Hi all,
I've been using the 16F628 for some time now, writing code and compiling with PBP and using a Tait style parallel programmer with P16PRO. The latest batch of Pic's I have been supplied with are 16F628A - I/P, I have updated the Device.ini on P16PRO but I cannot program the PIC, I can program an existing 16F628 I have no problem but when I try to program the 16F628A -I/P I get the same error number every time right at the start of trying to program. Does anyone have any ideas as to my problem? Thanks Jim |
Nigel,
Thanks for the reply, So if I purchase a different programmer and use lets say Winpicprog this will work? If so what Programmer would you recomend, I'm not a large volume programmer, maybe 4 or 5 pics a week is all. Regards, Jim |
I must first clear the PIC 16F628A when I use the basic parallel port programmer and the old DOS N.O.P.P.P program. N.O.P.P.P. has been working fine for all my F84, F84A, F627, and F628A chips.
What I dislike is how finding the difference between 628 and 628A is proving to be difficult. Microchip's site is sorely slow, the .pdf for --->628A migration is not listed, but the migration for --->84A is listed yet the link returns a page not found. |
Hi Nigel,
Thanks for all your help, OK I have now found 2 Windows based programs that will work in XP and program the 16F628A-I/P successfully using my Tait 7406-PNP style programmer. They are :- IC-Prog from http://www.ic-prog.com/ Oshon from http://www.oshonsoft.com/picprog.html Both do not have the 16F628A listed but selecting the 16F628 works OK with both. Would be very interested when you get Winpicprog to support the 16F628 as I like your software. Regards, Jim |
I have a programmer that I built specifically to program my 16F84A and 16F628A chips. It works with WinPic800 V 3.59 and PICPgm V 1.0.1.2 and may work with other programs as well. It is detected as a JDM programmer. It is a erial programmer and works like a charm. Has not had it fail on me yet.
Hope this helps. Dan |
Perhaps you might try considering the date the thread was posted?, over three years ago!.
Sorry I didn't look at the date. My BAD!
Doesn't sound like you want advice from new people on the board. I won't try and help anyone any more! |
