+ Reply to Thread
Results 1 to 6 of 6
Thread: BB Regulation help
  1. #1
    3v0
    3v0 is online now
    3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent
    Join Date
    Jul 2006
    Location
    USA
    Posts
    6,463
    Blog Entries
    11
    Default BB Regulation help
    I need to build regulator boards for my students to use with their solderless BB's. They will wire chips in backwards and create shorts, this is a given.
    Here is what I have in mind. It would provide 5V at 100ma, 500ma, and 1 Amp if the wall wart is up to it.
    Brick/wart connects to regulator using screw terminals.
    Just after the terminal block a diode to prevent problems when the brick is hooked up backwards. Maybe setup a red LED to indicate this conditon.
    Two regulators.
    The first will be a LM2931AZ50R .1 amp 5V regulator with reverse voltage and short protection. This regulator will be used when 100 ma is enough, or during initial testing lto ensure there are no shorts or chips in backwards.
    The second will be a generic 7805 regulator with 1 amp and .5 amp PTC fuse on the input side. A jumper block selects which of the 2 fuses powers the regulator.
    Maybe have the 100ma output sperate from the other. One could use the 100ma source for logic and the other for motors or LEDs.
    Suggestion or comments ?
    3v0
    BCHS/3v0's Tutorials
  2. #2
    nickelflippr Good nickelflippr Good nickelflippr Good nickelflippr Good
    Join Date
    Oct 2006
    Location
    Oregon, USA
    Posts
    487
    Using 2.5mm center positive jack would be nice touch to keep polarity straight. In my experience they seem most popular at the thrift stores. Also a bridge might be handy just in case someone trys to plug in an ac/ac wall wart.
  3. #3
    3v0
    3v0 is online now
    Join Date
    Jul 2006
    Location
    USA
    Posts
    6,463
    Blog Entries
    11
    Thanks for the input.
    To make it work with ac/ac would one also need a 22000uf cap in addition to the bridge? Sounds expensive and large.
    I am attempting to use wall warts donated by the parents. Hopefuly enough of them will fall into the 12-7 range that will work with the regulators. There is not telling what sort of plugs they will have. But I do like the idea of not having to use the screw terminals.
    Quote Originally Posted by nickelflippr View Post
  4. #4
    Mike, K8LH Excellent Mike, K8LH Excellent Mike, K8LH Excellent Mike, K8LH Excellent Mike, K8LH Excellent Mike, K8LH Excellent Mike, K8LH Excellent
    Join Date
    Jan 2005
    Location
    Michigan, USA
    Posts
    2,521
    3v0,
    If you get a chance, please look at the Micrel MIC4682 smps 'buck' regulator. It's a 2 amp regulator with current limiting capabilities. The little 1.9"x1.9" evaluation board in the Data Sheet includes jumpers for selecting voltage (1.8, 2.5, 3.3, and 5.0v) and current (0.6a, 1.0a, and 2.0a) and the formulas you would need for coming up with other limit settings.
    It may seem like more work and a larger investement on the "front end" but Micrel (MIC4682) and Coilcraft (DO5022P series) will sample and you'll end up with a very versatile SMPS regulator sub-system for your breadboard experiments.
    Micrel MIC4682 Product Page
    Happy Holidays.
    Mike
  5. #5
    Join Date
    Oct 2006
    Location
    Oregon, USA
    Posts
    487
    No expert on power supplies. Used 2200uf caps on my homemade bench supply. The Olimex Pic-XX protoboards I use, have the mentioned 2.5mm jack/bridge configuration. They rate the input as 9VDC/6VAC. The 16V bypass capacitors are 470uf and 100uf on either side of the LM317 regulator (it has a 3.3V option per shorting pin). Can't actually recall trying an AC wall wart on this setup.
  6. #6
    3v0
    3v0 is online now
    Join Date
    Jul 2006
    Location
    USA
    Posts
    6,463
    Blog Entries
    11
    nickelflippr,
    It has been a long time since I built a supply that han an AC input. I may have added an extra zero on the cap.
    So few of the wall warts I see are AC out, not a lot of motivation to handle it.
    Mike,
    I need to build these over break so I will use what I have or can get from Mouser or Newark if a few days.
    The Micrel MIC4682 looks like a very nice chip. They have a lot of interesting/useful offerings. I will give these a try.
    Also thanks for the kind words regarding the #define 7 seg stuff. We have enough self taught people here that seeing this sort of stuff should be helpful.
    3v0
+ Reply to Thread
  1. Voltage Regulation
    By Manor_Villages in forum General Electronics Chat
    Latest: 9th December 2008, 03:09 AM
  2. 24v - 12v Regulation
    By Pcolaboy in forum General Electronics Chat
    Latest: 8th May 2008, 12:31 AM
  3. Voltage Regulation
    By Carnivore in forum General Electronics Chat
    Latest: 15th January 2007, 12:45 PM
  4. psu regulation
    By monkeytree in forum General Electronics Chat
    Latest: 31st January 2006, 12:26 AM
  5. Trying to improve PSU regulation
    By TheOne in forum Electronic Projects Design/Ideas/Reviews
    Latest: 31st December 2004, 04:15 PM
Tags for this Thread
