Old 13th January 2009, 06:15 AM   #1
Arrow Junebug "VDD Level Error"
My Junebug is not working with my personal home computer.It says "VDD level error check target & retry operation"
The thing is my junebug is working in my friends computer.
I measured some voltages in junebug.
U5V = 4.4V
VPP = 10.69V
I'm going to check my PC's power unit whether I can do something .......
Any ideas?
Gayan
My Website
http://gsmicro.blogspot.com/
Gayan Soyza is offline
Old 13th January 2009, 06:57 AM   #2
Can you try running it via a powered hub?
Pommie is offline
Old 13th January 2009, 06:59 AM   #3
Sorry no any powered hubs
Gayan
My Website
Old 13th January 2009, 11:32 AM   #4
U5V = 4.4V
VPP = 10.69V
Any ideas?
Simple question.. are you testing it on the exact same target board? If so try powering the board from a external supply. (your pc may not be sending enough power) are you using many USB ports? (with higher power devices on it)
If you are doing that already... remove the external power and any parts such as regulators from the target. It may be faulting and causing a power issue.
AtomSoft is offline
Old 13th January 2009, 01:46 PM   #5
Try jumpering on the 16 pin breakout connector pins U5V & +5V
Also make sure you used a 1N581x diode not a 1N400x
Bill
Smart Kits build Smart People
Old 15th January 2009, 03:25 AM   #6
Hi thanks for the replies.
Yes when powering external 5V its working nicely.But I need to make my junebug to work like self powering programmer I need to check the power unit in my computer.
When that error occurs I firstly did bypass both 2N7000 & BS250 mosfets.Its working but cannot program PICs with INTOSC & MCLR OFF
Gayan
My Website
junebug, vdd level error
while(feet!=wet) { search(friendly="Linux", hardware="avr", software="kde desktop");} FirefighterBlu3 Micro Controllers 6 12th September 2008 06:31 PM
Error "debris" left on PCB in Eagle zevon8 General Electronics Chat 2 13th May 2007 01:54 AM
IC Prog error :" Verify failed at address 0x0000" G-nome Micro Controllers 11 28th January 2004 09:12 PM
IC-Prog ERROR ("Verify failed at address 0000h!") neohack Micro Controllers 9 24th December 2003 08:20 PM
Newbie with "Verify Failed at address 0000h" error Beefer3 Micro Controllers 14 15th September 2003 09:22 AM
