Hello everyone. I have a small 5V relay connected to a PIC via a ULN2803 driver. I have the diode on the 2803 tied to VCC to serve as a flyback diode, and it appears to be working properly. I'm switching 16VAC with the relay's contacts, which are connected to a small motor. The motor pulls about 60mA. The relay's contacts are not tied to the board's VCC or GND in any way - only to the motor and the AC source. When the relay switches I get a significant amount of noise on VCC and throughout the circuit board. So much noise at times that the PIC actually resets. I'm really at a lost where all the noise is coming from - I would not expect so much induced noise on VCC just by turning a small motor on and off. If I remove the load, the problem goes away. In the interest of full disclosure, the contact traces on the PCB do not cross VCC in anyway. I do have a ground plane on the bottom side of the board and the trace for the AC source lines is on the back side. Any suggestions? Do I need a snubber on the relay contacts to kill the noise? If so, any suggestions on R/C values? Any help or constructive suggestions would be greatly appreciated. Thanks. -Tom | |
Put a capacitor on the relay a 104 should do it. And make sure you have 1 on the pic from vdd to ground I have had to add a 10uf to my pic because of the motor
Put the RC snubber across the motor, right at the motor. Make R the same value as, or slightly smaller than, the resistance of the motor windings. Try a 1uF non-polarized cap for C. A scope would help you select the right value for C.
__________________ Inside every little problem, is a big problem trying to get out. | |
The cap of value about 100 uF at the MCLR pin is very importnat. Micro chip themselves reccomends this which I have wondered Y. May be this is Y. Good LUCk.
Thanks for the suggestions everyone. Using parts on hand (94Ω/.1µF) I put in a snubber circuit and it did limit some of the noise, but it is not perfect yet. Once I get more accurate parts, I'll see if it gets better. Thanks again.
| causing, noise, relay, suggestions |
| Simple relay circuit getting noise spike form AC line | creichard | General Electronics Chat | 26 | 10th August 2009 09:28 AM |
| Any suggestions for a digital ready random noise circuit? | blueroomelectronics | Electronic Projects Design/Ideas/Reviews | 17 | 13th June 2008 11:19 AM |
| LCD backlight causing problems | MrMikey83 | Micro Controllers | 6 | 6th February 2005 11:12 PM |
| Relay making a whining noise | batman | Electronic Projects Design/Ideas/Reviews | 3 | 8th October 2004 01:33 PM |
| Fan causing electrical noise in AMP circuit - help plz | rudi | Electronic Projects Design/Ideas/Reviews | 3 | 26th May 2004 05:38 PM |
