimmy Vivas | Micro Controllers | 17 | 25th July 2008 02:36 AM |
| what exactly does Program Verify Error at Program Address 0x000 mean | Gaston | Micro Controllers | 5 | 24th December 2006 07:17 PM |
| new to program | kudanhema | Datasheet/Parts Requests | 1 | 22nd March 2005 04:59 PM |
| schematic & program to program pic 16f84a plz | mafiaaa | Micro Controllers | 2 | 27th November 2004 05:00 PM |
