| Experienced Member | hi, i have been experimenting on pic over a few days already. everthing works 100% over the mplab simulator (6.5). i am burning the chip using jdm programmer and ic-prog version 1.05. btw, my chip is 16f84a. everthing works 100% in the simulator, however, things don't go well in hardware. i am trying to spin 2 stepper motors using port b (one nibble each). the stepping works perfectly in rb0, rb1, rb2, and rb3. while there is absolutely no stepping action in rb4, rb5, rb6, and rb67. :shock: the logic probe pulses on the low nibble, while it stays high on the high nibble. i made another program to test if portb is damaged. unfortunately, every pin of portb is fully functional. i don't know what on earth is wrong with the program i made because it works the way i wanted it to be in the simulator, but it never works on hardware.... :evil: |
| Experienced Member | Can we see the program please?
__________________ Dave Pusey. PIC Programming Tutorials: http://www.mstracey.btinternet.co.uk...al/picmain.htm Brilliant PIC Simulator: http://www.oshonsoft.com/pic.html |
| Experienced Member | :cry: Calm down!! They are designed by mchip to make you pull your hair out!! :wink: Ok, make sure that the TRIS registers are correct i.e. B'00000000' not B'11110000' also pics can "lock up" if you give them too much abuse, is the pic directly conected to the stepper motor? What is the load on the pins.... Like Dave said, show us the code, we can help (no warrenty implied etc :roll: )
__________________ Regards MATT! |
| Experienced Member | ok... here is the code: Code: list p=16f84a #include <P16F84A.INC> __CONFIG _WDT_OFF & _PWRTE_OFF & _CP_OFF & _XT_OSC ; *** Setup the constants *** ISR_ADDR equ 0004h ; ISR address TMR0_RELOAD equ b'00000000' ; Reload value of Timer 0 LEFT_MOTOR equ 0Fh ; Location of current step of left motor RIGHT_MOTOR equ 10h ; Location of current step of right motor COUNTER1 equ 11h ; First counter for delay COUNTER2 equ 12h ; Second counter for delay ; *** Macros *** bank0 macro ; Select memory Bank 0 bcf STATUS, RP0 endm bank1 macro ; Select memory Bank 1 bsf STATUS, RP0 endm ; *** Begin program execution org 0000h goto Main ; *** Interrupt Service Routine org ISR_ADDR bcf INTCON, T0IF ; Clear Timer 0 overflow flag decfsz COUNTER1, 1 goto End_ISR call Forward ; Call subroutine to go forward End_ISR call Reset_TMR0 ; Reset Timer 0 call Move_Motors retfie ; *** Subroutines Reset_TMR0 movlw TMR0_RELOAD movwf TMR0 return Turn_Right bcf STATUS, C ; Clear Carry flag rrf LEFT_MOTOR, 1 ; Create a single step for left motor btfsc STATUS, C ; Is C set? bsf LEFT_MOTOR, 3 ; Yes, set bit 3 of LEFT_MOTOR bcf STATUS, C ; Clear Carry flag return Turn_Left bcf STATUS, C ; Clear Carry flag rlf RIGHT_MOTOR, 1 ; Create a single step for right motor btfsc STATUS, C ; Is C set? bsf RIGHT_MOTOR, 4 ; Yes, set bit 4 of RIGHT_MOTOR bcf STATUS, C ; Clear Carry flag return Forward call Turn_Right call Turn_Left return Move_Motors movf RIGHT_MOTOR, 0 ; Place current step of left motor in W iorwf LEFT_MOTOR, 0 ; OR W with the current step of right motor movwf PORTB ; Move the current step to Port B return ; *** Main Program *** Main call Reset_TMR0 ; Setup stepper motor movements bsf LEFT_MOTOR, 3 ; Set initial step for left motor bsf RIGHT_MOTOR, 4 ; Set intitial step for right motor ; Setup I/O ports bank1 movlw 00h ; Set W register to zero movwf TRISB ; and Port B to be an output port bank0 ; Setup interrupts bsf INTCON, T0IE ; Setup Timer 0 overflow interrupt bsf INTCON, GIE ; Enable occurrence of interrupts ; Setup Timer 0 interrupt to respond to internal clock bank1 bcf OPTION_REG, T0CS ; Timer 0 Clock source is internal clock bank0 This goto This end |
| Experienced Member | The simulator defaults by initializing all file registers to zero. In reality, the file registers can assume a random value on power-up. Your software assumes that the values of LEFT_MOTOR and RIGHT_MOTOR are initially zero. If they are intialized to a non-zero value, that value will recirculate and you will get odd signals out of portb. For example, let's assume LEFT_MOTOR were initialized to 0xFF. As soon as the ff instruction are executed, the succeeding bit3 will be set. Code: btfsc STATUS, C ; Is C set?
bsf LEFT_MOTOR, 3 ; Yes, set bit 3 of LEFT_MOTOR Code: Main call Reset_TMR0
clrf LEFT_MOTOR
clrf RIGHT_MOTOR
__________________ "Having to do with Motion Control" |
| Experienced Member | great! that did the trick... 8) so this means that the gpr does not have a reset state of all 0's... am i right? |
| Super Moderator | Quote:
| Experienced Member | Quote:
As a follow-up, I would recommend to change your code as follows: Code: Turn_Right bcf STATUS, C ; Clear Carry flag
btfsc STATUS, Z ; Test for zero
return
return
__________________ "Having to do with Motion Control" | |
