+ Reply to Thread
Page 3 of 4
First 1 2 3 4 Last
Results 31 to 45 of 53
Thread: how to detect Ac
  1. #31
    shingadaddy Newbie
    Join Date
    Jan 2009
    Location
    Central USA
    Posts
    88
    Forward makes sense. And after all it IS a diode and is blocking the current on one direction and doesn't have to work too hard at it since the reverse leakage current is probably enough that the resistor is soaking up / limiting the effective reverse voltage to a possibly tolerable level. Resistor only takes a beating - er a - heating at 50% duty cycle and at a halfasine duration only.
    At first it does It does conjure up an instant vision of :
    vvvfffvvvFFFRAP---POP--- sizzzzzzle.
    Hence, my signature phrase
    The most popular Engineering test phrase... WHAT WAS THAT!!!
  2. #32
    KMoffett Excellent KMoffett Excellent KMoffett Excellent KMoffett Excellent KMoffett Excellent
    Join Date
    Oct 2007
    Location
    Minneapolis MN USA
    Posts
    1,386
    Quote Originally Posted by shingadaddy View Post
    Take a look at any discrete LED spec sheet. "Absolute Maximum" Vrev=5V. (Ok I did find one that had Vr=9V) The Irev at Vrev is usually 100ľA. So using your concept: 10K x 100ľA would drop 1.0V across the resistor. That leaves 119V (actually 169Vpeak) reverse voltage across the LED.
    Still doesn't make sense.
    Ken
  3. #33
    shingadaddy Newbie
    Join Date
    Jan 2009
    Location
    Central USA
    Posts
    88
    LED - 10K 1/2 watt resistor and a suicide cord and you have the test set.
    Give it a whirl.
    Thats why I wanted the LED part number so I could check to see if its one with a built in resistor and a non-typical voltage rating.
    FLASH! Maybe its one of those fancy smancy LED's that actually have 2 diodes on the die. One in each direction.
  4. #34
    Join Date
    Oct 2007
    Location
    Minneapolis MN USA
    Posts
    1,386
    If it had a built-in diode, with its polarity opposite the LED, it would work. I don't recall seeing ever seeing one like that. But then, I haven't seen everything...yet.
    Ken
  5. #35
    Join Date
    Oct 2007
    Location
    Minneapolis MN USA
    Posts
    1,386
    OK I did a bench test. But, no way I'm going to do the 120VAC/resistor/LED trick.
    Normal forward bias connection of a red LED with a current-limited power supply: Vf=1.9v@If=20mA
    Reverse Connection: Ir=~0 mA @ Vr <24V. As Vr was increased above 25V, Ir rapidly increased to 30mA. The LED was getting hot!
    A combination of the 10K resistor limiting the reverse current to 12mA (120v/10K) would keep the LED from going Poof. But this cannot be doing the LED any good in the long run. A single diode, connect with opposite polarity across the LED would make the LED operate within its specified limits.
    be80be,
    Do you have any examples of this configuration used in commercial, or hobby, devices?
    Ken
  6. #36
    be80be Excellent be80be Excellent be80be Excellent be80be Excellent be80be Excellent be80be Excellent
    Join Date
    Aug 2008
    Location
    morristown,tn
    Posts
    2,000
    I'm done with the Led and 120 volt's now i don't no what you tired a diode blocks half of the 120 volts because it's AC so it only using 60 volts now the led will not burn up because I limited the Current to about 6mA. So it can't be getting hot. It's the current that burns the led out and most any small diode can handle 120 volts at less then 20 mA. And a led is a diode. Oh by the way if you have not seen them They are selling light bulbs with led in them $35.00 each lol and the one's I put in couldn't have more then a resistor and some led's in it. Oh what I showed you was real a cord plugged in to the wall outlet with a led hooked to a 10k resistor and and hooked to the cord and plugged in to the AC 120 volts
    LED; Red, T- 1 3/4 (5mm); Super Brite, 6.3 mcd, Diffused Lens
    $0.12 (Each) that's what it is
    __________________________________________________ __
    Linux help by be80be
  7. #37
    shingadaddy Newbie
    Join Date
    Jan 2009
    Location
    Central USA
    Posts
    88
    The double direction (or dislecsic) diode is a " you can't get it backwards" design and glowage is ensured no matter which way it gets stuck in the circuit.
    Ken I figured you tried the 120 volt test and that was what brought the electro-tech website down around 4ish central time today. I didn't hear a big bang though
  8. #38
    curadebt_complaints Newbie
    Join Date
    Mar 2009
    Posts
    5
    Yes, there are devices which can detect so you should check electronic stores online and offline.
  9. #39
    Join Date
    Aug 2008
    Location
    morristown,tn
    Posts
    2,000
    lol It just a plain red led like you get from radio shack. no tricks It just works. Here there using a 6 watt lamp for the resistor Ultra-simple Voltage Probe - RED - Page25
    Just remember that this non-linear relationship between voltage and current means that Ohm's Law doesn't work for LEDs.
    Burt
  10. #40
    Join Date
    Oct 2007
    Location
    Minneapolis MN USA
    Posts
    1,386
    Thanks!
    Ken
  11. #41
    umer27 Good umer27 Good
    Join Date
    Mar 2009
    Location
    Pakistan
    Posts
    53
    before I shoot myself for reading all posts on this topic...
    here is your solution, Buy an AC relay ... like the OMRON MY2 or MY4 ... it has a switching time of 20 ms.. so its pretty quick.. hope you know how, a relay works.. and if your using a u controller, how to properly use the signal..
    PS.. i really deserve getting an upgrade in Reputation for this post ! (see, Im a good boy now.. )
  12. #42
    4um Addict Mike2545 Excellent Mike2545 Excellent Mike2545 Excellent Mike2545 Excellent Mike2545 Excellent Mike2545 Excellent Mike2545 Excellent
    Join Date
    Jan 2009
    Location
    Toledo, Ohio
    Posts
    838
    Yes, a relay will work in this instance.
    Sometimes size is a concederation and relays/sockets may be larger than acceptable.
    Relays are also mechanical, some designs may call for solid state.
    Cost may also be an issue, relays and sockets run around $5-$7 for the set, the components I listed will be around $1.
    Wiring may also be a constraint on design, with relays, switched power needs to be wired, where the design I posted supply the power (2 wires vs 4)
    Don't beat yourself up too bad for reading the whole thread.
    Mike 2545
  13. #43
    Join Date
    Oct 2007
    Location
    Minneapolis MN USA
    Posts
    1,386
    Quote Originally Posted by mike2545 View Post
    Y
    Are you implying that there was just toooooo much discussion?
    ken
  14. #44
    Join Date
    Jan 2009
    Location
    Toledo, Ohio
    Posts
    838
    Quote Originally Posted by KMoffett View Post
    ken
    Not at all, just that umer27 seemed a little exasperated, and I didn't want him to be that extreme, shooting himself and all.
    Mike 2545
  15. #45
    shingadaddy Newbie
    Join Date
    Jan 2009
    Location
    Central USA
    Posts
    88
    I was going to suggest an optocoupler but...Meh
+ Reply to Thread
Page 3 of 4
First 1 2 3 4 Last
  1. Caller Id detect.
    By goodpickles in forum Electronic Projects Design/Ideas/Reviews
    Latest: 13th August 2008, 03:04 AM
  2. how to detect the voltage?
    By nabilhattaz in forum Micro Controllers
    Latest: 23rd January 2008, 04:37 AM
  3. How do you detect ground?
    By AceOfHearts in forum Robotics Chat
    Latest: 24th August 2007, 10:43 AM
  4. how to detect GSM THROUGH PIC
    By saran in forum Electronic Projects Design/Ideas/Reviews
    Latest: 7th December 2006, 11:34 AM
  5. How do you detect CO2?
    By William At MyBlueRoom in forum General Electronics Chat
    Latest: 23rd June 2006, 07:13 PM
Tags for this Thread
