I was actually playing around with IR not that long ago, and customized one of the Swordfish (a PIC Basic compiler) UART libraries to modulate the signal for infrared data transmission, the results were great.
Like most compilers, SF has its own software UART routines, but when modified to turn on/off a 38Khz PWM signal instead of making a pin high/low, the result looks like this;
And what does that look like? Well its now modulated UART ready to control an infrared LED to transmit the data!!
How do you go about recieving the signal? The use of a "logic output" IR reciever makes life easy. It will provide a logic high (5V) should a 38Khz signal be detected. You have now successfully demodulated the IR encoded UART data!
It was as if two PIC's were connected by a wire and UART data was being sent from one to another, but of course they can be many many meters away (my hall way is 17 meters and I did not get any errors - it would even work around corners and into other rooms because of the high intensity IR Leds I was using)
Transmit Program:
Device = 18F2550
Clock = 8
Config FOSC = INTOSCIO_EC
Include "INTOSC8.bas"
Include "PWM.bas"
Include "IR_UART.bas"
Dim Variable As Byte
// start of main program
PWM.SetFreq(38000)
PWM.SetDuty1(50)
PWM.Start1
IR_UART.SetTX(PORTC.2)
IR_UART.SetMode(umTrue)
IR_UART.SetBaudrate(sbr300)
Variable = 0
Low(PORTC.0)
While True
Inc(Variable)
IR_UART.Write(Variable)
DelayMS(500)
Wend
Receiver Program:
Device = 18F2550
Clock = 8
#option LCD_DATA = PORTB.4
#option LCD_RS = PORTB.0
#option LCD_EN = PORTB.1
Include "convert.bas"
Include "lcd.bas"
IR_UART.SetRX(PORTC.2)
DelayMS(150)
LCD.Cls
LCD.WriteAt(1,1,"IR UART")
While True
IR_UART.Read(Variable)
LCD.WriteAt(2,1,Convert.DecToStr(Variable,3))
Wend
Of course a lot more information can be found here Spencys digital-diy 18F PIC micro - Infrared IR Modulated UART
Might help you out on the IR side of things, manipulating PWM is extremely easy as well, consider Spency's digital-diy 18F PIC micro Tutorial - PWM
