| if i use 2 pics.. is it then possible that one programs the other reading his hex from a FDD..??? TKS | |
You can certainly program one PIC with another, that's how the PicStart+ works - but it gets it's data from the PC serial port. | ||
| but isn't it possible to read 1 byte.. write that byte in the pic.. write it to the other pic read the next byte etc.. ??? wy you need memory..?? TKS i don't care if the process is 5minutes or 25.. and how big is a good program in hex..??? 50Kb..??? 50000steps..should be done. if every step takes 20Ms.. then it will take 12 minutes to program.. ok.. maybe i have to think about using a flash card.. or simply build a quik change cpu maner.. but sending pics over the world..is not a system.. i prefer let the cust download a hex and put it on a flop and do it them self.. TKS..... i agree that when you miss read a byt you are gone..whit my system. | |
| What you need is a microcontroller with code space for a bootloader. uC with this capability can write to their own flash memory while execuing code in a special section of the flash that can be read while writing the rest of flash. Most 8051s have this capability I don't know about PICs though. Bootloaders let you use almost any interface (RS232, ethernet, etc) to reprogram the main program. You can send users updated code through the internet and they can download it into your product with their computer. Brent | |
As 'bmcculla' mentioned, a botloader system could work fairly easily for you, various PIC's are bootloader capable - including the 16F876/7 series. All you need is a serial connection to a PC. | ||
| Interesting. Now you've got me thinking about how that could work. The bigger PICs do have 1k of RAM space, capable of buffering the 512 byte chunk as long as you can do everything else you wanted with half the RAM already taken. I wonder, could you format it so that you only use say the first 128 bytes of each chunk and just forget about the rest? Or would the storage format need to use the entire chunk? I saw some recommendations that an I2C EEPROM or a parallel EEPROM be used to hold the 512 byte chunk. Here's some stuff I saw about interfacing with an MMC or CF card. I saw bootloading off the card mentioned. http://www.compsys1.com/workbench/Be...o/mmc_i_o.html http://www.compsys1.com/workbench/On...c_project.html http://barrymichels.com/ide/ | |
| i think it could be work whit a floppy as well.. because who will be the slowest factor..??? i think that whit a serial eeprom.. it has to be able to read a hex from a fdd and to write it in a EEPROM MEM.. and then finally write the eeprom ram into another chip..?? maybe i2c isn't fast.. but it will work.. how fast is i2c.??? TKS | |
| A PIC alone won't be able to read from an FDD. You would need a floppy disk controller (FDC) to read a standard 512 byte sector. Stand alone FDC chips are getting harder to obtain. This alone will eliminate any cost advantage a FDD may have. You may have to forego using DOS format for storage. There is not enough memory to decode a DOS directory, FAT, etc. even if you could read a 512 byte sector.
__________________ "Having to do with Motion Control" | |
| ok.. i have forgotten the FDD idea.. because i'm got a new idea... i'm gonna do it whit a CF card.. these are easyer to read and faster and cheap... atleast they don't need much power.. and don't have moving parts.. soow i'm gonna try that out..!! also i'm gonna try to acces a HDD>.. any one has already done that succesfully..?? i'm gonna make a new topic for it..for better atention.. TKS | |
| TKS, you might look here, http://www.compsys1.com/workbench/ :wink: | |
| ok will take a look @ it... | |
