Old 5th February 2009, 04:00 AM   #1
Default Problem using LCD on PortA and PortE with MiKroC
Every thing works OK when I'm using Proteus with but in the reality when I make my circuit nothing appears on the LCD I'm using PIC18F4550 und LMB162A LCD my Cristal is 8MHZ
I think the problem is by using PortA or PortE when I use PortB or PortD every thing is OK.
Thank You all
This is my Code:
char *text = "Hello World";
void main()
  CMCON |= 0x07;             // turn off comparators
  ADCON1 |= 0x0F;           // turn off analog inputs
  TRISA = 0x00;
  TRISE = 0x00;                        // PORTB is output
  TRISB = 0x00;
  Lcd_Custom_Config(&PORTA,3,2,1,0,&PORTE,2,1,0);  // Initialize LCD on PORTB
  Lcd_Custom_Cmd(Lcd_CURSOR_OFF);           // Turn off cursor
  Lcd_Custom_Cmd(LCD_CLEAR);
  Lcd_Custom_Out(1, 1, text);
  PORTB.F2 = 1;
  while(1)
    Delay_ms(250);  // One second pause
    Lcd_Custom_Cmd(LCD_SHIFT_RIGHT);
    PORTB.F2 = ~PORTB.F2;
This is my circuit:
Nizar is offline
Old 5th February 2009, 10:28 AM   #2
Lightbulb
pull up all data lines d4-d7 with 4.7k resistor to 5v.
yatoof is offline
Old 5th February 2009, 02:56 PM   #3
change this
to this
  CMCON = 7;             // turn off comparators
  ADCON1 = 0x0F;           // turn off analog inputs
and see what happen
Steve
mister_e is offline
Old 5th February 2009, 04:07 PM   #4
Default Thanks, I will try it
I think this is the problem
Thank You very much
Nizar is offline
Old 6th February 2009, 02:58 AM   #5
Thank You very much
ROKE2009 is offline
Old 7th February 2009, 07:01 AM   #6
Default Sorry It doesn't work
I put putt-up res. but I get nothing.
So, when do LED test on PortA and PortE (without putt-up res.)I get sometning unblieveable: LEDs RA0 and RA1 blink but RA2 and RA3 light without blinking.
On PortE, I get RE0 and RE1 blinked but RE2 does nothing.
But the programm works good on Proteus
This is the Code:
//CPU Clock 48MHZ
//PIC18F4550
void main()
  CMCON = 0x07;             // turn off comparators
  ADCON1 = 0xFF;           // turn off analog inputs
  TRISA = 0x00;               // PORTA is output
  TRISE = 0x00;                // PORTE is output
  PORTA = 0xFF;
  PORTE = 0xFF;
  while(1)
    Delay_ms(500);          /* 0.5 second pause */
    PORTA = ~PORTA;
    PORTE = ~PORTE;
Circuit on Proteus:
Nizar is offline
Old 7th February 2009, 07:11 AM   #7
Try changing all your port reads to latch reads,
so
PORTA = ~PORTA;
becomes
LATA = ~LATA;
Pommie is online now
Old 8th February 2009, 04:49 AM   #8
Default Thank You all
I got it due to Your help:
The Problem is that I used PORT instead of LAT
So, thanks for your help special Pommie.
The New code:
void main()
  TRISB = 0x00;                         // PORTB is output
  Lcd_Custom_Config(&LATA,3,2,1,0,&LATE,2,1,0);  // Initialize LCD on PORTB
  Lcd_Custom_Out(1, 16, text);
  PORTB.F2 = 1;
  while(1)
    Delay_ms(300);               // 0.3 second pause
    Lcd_Custom_Cmd(LCD_SHIFT_LEFT);
    PORTB.F2 = ~LATB.F2;
Nizar is offline
Old 4th June 2009, 08:38 PM   #9
I just wanted to say thankyou for the LAT/PORT hint.
I have been troubleshooting this issue for two long evening/nights now looking for soft and hard errors.... !
thankyou / Ahd71
ahd71 is offline
Old 15th November 2009, 02:09 AM   #10
Thanks it is working.
kalindusri is offline
lcd, mikroc, porta, porte, problem
Interrupt on change problem, PORTA mjdeez Micro Controllers 7 11th June 2009 01:58 AM
MikroC Delay_ms() problem!!! cGr Micro Controllers 2 7th November 2008 12:49 PM
mikroC problem colin mac Micro Controllers 12 22nd July 2008 01:02 PM
PORTA output problem skyrock Micro Controllers 2 13th May 2008 11:47 AM
Problem in PORTE register of PIC Hesam Kamalan Micro Controllers 2 11th July 2006 12:51 PM
