Old 14th January 2009, 12:36 AM   #1
Default help with pic 12F509
i am a tech at this company i work for and one of my engineers asked me to write a program from the schematic he provided me.
ok so this is my question... my first assignment was to write a code that would enable the pic to turn the motor on for 6 seconds when the switch is pressed then turn off to reserve power and again turn on when the swith is pressed again .
i presume it is a NC switch
can anyone help me out with this.
crzy engineer is offline
Old 14th January 2009, 12:56 AM   #2
What PIC part number? I can't quite make it out... Does it say 12F508/509?
Mike, K8LH is offline
Old 14th January 2009, 01:01 AM   #3
Use a N.O. switch,like shown here as the RA3/MCLR buttonhttp://ww1.microchip.com/downloads/e...0Schematic.pdf
nickelflippr is online now
Old 14th January 2009, 01:03 AM   #4
The place to start is the template file you will find in C:\Program Files\Microchip\MPASM Suite\Template\Code called 12F509temp.asm. You will need to turn off the MCLR pin as your engineer has used it as the input pin. (change _MCLRE_ON to _MCLRE_OFF).
You will then need to read the datasheet to figure out how to turn on the weak pullup resistors and make GP4 an output. For the delay you can use the Pic Delay Generator and that should get you started.
Pommie is online now
Old 14th January 2009, 01:04 AM   #5
I guess you missed the title.
Old 14th January 2009, 01:11 AM   #6
Yes I did. Guess I became too focused on the schematic and very curious about the normally closed push button switch (grin)...
Old 14th January 2009, 01:24 AM   #7
Hey mike thanks for the info.
im guessing from what you wrote he made a mistake with the MCLR pin?
Old 14th January 2009, 01:39 AM   #8
is there anything wrong with the NC push button?
Old 14th January 2009, 01:55 AM   #9
thanks for the suggestion nickel
Old 14th January 2009, 01:55 AM   #10
There is nothing wrong with using the MCLR pin. It is just unusual as it is normally used after all the other pins are allocated. The only thing wrong with the NC switch is that it will use (slightly) more current than a NO but as you have a motor in the circuit the extra amount is insignificant.
Old 14th January 2009, 02:02 AM   #11
ok i understand what you said. Im thinking he used it because that pin is only an input am i correct?
Old 14th January 2009, 02:49 AM   #12
Yes, it is input only but this suggests that the circuit will be extended to use the other pins. Also, with no MCLR pin and the internal oscillator, some (cheapo) programmers may not be able to reprogram the chip.
Old 14th January 2009, 01:40 PM   #13
This guy has the best tutorials on PIC's
heres some for the 12F509.
http://http://www.gooligum.com.au/tut_baseline.html
Oblong is offline
pic
Needing help with delay times on a 12f509 Darkstar64 Micro Controllers 16 14th August 2008 12:59 AM
