Hey all, Microchip's PIC32 microcontrollers only come in 100 pin TQFP .4 mm pitch and 64 pin TQFP .5 mm pitch packages. These are really nice and inexpensive chips to play around with. My question is, how do I prototype with them? I bought two of these: http://www.futurlec.com/Pictures/TQFP_100.jpg They're double sided .4 and .5 mm 100 pin TQFP breakout boards that fit nicely with any of the PIC32 chips. The holes are DIP sized spacing. My question is, how do I prototype with this? How do I attach it to a breadboard, for example? How do I attach it to a prototyping board like this: http://www.futurlec.com/Pictures/PROTO777.jpg ? What's the best and quickest way to prototype with this chip? | |
The 4 headers on the breakout board are 4 2x13 set at right angles. I think either you have to go to a breadboard where each hole has its own copper donut or etch your own.
__________________ Please post questions to the forums. PM's are for personal communication. BCHS/3v0's Tutorials Junebug USB PIC programmer kit., USB Bit Whacker, The 15 Minute Printed Circuit Board! (+drill time) Last edited by 3v0; 22nd January 2009 at 09:39 PM. | |
| | #3 | |
And I've seen those boards before: http://www.futurlec.com/Pictures/EXPBRD.jpg Since the holes are not connected to each other in rows of 3, 5 of entire rows, how am I supposed to connect components together? | ||
Get a bigger/stronger board than that, fiberglass (FR4) is best. Buy a bunch of breakaway .100" female headers 3M|929974-01-36-RK|PC Board Connector | Newark.com and use those on the proto PCB. Next use some Samtec board standoff female headers that have extra long tails, to put on TQFP board http://dkc3.digikey.com/PDF/T091/P0126.pdf and http://www.samtec.com/ftppub/cpdf/SSQ-MKT.PDF The extra long tails can then go thru the TQFP board, AND also have the length to properly mate with the female headers that have been placed on the proto PCB. Then buy a JE10 wire jumper kit. Good luck. | |
nickelflippr's method sounds good ![]() On a protoboard with each hole isolated you need to connect every connection with wire. Wire sold as wire wrap wire is very flexiable and works well for signals and is easy to solder (I am not suggesting you wire wrap). Use heavier wire for power and ground.
__________________ Please post questions to the forums. PM's are for personal communication. BCHS/3v0's Tutorials Junebug USB PIC programmer kit., USB Bit Whacker, The 15 Minute Printed Circuit Board! (+drill time) | |
| | #6 | |
I'll go with that and make my own PCB as well. Since it's relatively easy to make a PCB for DIP sizes, this should work well. Thanks! | ||
| | #7 | |
| | #8 |
Yes, exactly. I've tried male headers, and making squid type cables, but nothing seems to beat the simplicity of using 22ga. jumper wire (in my case, it usually is going to a breadboard anyways). I'm not nearly as brave as you, using a 100 pin TQFP has got to be a pain. While the bare PIC32 prices are attractive, I would likely flake out, and get one these SparkFun Electronics - Development Board for PIC32MX340F512 | |
| | #9 | |
| | #10 |
Glade to see this post I have a lot of pic 32 samples but I couldn't find a brakeout board now I know where it get them. Next is soldering them just flux and go come back and clean with a wick and be good to go. | |
| | #11 | |
On the Samtec female headers (or whose else?), the 0.394" tail length seems to be the one. It will give you full engagement in the PCB mounted header, plus the TQFP pcb, plus a solder joint and a little room to spare. | ||
| | #12 |
| Do you have a link for the flux/syringe that you use? Could have another go at the drag soldering, then wick, technique. Last time was a disaster on a TSSOP device, with too generously applied flux (no syringe), and the flux aftermath got up under the chip!
| | #13 | |
Also, watch this video: YouTube - Surface Mount Soldering 101 (surface mount soldering) | ||
| | #14 |
I got it at radio shack but thay stop selling it now all thay want to sell is cell phones
| | #15 | |
I hate it when suppliers like these go for consumer electronics. It just makes that store that much more retarded. I never go to places like that anymore. I go to electronics parts surplus stores only now. | ||
| pic32, prototyping |
| LCR meter. (And prototyping) | yngndrw | Electronic Projects Design/Ideas/Reviews | 16 | 6th July 2009 04:38 PM |
| Wirewrap and other Prototyping | dknguyen | General Electronics Chat | 6 | 13th March 2008 04:20 PM |
| PCB Prototyping | yngndrw | General Electronics Chat | 30 | 22nd August 2007 07:30 PM |
| PCB Prototyping | danuke | Electronic Projects Design/Ideas/Reviews | 18 | 24th July 2007 12:17 PM |
| need prototyping ideas | riskbreaker | Electronic Projects Design/Ideas/Reviews | 4 | 4th September 2003 06:31 PM |
