Old 23rd January 2009, 08:54 AM   #1
Default Is there any need to use External ADC for PIC16F877A
I'm new to pic controller. I connected -Vref at port A.2 and +Vref at port A.3 and Analog input at Port A.5. Then the out put will be store where. Thanks in advance.
vinoth is offline
Old 23rd January 2009, 08:58 AM   #2
If you are OK with 10 bit resolution, there is no need for an external A2D convertor with a 16F877A.
What is the volatge you want to convert.? volts etc...
ericgibbs is offline
Old 23rd January 2009, 12:21 PM   #3
Thanks for your suggestion. In my application I need a 8 bit resolution.
vinoth is offline
Old 23rd January 2009, 01:03 PM   #4
In which case you are perfectly fine with the 16F877A, it can be easily configured to allow simple 8 bit readings.
My tutorials explain how to use the analogue inputs.
Old 23rd January 2009, 01:22 PM   #5
What voltage are you trying to convert.?
The description of the -/+Vref is puzzling.
Old 23rd January 2009, 01:33 PM   #6
Arrow
-Vref=-2v and +Vref=6v
vinoth is offline
Old 23rd January 2009, 01:35 PM   #7
You can't have a negative Vref, 0V is as low as you can go, you also can't go above Vdd (usually 5V).
This is pretty universal with all ADC's.
DC shift the signal so it fits within the permitted limits.
Old 23rd January 2009, 01:39 PM   #8
Post a diagram showing the PIC adc input connection.
You dont seem to understand the PIC's specification.
adc, external, pica
External interrupt PIC16F877A Jyothi@Pic Micro Controllers 5 9th January 2009 04:53 AM
External Eeprom AtomSoft Micro Controllers 42 22nd July 2008 05:11 PM
external oscillators amr_karimm Micro Controllers 3 18th April 2004 10:06 AM
external memory curiousCal Micro Controllers 1 18th March 2004 09:19 AM
external RC OSC Deagol_the_Dead Micro Controllers 7 4th December 2003 04:56 AM
