Old 7th January 2009, 09:42 AM   #1
Question Problem facing when using Timer0 of 16f877a
hi guys,
i'm now trying to use Timer0 of 16f877a to overflow every 6.25ms. So this is how i calculate the TMR0 value. i'm using 4Mhz XTAL. and my prescaler is set to 1:256.
4Mhz/4= 1Mhz
1Mhz/256 = 3906.25hz
1/3906.25hz = 256us
6.25ms/256us=24.41
256 - 24.41 = 231.58
so i decided to use 232 as my TMR0 value. So am i correct?
in my program, i complement my LEDs everytime interrupt occur which mean every 6.25ms. But when i measure the period from my logic analyzer i found that the period time is not correct. SO i'm wonder maybe is my calculation problem or other .
thank you.
simpsonss is offline
Old 7th January 2009, 10:38 AM   #2
If you set TMR0 to 232 then you will get an overflow every (256-232)*256 = 6144 instruction cycles.
1,000,000/6144 = 162.7 Hz
1/162.7 = 0.006114 Seconds or 6.114mS
Looks good to me. Even if it is kinda circular.
However, you will get better accuracy if you set the prescaler to 32 and TMR0 to 61.
<edit> Note that this time is for half a period and so a frequency meter will register 80Hz.</edit>
Pommie is offline
Old 7th January 2009, 10:41 AM   #3
The gap is too big.
Better set pre scaller to 32 & load 195(61) to TMR0.
195*32 = 6240uS
So you need to add another 10uS to your routine.
EDIT:Mike answered before
Gayan
My Website
http://gsmicro.blogspot.com/
Gayan Soyza is offline
Old 8th January 2009, 01:03 AM   #4
Seems like my calculation is correct. The following is my picBasic code. Where am i go wrong? because the period of one logic high or logic low is wrong.
'DECLARE SYMBOLS
Symbol T0IF = INTCON.2 ' TMR0 Overflow Interrupt Flag
Symbol T0IE = INTCON.5 ' TMR0 Overflow Interrupt Enable
Symbol GIE = INTCON.7 ' Global Interrupt Enable
Symbol PS0 = OPTION_REG.0 ' Prescaler Rate Select
Symbol PS1 = OPTION_REG.1 ' Prescaler Rate Select
Symbol PS2 = OPTION_REG.2 ' Prescaler Rate Select
Symbol PSA = OPTION_REG.3 ' Prescaler Assignment
Symbol TOCS = OPTION_REG.5
symbol LED = PORTB
TRISB = 0
PORTB = 0
PS0 = 1
PS1 = 1
PS2 = 1
thank you for the reply.
Old 8th January 2009, 02:50 AM   #5
I can't see anything wrong. Can you try a non-interrupt version.
Something like,
    OPTION_REG=7
    while(1)
        while(INTCON.TMR0IF=0)
        wend
        INTCON.TMR0IF=0
        TMR0=232
        LED = ~LED
    wend
Pommie is offline
Old 8th January 2009, 03:03 AM   #6
HI,
yeah~ the code u given works.i can get half period for 6.15ms. So what wrong with my part?
After i troubleshooting my code. i found that when i enable global interrupt, it wont work. but once i disable it. i cant get 6.20ms back for half period.
thank you.
Old 8th January 2009, 03:47 AM   #7
I'm afraid I'm not familiar with the compiler that you are using so can't really help. I suspect it is something to do with the interrupt code. Is there a forum for your compiler?
If you state which compiler it is then maybe someone else who is familiar with it might help.
Pommie is offline
Old 8th January 2009, 04:05 AM   #8
i'm using PIC basic pro compiler.
anyway thanks.so instead of using the interrupt i also can use the code u write to generate the frequency i want.Am i correct?
Old 8th January 2009, 04:10 AM   #9
i'm now trying to write the code in assembly and try the interrupt again.
Old 8th January 2009, 04:19 AM   #10
anything wrong with my code?
list p=16F877A
#include <p16F877A.inc>
ORG 0x00
goto Main
org 0x04
goto T0_INT
Main
bsf STATUS,RP0 ;switch 2 bank1
clrf TRISB
movlw b'00000111'
movwf OPTION_REG
bcf STATUS,RP0 ;switch 2 bank0
movlw 0xe8
movwf TMR0
movlw 0xa0
movwf INTCON
clrf PORTB ;clear PORTB
goto $
;interrupt subroutine
T0_INT
clrf T0IE
clrf T0IF
movlw 0xe8
movwf TMR0
comf PORTB
bsf INTCON,5
retfie
END
thanks.
Old 8th January 2009, 04:26 AM   #11
You're code is very close to working, you need a config line and I changed the INTCON bits just in case.
try,
		list	p=16F877A
		__config _XT_OSC & _PWRTE_OFF & _WDT_OFF &_LVP_OFF
		org	0x00
		goto	Main
		org	0x04
		goto	T0_INT
Main
		clrf	TRISB
		movlw	b'00000111'
		movwf	OPTION_REG
		movlw	0xe8
		movwf	TMR0
		bsf	INTCON,T0IE	;enable timer interrupt
		bsf	INTCON,GIE
		goto	$
T0_INT
		clrf	INTCON,T0IF	;clear int flag
		movlw	0xe8
		movwf	TMR0
		comf	PORTB,f
		retfie
		end
Pommie is offline
Old 8th January 2009, 05:44 AM   #12
hi pommie,
since the idea and concept of the code for PicBasic is same as the assmebly which both i written. How come the result is different? ehm...
regards the config line u added in. since everything is off. So why i can get the correct result without adding in the config line?
thanks for the reply.
Old 8th January 2009, 06:51 AM   #13
As you state, the code is identical and so it must be the compiler that does something strange. I would check the manual especially the interrupt section.
With regard to the config line, the default is all ones and so,
LVP would be enabled - rb3 must be tied high.
WDT is enabled - it will reset every few mS.
Oscillator is RC - won't work with a crystal.
Actually, this could be the problem with your basic program. The watchdog timer could be reseting the processor.
Pommie is offline
Old 8th January 2009, 07:52 AM   #14
hi pommie,
ic..really learn alot.thanks. i would like to ask something regard programming style. if i want to read data from a table using assembly. how am i gonna do?
.data 0x01, 0x02, 0x03
some sort like dis. i want to display the data 1 by 1 to the led. how is the coding idea?
thank you.
Old 8th January 2009, 08:02 AM   #15
You use an instruction called retlw and do a jump into the middle of the message,
Message		addwf	PCL,F
		retlw	0x01
		retlw	0x02
		retlw	0x03
To use it you put the item number in W and call Message.
You can also use dt to write a string of bytes,
		dt	0x01,0x02,0x03
OR,
		dt	"Hello world!",0
<edit> forgot to mention, these types of tables must reside in 1 page of memory.</edit>
Pommie is offline
facing, problem, timer0
Timer0 problem littletransistor Micro Controllers 8 27th November 2008 06:55 AM
LCD & CHECK CODE (facing problem) smileguitar Micro Controllers 17 20th March 2008 05:30 PM
Problem in LED Flasher in pic 16F877A rakan Micro Controllers 6 7th April 2007 11:45 AM
info about computes im facing some hardware problem salman007 Chit-Chat 6 29th March 2007 07:23 PM
XTAL Problem in PIC 16F877A Hesam Kamalan Micro Controllers 7 16th July 2006 07:41 PM
