I'm planning to do PWM and Timer2 with USB feature using PIC18F4550 with crystal of 20MHz.
What I intend to do is to have both PWM and Timer2 interrupt running on 20MHz as in FOSC = 20 MHz.
Attached is the print screen of my settings in configuration bits.
To test whether the code is running at 20MHz or not, i program a simple code to blink the LED ON for 1 second and then OFF for another second and i measure its time by using stopwatch. What i found is the code is running slower compared to the stopwatch.
Below is how i did the blinking code. I put it in a while loop so that the PIC will do nothing else except blinking the LED.
The reason why i did the above testing is to ensure that the PIC is indeed running at 20MHz so that when I do PWM and Timer2, I can use FOSC = 20MHz for the calculation. However, it seems that the PIC is running abit slower than 20MHz and because of that, I'm afraid when I do the PWM and Timer2, the result will be off.. Can somebody pls advice..Code:// I'm using 20MHz crystal oscillator. void main(void) { InitializeSystem(); while(1) { USBTasks(); // USB Tasks ProcessIO(); // See user\user.c & .h while (1) { PORTD = 0xFF; Delay10KTCYx(200); Delay10KTCYx(200); Delay10KTCYx(100); PORTD = 0x00; Delay10KTCYx(200); Delay10KTCYx(200); Delay10KTCYx(100); } }//end while }//end main
Thanks.
