Old 19th December 2008, 05:40 PM   #1
Default Multiplexing 7 Segment Displays with PIC 16F627
I have a PIC 16F627, and I want to make a digital clock with it. The only problem I have is that I only have enough outputs for one 7-seg display unless I multiplex them.
Can someone please point me in the right direction of multiplexing 6 common cathode 7-seg displays (to show hours, minutes, and seconds).
Thanks to everyone in advance!
Cheers
Fred
Last edited by alifred; 19th December 2008 at 05:41 PM. Reason: Bad grammar! (My mum would me cross!)
alifred is offline
Old 19th December 2008, 05:43 PM   #2
Cheers
Fred
Use the Forum SEARCH for charlieplexing
See Pommies drawing here:
charlieplexing max per pin
ericgibbs is offline
Old 19th December 2008, 06:00 PM   #3
Cheers,
I was searching with multiplexing not charlieplexing.
Thanks for such a quick reply
Fred
alifred is offline
Old 21st January 2009, 02:02 PM   #4
Default help
I have a PIC 16F627 with 32.768khz cristal, and I want to make a digital clock with date and time .I have 7-seg display with cd4543 drivers. Can any one help me to write codes for this pic.I dont have any experiance writing codes.so please help me..
Yours
Bimal
bimalchandran is offline
Old 21st January 2009, 03:24 PM   #5
Yours
Bimal
Start your own new thread for this topic.
Old 24th January 2009, 01:35 PM   #6
hi
I had found a circuit with 16f627 and time based clock codes.i need this thing with calendar can you help me to devolop it?
Bimal
Old 24th January 2009, 01:48 PM   #7
One simple thing. Just take 8 pin for displaying and connect this to all the six seven segment display and take 6 for controlling displaying. Connect first controlling input to first seven segment displays Vcc(Through transistor) and second contorl pin to second seven seg's Vcc and so on. program will be similar to.
#bit c1=0x05.0
#bit c2=0x05.0
#bit c3=0x05.0
#bit c4=0x05.0
#bit c5=0x05.0
#bit c6=0x05.0
#byte val=0x06
c1=1;
c2=0;
c3=0;
c4=0;
c5=0;
c6=0;
val=disp1;
delay_ms(20);//20 ms delay
c1=0;
c2=1;
c3=0;
c4=0;
c5=0;
c6=0;
val=disp2;
//so on for all digit.
vinoth is offline
Old 27th January 2009, 01:43 PM   #8
Default thanks
thankyou sir.
I willl try to impliment this..and let you know .
displays, multiplexing, pic, segment
Multiplexing 7 segment displays using AVR justin_t AVR 2 25th June 2008 04:23 PM
multiplexing two 7 segment displays rebirth of sands Electronic Projects Design/Ideas/Reviews 10 6th January 2008 10:11 AM
multiple 7-segment displays ico2 Electronic Projects Design/Ideas/Reviews 31 20th February 2007 05:05 PM
Advice on multiplexing ten 7-segment display taengi General Electronics Chat 60 18th April 2006 11:45 PM
What LED 7 segment displays to buy kennydow241 General Electronics Chat 3 24th May 2005 02:25 AM
