Old 11th January 2009, 09:38 AM   #1
Default BoostC Help
Hi guys, I have got a PIC dev kit with loads of LED's on it, and I have been successful in having them chase after each other. I have included the code I used for my 16F877A. I need help in creating a more efficient program.
// PIC16F877A
#include<system.h>
// _LVP_OFF disables Low Voltage Programming, enabling use of the RB3 output.
#pragma DATA _CONFIG, _CP_OFF & _PWRTE_OFF & _WDT_OFF & _HS_OSC & _LVP_OFF
#pragma CLOCK_FREQ 5000000
void main()
    // - turn portb inputs that we are using into digital mode.
    adcon1 = 00000110b;
    trisb = 0x00;
    trisc = 0x00;
    trisa = 0x00;
    while( 1 )
            porta = 0x01;
        delay_ms( 50 );
        porta = 0x02;
        delay_ms( 50 );
        porta = 0x04;
        delay_ms( 50 );
        porta = 0x08;
        delay_ms( 50 );
        porta = 0x10;
        delay_ms( 50 );
        porta = 0x20;
        delay_ms( 50 );
        porta = 0x40;
        delay_ms( 50 );
        porta = 0x80;
        delay_ms( 50 );
        porta = 0x00;
        portb = 0x01;
        delay_ms( 50 );
        portb = 0x02;
        delay_ms( 50 );
        portb = 0x04;
        delay_ms( 50 );
        portb = 0x08;
        delay_ms( 50 );
        portb = 0x10;
        delay_ms( 50 );
        portb = 0x20;
        delay_ms( 50 );
        portb = 0x40;
        delay_ms( 50 );
        portb = 0x80;
        delay_ms( 50 );
        portb = 0x00;
        portc = 0x01;
        delay_ms( 50 );
        portc = 0x02;
        delay_ms( 50 );
        portc = 0x04;
        delay_ms( 50 );
        portc = 0x08;
        delay_ms( 50 );
        portc = 0x10;
        delay_ms( 50 );
        portc = 0x20;
        delay_ms( 50 );
        portc = 0x40;
        delay_ms( 50 );
        portc = 0x80;
        delay_ms( 50 );
        portc = 0x00;
I was thinking of having i as a variable and implementing this statement, but when I try it doesn't work:
for (i=8;i>0;i--)
How can I use this statement in my program.
// PIC16F877A
#include<system.h>
void main()
    adcon1 = 00000110b;
    trisb = 0x00;
    trisc = 0x00;
    trisa = 0x00;
    while( 1 )
		int i
		for(i=8;i>0;i--)
        porta = i;
        delay_ms( 50 );
I know im awfully wrong with the second code. Also ignore the fact that there are no portb, or portc in the second code
usif is offline
Old 11th January 2009, 10:33 AM   #2
    while( 1 )
        int i;   // a semi-colon is required to tell the compiler that
                 // you're at the end of a command
        for(i=8;i>0;i--)
           // braces are required when you want to include
           // more lines in the body of the for instruction
           porta = i;
           delay_ms( 50 );
Now the code should compile correctly, but you might need to change your program using shift operators in the for loop to get the desired effect.
Your for loop sets PORTA pins as follows:
PORTA = 8 = b'00001000'
PORTA = 7 = b'00000111'
PORTA = 6 = b'00000110'
PORTA = 5 = b'00001001'
PORTA = 4 = b'00001000'
PORTA = 3 = b'00000011'
PORTA = 2 = b'00000010'
PORTA = 1 = b'00000001'
eng1 is offline
Old 11th January 2009, 11:01 AM   #3
My guess at this time of night is,
void main()
char i;
    adcon1 = 00000110b;
    trisb = 0x00;
    trisc = 0x00;
    trisa = 0x00;
    while( 1 )
	for(i=1;i!=0;i<<=1){
	    porta = i;
            delay_ms( 50 );
        porta=0;
        delay_ms( 50 );
Pommie is offline
Old 11th January 2009, 11:47 AM   #4
You might do it this way as well;
    while(1)
    { i = 1;                 // night rider effect
      while(i)               //
      { porta = i;           //
        delay_ms(50);        //
        i <<= 1;             // shift left
      i = 128;               //
      while(i)               //
      { porta = i;           //
        i >>= 1;             // shift right
        delay_ms(50);        //
Mike, K8LH is online now
Old 11th January 2009, 11:55 AM   #5
    while(1)
      while(i)               //
      { porta = i;           //
        delay_ms(50);        //
      i = 128;               //
      while(i)               //
      { porta = i;           //
        delay_ms(50);        //
Hi Mike,
You missed out the all LEDs off state.
Pommie is offline
Old 11th January 2009, 01:15 PM   #6
If you want LEDs off between the back-and-forth scans, you might add a few more lines;
    while(1)
    { porta = 0;             //  All LEDs off
      delay_ms(100);         //
      while(i)               //
      { porta = i;           //
        delay_ms(50);        //
      porta = 0;             // all LEDs off
      delay_ms(100);         //
      i = 128;               //
      while(i)               //
      { porta = i;           //
        delay_ms(50);        //
Old 15th January 2009, 06:47 AM   #7
Can anyone tell me whats wrong with this code? I am trying to get an input from porta.0 so that it would change direction of the LED chase.
#include<system.h>
#pragma CLOCK_FREQ 20000000
void main()
	#define a porta.0;  // Define porta.0,1.2 as variable a,b,c
	#define b porta.1;  // These will be used as the input variables
	#define c porta.2;
    adcon1; = 00000110b; //digital
    trisb = 0x00; //Output
    trisc = 0x00; // Output
    trisa = 0xFF; // Turn Porta A as an Input
    char i; // introduce I as a variable for the flash
    while( 1 )
		for(i=0;i!=0;i<<=1){
			portb = i;
            delay_ms( 50 );
			portb = 0;
			delay_ms( 15 );
				if(a){
			for(i=0;i!=0;i>>=1) {
			portb = i;
			delay_ms ( 50 );
			 portb = 0;
			 delay_ms ( 50 );
usif is offline
Old 15th January 2009, 07:25 AM   #8
When you shift zero left it is still zero,
Try,
    while( 1 )
            portb = i;
            delay_ms( 50 );
        portb = 0;
        delay_ms( 15 );
        if(a){
            for(i=128;i!=0;i>>=1) {
                portb = i;
                delay_ms ( 50 );
             portb = 0;
             delay_ms ( 50 );
Last edited by Pommie; 15th January 2009 at 07:47 AM. Reason: There was one too many braces!!
Pommie is offline
Old 15th January 2009, 07:43 AM   #9
This is a nice experiment I also like very much & leaned many things.
One thing I noticed that PORTA.0 input will act at the end of the pattern??
Gayan
My Website
http://gsmicro.blogspot.com/
Gayan Soyza is offline
Old 15th January 2009, 09:17 AM   #10
Mike, Thanks for your reply, and you pointed out another error which I hadnt found yet (normally I would compile, and look at any of the oddities of the project, and edit again)
However, what I failed to say in my previous post was that the code will not compile. Ive double checked for any oddities and the usual ";" forgotten (as a noob, I guess), and there are none. I get these errors:
Building...
BoostC Optimizing C Compiler Version 6.90 (for PIC16 architecture)
http://www.sourceboost.com
Copyright(C) 2004-2008 Pavel Baranov
Copyright(C) 2004-2008 David Hobday
Single user Lite License (Unregistered) for 0 node(s)
Limitations: PIC12,PIC16 max code size:2048 words, max RAM banks:2, Non commercial use only
SourceBoost1.c
C:\Documents and Settings\Yousif\Desktop\SourceBoost1.c(11): error: general error
failure
"C:\Program Files\SourceBoost\boostc.pic16.exe" SourceBoost1.c -t PIC16F877A
Exit code was 1.
Removing target: SourceBoost1.obj
C:\Documents and Settings\Yousif\Desktop\SourceBoost1.c(11): error:  failure
Done
Line 11 is the opening brace after "void main ()". Also it gave me an error earlier about the "adcon1 = 00000110b;" line, which it said a semicolon was missing. I had used that line earlier in the previous project, and it compiled fine. I gave a semicolon after
"adcon1" and it shut up about that error. I have my doubts on this - is this usual?
usif is offline
Old 15th January 2009, 09:25 AM   #11
Lines that start #define should not end in a semi colon.
Pommie is offline
Old 15th January 2009, 09:29 AM   #12
Fixed that problem, and it still wont compile. Giving me the same error.
usif is offline
Old 15th January 2009, 09:36 AM   #13
Gayan,
It is always easier to follow C if the indentation is correct. Every { you indent 4 more characters and every } you indent 4 less characters.
    while(a==1) //active low type switch
        PORTB = i;
        delay_ms(50);
        i=i<<1;
        if(i==0)
            PORTB = 0;
            delay_ms(50);
            i = 1;
    i = 128;
    while(b==1) //active low type switch
        PORTB = i;
        delay_ms(50);
        i=i>>1;
        if(i==1)
            PORTB = 0;
            delay_ms(50);
            i = 128;
To make the light go one way and reverse whenever the button is pressed I would do,
    i=1;
    while(1)
        if(a)
            i>>=1;
            if(i==0)
                i=128;
        }else
            i<<=1;
            if(i==0)
                i=1;
        PORTB=i;
Pommie is offline
Old 15th January 2009, 09:56 AM   #14
Gayan,
Hi thanks Mike,I must very careful with braces alignment. I was searching wheres my post after I deleting it, you got it thanks for that
Gayan
My Website
Old 15th January 2009, 10:08 AM   #15
It took a while to find that error as the compiler gives a nonsense error message, the line
should be,
    adcon1 = 0b00000110; //digital
Pommie is offline
boostc
BoostC Charlieplexed PWM 32 Mike, K8LH Micro Controllers 140 27th March 2009 11:19 AM
Hardware SPI with BoostC weirdness futz Micro Controllers 0 23rd July 2008 06:57 AM
BoostC Flaw? AtomSoft Micro Controllers 7 19th July 2008 04:32 AM
BoostC USART 18F AtomSoft Micro Controllers 9 29th June 2008 05:02 PM
math.h and lib for BoostC? futz Micro Controllers 3 31st March 2008 06:29 AM
