Old 17th January 2009, 07:36 AM   #1
Default PIC programming question
I downloaded a PIC programme from the internet for a PIC16F88.
PORTA 1, 2 & 3 are used as analogue inputs.
But there is an instruction in the programme that I don’t understand.
movlw (1<<ana1)|(1<<ana2)|(1<<ana3)
I’m familiar with the normal movlw instruction, eg. movlw 0x1A, but not with the one above.
In the definitions, the parameters are defined as:-
ana3 equ 3 ; analog input AN3
ana2 equ 2 ; analog input AN2
ana1 equ 1 ; analog input AN1
Any assistance will be appreciated.
Len
ljcox is offline
Old 17th January 2009, 07:45 AM   #2
Your setting the bit to 1
be80be is offline
Old 17th January 2009, 07:51 AM   #3
Bitwise inclusive OR
be80be is offline
Old 17th January 2009, 07:54 AM   #4
The "<<" directive shifts the number left by the number to the right.
So,
1<<3 = 8
1<<6 = 64
and so the movlw instruction above if the same as movlw b'00001110'.
Pommie is online now
Old 17th January 2009, 08:23 AM   #5
So it is moving a 1 right so it would put
 b'00001110'
but why the pipe | is it for stacking
which is the same as this
movlw b'00001110
And this set a 0
movlw b'11111111'-(1<<ana1)-(1<<ana2)-(1<<ana3)
which is
movlw b'11110001
be80be is offline
Old 17th January 2009, 08:33 AM   #6
 b'00001110'
The pipe means OR. I've seen people do this in C too. What it usually means is that they don't know how to convert to binary. This gets the bits in there in a roundabout way.
futz is online now
Old 17th January 2009, 08:35 AM   #7
The | is inclusive or and so,
b'00000010' or b'00000100' or b'00001000' = b'00001110'
Old 17th January 2009, 07:56 PM   #8
Thanks for the prompt responses. Much appreciated.
I understand. eg. 1<<n means shift left n places.
| means inclusive OR.
It seems a complicated way to do something simple, but I guess he had his reasons.
Len
ljcox is offline
Old 17th January 2009, 08:23 PM   #9
| means inclusive OR.
Isn't it just standard C? - and I don't even do C.
Old 17th January 2009, 10:23 PM   #10
Arithmetic operators may be used with directives and their variables.
These operators cannot be used with program variables. They are for use with directives only.
From Mplab Assembler
be80be is offline
Old 18th January 2009, 02:47 AM   #11
The reason it is done this way is so that if sometime in the future the design was changed and instead of A2, A4 was used then it is a simple matter to change,
ana2 equ 4 ; analog input AN2
rather than trying to find all occurrences in the code.
I use to use this method to setup SFRs. EG,
	movlw	(1<<GIE|1<<PEIE|0<<TMR0IE|0<<INTE|0<<RBIE|0<<TMR0IF|0<<INTF|0<<RBIF)
	movwf	INTCON;		enable Peripheral interrupts
but it confused people and so I stopped using it.
Old 18th January 2009, 08:53 PM   #12
It may be, but I know nothing at all about C.
Len
ljcox is offline
Old 18th January 2009, 08:57 PM   #13
Thanks Mike.
Len
ljcox is offline
Old 18th January 2009, 11:23 PM   #14
I like It. It works for me and makes a lot of sense to me.
_______________________________________
But I have never been confused
be80be is offline
pic, programming, question
C programming question MrMikey83 General Electronics Chat 12 4th January 2006 10:36 PM
PIC programming question Deni Micro Controllers 1 11th May 2004 06:03 PM
PIC programming question Andy_123 Micro Controllers 4 7th March 2004 01:53 PM
Programming PIC question... udi_hakim Micro Controllers 4 17th January 2004 10:54 AM
some question about programming watson Micro Controllers 3 17th August 2003 05:59 AM
