+ Reply to Thread
Page 1 of 2
1 2 Last
Results 1 to 15 of 21
Thread: Does anyone else hate the pickit1 board as much as me?
  1. #1
    kyussinchains Newbie
    Join Date
    Jan 2009
    Posts
    8
    Default Does anyone else hate the pickit1 board as much as me?
    I'm a total novice when it comes to embedded programming, I've been playing around with C for years, but never consistently, it seems I have to re-learn it all each time I come around to using it....
    I've been given a microchip pickit1 flash starter kit with a pic12f675 onboard and I'm banging my head on a wall trying to make a single LED flash.... I can make two flash at once, but isolating a single one seems beyond me at the moment!
    my problem is that the LEDs on the demo board are wired in a tri-state configuration and I don't seem to be able to set the pins in a high Z configuration. I'm using pin 3 to source the current for the LED, pin 2 to sink it, and setting pins 5 and 6 to input mode (High Z I believe)
    my code is below:
    #include <htc.h>
    __CONFIG(UNPROTECT & BORDIS & MCLRDIS & PWRTEN & WDTDIS & INTIO);
    void main()
    	unsigned int i;
    	TRISIO = 0b000011; //set GPIO0-3 as inputs, high Z
    	ANSEL = 0x00; //clear ansel register
    	CMCON = 0x07; //disable comparator
    	while (1){ //loop continuously
    		GPIO4 = 1; //set pin 3 high, LED on
    		GPIO5 = 0; //set pin 2 low
    		for(i = 0; i < 10000; ++i)
    			// do nothing, busy wait loop
    		GPIO4 = 0; //set pin 3 low, LED off
    can anyone suggest why it's switching two LEDs on instead of a single one?
    oh and I'm using MPLAB 8.10 and HI-TIDE 9.60
    thanks in advance!
  2. #2
    Help us help you blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent
    Join Date
    Jan 2007
    Location
    Toronto, Canada
    Posts
    10,709
    Blog Entries
    5
    The LEDs are Charlieplexed on the PK1, download JPUG#1 from my site as it has a couple of articles on Charlipexing LEDs.
    Bill
    Smart Kits build Smart People
  3. #3
    3v0
    3v0 is online now
    3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent
    Join Date
    Jul 2006
    Location
    USA
    Posts
    6,464
    Blog Entries
    11
    Looks like the schematic at
    http://www2.dgb.ch/users/soe/Informa...tUserGuide.pdf
    Your code should light LED DO only. Which are lighting ? You can tell the state and value for each of you IO bits by looking at the schematic and knowing which LEDs are conducting/on. If D0 and D2 are on RA2 is a low output rather then an input. If DO and D10 are on RA1 is a low output rather then an input etc.
    You can also use a logic probe or volt meter to check that you can configure GPIO bits as you expect them.
    After a quick look I did not see a problem with thecode.
    It should NOT make a difference but try 0b00000011 as the value for TRISIO.
    Is the board new or is it possible it has been modified.
    At the very least tell us what LEDs are on. It will help soft out any software to hardware mapping problem.
    BCHS/3v0's Tutorials
  4. #4
    Join Date
    Jan 2009
    Posts
    8
    my apologies, I should have said which LEDs are on!
    the two that are on are D0 (the one I'm trying to light) and D2, I'll try the change to the TRISIO value out and let you know if it works after the weekend
    The board isn't new, but as far as I can tell it's not been modified
    thanks for the replies!
  5. #5
    be80be Excellent be80be Excellent be80be Excellent be80be Excellent be80be Excellent be80be Excellent
    Join Date
    Aug 2008
    Location
    morristown,tn
    Posts
    2,000
    should be
    		GPIO5= 0; //set pin 2 low
    that should turn on D0
    and turn off weak pullups
  6. #6
    3v0
    3v0 is online now
    Join Date
    Jul 2006
    Location
    USA
    Posts
    6,464
    Blog Entries
    11
    If D0 and D2 are on RA2 is a low output rather then an input. That is to say RA2 is providing a path to ground for LED D2.
    The datasheet says weak pullups are active on power up and other resets. --11 -111 RA2 would need to be a low ouput to light D2, this should not be a problem. You could set WPU = 0x00 to be paranoid safe.
    There are times when things that should not be problems are. Either due to misunderstanding or some quirk. For that reason the paranoid but safe way is best.
    As I see it you need to figure out how RA2 is providing a path to ground D2
    HTH
  7. #7
    Join Date
    Aug 2008
    Location
    morristown,tn
    Posts
    2,000
    0b000011
    Should be 0b001111
    if not RA2 will sink for led D2
  8. #8
    3v0
    3v0 is online now
    Join Date
    Jul 2006
    Location
    USA
    Posts
    6,464
    Blog Entries
    11
    Bits are numbered 0 1 2 3 4 5 6 7
    You need to trisate bits 1 and 2 which can be done with
    TRISIO=0x000110
    but instead you are doing
    TRISIO=0x000011
    which tristates bits RA0 and RA1 instead of RA1 and RA2.
    It fits. We have all made this mistake
    3v0
    Last edited by 3v0; 23rd January 2009 at 07:09 PM. Reason: changed TRISIO values to 6 bits.
  9. #9
    3v0
    3v0 is online now
    Join Date
    Jul 2006
    Location
    USA
    Posts
    6,464
    Blog Entries
    11
    Quote Originally Posted by be80be View Post
    Should be 0b000000
    What should be 0b000000. Why ?
  10. #10
    Join Date
    Aug 2008
    Location
    morristown,tn
    Posts
    2,000
    It's sinking down to RA2 I tried it. My ideal didn't work I figured make all pins output would stop it but it still sink to RA2 to turn on D2. If you source RA4 and sink RA5 D2 come's on to. If you make RA2 high to turn off D2 you lite 3 leds
  11. #11
    Join Date
    Aug 2008
    Location
    morristown,tn
    Posts
    2,000
    I can flash the leds in a roll but it don't want to turn on just 1 lol I see why it would drive you cazy
  12. #12
    3v0
    3v0 is online now
    Join Date
    Jul 2006
    Location
    USA
    Posts
    6,464
    Blog Entries
    11
    It is not difficult. You can figure out which lines are hi low or tristated for each LED by looking at the schematic.
  13. #13
    Join Date
    Jan 2009
    Posts
    8
    thanks for the help guys, I think we've cracked it, it annoys me that I left everything at work so can't test it before tuesday!
    edit:
    the next stage is to ask if you can alter the TRISIO value later in the code as I'm attempting to write a program to turn all the LEDs on in sequence, and it would be nice to be able to set different pins to input as and when they're needed to turn a specific LED on or off....
  14. #14
    3v0
    3v0 is online now
    Join Date
    Jul 2006
    Location
    USA
    Posts
    6,464
    Blog Entries
    11
    Yes you can.
    I would put the TRIS and GPIO values for each LED into arrays. To turn on LED3 you
    TRISIO=trisioArray[3];
    GPIO = gpioArray[3];
    Better yet define it as a macro or a function. With a small pic I would use the macro
    #define LED_ON(n)  TRISIO=trisioArray[3];GPIO = gpioArray[3]
    // to turn on LED2 use
    LED_ON(2);
    This is code written for the Junebug which has 3 switches and 6 charlieplexed LEDs. It may be of interest.
    // ADVANCED COMPUTER SCIENCE  9/23/2008
    // DEMO PROGRAM
    // Name:    read switches
    // Purpose: demostrate how to read switches and the
    //          use of arrays to operate the LEDs
    // settings for configuration memory
    #pragma	config OSC = INTIO2, WDT = OFF, LVP = OFF
    // processor definitions
    #include <p18f1320.h>
    // tell the compiler these are unsigned 8 bit
    // constants that can be stored in flash with
    // the program code.
    rom const unsigned char lataVal[] =
              {0x01,  0x40, 0x40, 0x80, 0x80, 0x01};
    rom const unsigned char trisaVal[] =
              {~0x41,~0x41,~0xC0,~0xC0,~0x81,~0x81};
    void main(void)
      unsigned char sw;
      unsigned char btn1;
      unsigned char btn2;
      unsigned char btn3;
      // crank up the internal clock to 8MHz
      OSCCONbits.IRCF0=1;
      OSCCONbits.IRCF1=1;
      OSCCONbits.IRCF2=1;
      ADCON1=0x70;        // all digital
      TRISB=0x25;         // Switches on RB0 RB2 RB5
      // PORTB weak pullups for switches
      INTCON2bits.RBPU=0;
      while(1)
        // Read from PORTB,
        // what would happen if used
        //'sw=PORTB&0x25' instead ?
        // Use PORTB not LATB with weak pullups.
        sw=PORTB;
        // deterimine if any was pressed
        btn1 = (!(sw & 0x01));  // RB0
        btn2 = (!(sw & 0x04));  // RB2
        btn3 = (!(sw & 0x20));  // RB5
        // turn on correct LED if switch was pressed
        if(btn1)  // why do we not use "if(btn1==1)" ?
          LATA=lataVal[0];
          TRISA=trisaVal[0];
        if(btn2)
          LATA=lataVal[1];
          TRISA=trisaVal[1];
        if(btn3)
          LATA=lataVal[2];
          TRISA=trisaVal[2];
  15. #15
    Join Date
    Aug 2008
    Location
    morristown,tn
    Posts
    2,000
    Ok I'm going to stay away from C . Here how to Bink 1 led on the pickkit1 in assembly
    	list p=12f675
    	include "p12f675.inc"
    __CONFIG _CPD_OFF & _CP_OFF & _BODEN_OFF & _MCLRE_OFF &_PWRTE_OFF & _WDT_OFF & _INTRC_OSC_NOCLKOUT
    #define	BANK1		banksel 0x80	;Select BANK1
    #define	BANK0		banksel 0x00	;Select BANK0
     cblock 	0x20 			;start of general purpose registers
    		count1 			;used in delay routine
    		counta 			;used in delay routine
    		countb 			;used in delay routine
    	endc
    	org	0x0000			;org sets the origin, 0x0000 for the 12f675,
    main
    	call    0x3FF      ; retrieve factory calibration value
    	BANK1
    	movwf   OSCCAL      ; update register with factory cal value
    	BANK0
    	clrf	GPIO		;Clear Port
    	BANK1
    	clrf	ANSEL
    	movlw	0xFF
    	movwf	TRISIO		;Tri-State All Inputs
    	clrf	VRCON		;Vref Off
    	BANK0
    	movlw	0x07
    	movwf	CMCON		;Comparator Off
    start:
    	 bsf     STATUS,RP0       ; select Register Page 1
             bcf     TRISIO,4          ; make IO Pin C0 an output
    	 bcf	 TRISIO,5
    	 bcf     STATUS,RP0       ; back to Register Page 0
             bsf     GPIO,4          ; turn on LED C0 (DS1)
    	 call	 Delay			;this waits for a while!
    	 clrf	 GPIO         ;turn off led
             goto    start                ; wait here
    Delay	movlw	d'250'			;delay 250 ms (4 MHz clock)
    	movwf	count1
    d1	movlw	0xC7
    	movwf	counta
    	movlw	0x01
    	movwf	countb
    Delay_0
    	decfsz	counta, f
    	goto	$+2
    	decfsz	countb, f
    	goto	Delay_0
    	decfsz	count1	,f
    	goto	d1
    	retlw	0x00
    	end
    Don't like C
+ Reply to Thread
Page 1 of 2
1 2 Last
  1. Sometimes, I really hate PIC
    By Hanxa in forum Micro Controllers
    Latest: 2nd November 2007, 06:31 AM
  2. I hate RAP Music.
    By one_resistor in forum Electronic Projects Design/Ideas/Reviews
    Latest: 20th July 2007, 01:17 PM
  3. I hate the PICKit2
    By NJ Roadmap in forum Micro Controllers
    Latest: 16th December 2006, 11:44 PM
  4. I hate crystals.
    By 0mega in forum Micro Controllers
    Latest: 25th March 2004, 06:42 PM
  5. 12F675 & PBPro & PicKit1
    By rjwheaton in forum Micro Controllers
    Latest: 8th February 2004, 08:57 AM
Tags for this Thread
