Hi everybody:
I'm having troubles trying to communicate a f628a and a DS1820 using the internal pic oscillator @ 48kHz, 3.3V. Communication between them @ 4MHz is successful , but @ 48kHz is not.
My question is : is this possible (communication @ 48kHz)?, or am I doing something wrong?
this is the modificated part (taken from the very usual code)
Code:;****************************************************************** ;* * ;* Dallas/Maxim DS18B20 Temperature Sensor Routines * ;* * ;****************************************************************** OW_HIZ:MACRO bsf STATUS,RP0 ; bank 1 bsf TRISA,DQ ; set DQ pin as HiZ input bcf STATUS,RP0 ; bank 0 ENDM ; OW_LO:MACRO bcf STATUS,RP0 ; Select Bank 0 of data memory bcf PORTA, DQ ; Clear the DQ bit bsf STATUS,RP0 ; Select Bank 1 of data memory bcf TRISA, DQ ; Make DQ pin an output bcf STATUS,RP0 ; Select Bank 0 of data memory ENDM ; WAIT:MACRO TIME ; movlw (TIME/5)-1 ; 1 µsec call WAIT5U ; 2 µsec ENDM WAIT5U nop ; 1 µsec addlw -1 ; 1 µsec bnz WAIT5U ; 3µsec or 2µsec return ; 2 µsec OW_RESET OW_HIZ clrf PDByte OW_LO ;WAIT .500 nop nop nop nop nop nop OW_HIZ ; ;WAIT .70 ; nop btfss PORTA,DQ ; incf PDByte,F ; ;WAIT .430 ; nop nop nop nop nop return ; ; ; RX byte ; DSRXBYTE movlw .8 ; movwf Count ; set bit counter DSRXLP OW_LO ; bring DQ low for 6 usecs nop ;nop ;nop ;nop ;nop ;nop OW_HIZ ; change to HiZ and wait 4 usecs nop ;nop ;nop ;nop movf PORTA,W ; read DQ andlw 1<<DQ ; mask off the DQ bit addlw .255 ; C=1 if DQ=1: C=0 if DQ=0 rrf IOByte,F ; Shift C into IOBYTE ;WAIT .50 ; Wait 50µs to end of time slot nop decfsz Count,F ; Decrement the bit counter goto DSRXLP ; movf IOByte,W ; return ; ; ; TX byte ; DSTXBYTE movwf IOByte ; we send it from IOBYTE movlw .8 ; movwf Count ; set bit counter DSTXLP OW_LO ; drive the line low for 3us nop ;nop ;nop rrf IOByte,F bsf STATUS,RP0 ; bank 1 btfsc STATUS,C ; test LSB of IOBYTE for 1 or 0 bsf PORTA,DQ ; HiZ the line if bit is 1 bcf STATUS,RP0 ; bank 0 ;WAIT .60 ; continue driving line for 60µs nop OW_HIZ ; release the line for pullup nop ;nop ; recovery time of 2µs decfsz Count,F ; decrement the bit counter goto DSTXLP return ; ;****************************************************************** ; ; get temperature reading ; GetTemp call OW_RESET ; send reset signal btfss PDByte,0 ; DS18B20 found? return ; no, return, else movlw h'CC' call DSTXBYTE ; send 'skip rom' command movlw h'44' call DSTXBYTE ; start temperature conversion ReadSlot ;WAIT .60 ; wait 60-usecs nop OW_LO ; start new read slot OW_HIZ nop ;nop ;nop ;nop ;nop btfss PORTA,DQ ; conversion complete '1'? goto ReadSlot ; no, do another slot, else ;WAIT .60 ; finish read slot period nop GetResult call OW_RESET ; send reset signal movlw h'CC' call DSTXBYTE ; send 'skip rom' command movlw h'BE' call DSTXBYTE ; send 'read scratchpad' command call DSRXBYTE movwf TempL ; save temperature lo call DSRXBYTE movwf TempH ; save temperature hi bcf STATUS,C rrf TempL,f ; eliminate "decimal" place return
Thanks in advace for your comments![]()
