Old 17th December 2008, 08:28 AM   #1
Default Icd2 Clone
HELLO GUYS, i am trying to make my own icd2 clone based on stolz configuration, using PIC16F876A.
But i get no responce from mplab.
1. I am using usb to serial converter to communicate with the pic controller.
2. I have burnt the hex file given by stolz in the controller.
3. I have checked the usb to serial converter by echoing in hyperterminal.
4. I have given manual input to Transistors to generate MCLR signal it switches fine between 5v and 13.5v.
5. I am using PN2222 as NPN transistor and C557 as PNP transistor.
note: i am making the circuit on breadboard.
PLEASE SUGGEST WHAT SHOULD I DO NEXT.
LUNAR is offline
Old 17th December 2008, 08:43 AM   #2
Several of us built ICD2 clones. Most of us now use USB based PICkit2's or their clones.
Your echo test of the USB to RS232 converter is not good enough to verify that the adaptor. The ICD2 uses lines other then TX and RX. Most adaptors do not handle these well or at all. My suggestion is to find an old PC with a serial port and use it at least till you verify your ICD2 works.
The only major components that take part in the connect (MPLAB to ICD2) are the RS232 level shifter, and the processor.
Bill has a ICD2 clone kit called the inchworm. blueroomelectronics - Smart Kits Build Smart People Somewhere in his info he talks about adaptors and the one he knows that works.
BCHS/3v0's Tutorials
3v0 is offline
Old 17th December 2008, 02:12 PM   #3
Most USB to rs232 adapters don't work with the ICD2. I built the Unicorn kit to address the problem. As 3V0 said most of us have moved on to USB programmers and clones based on the 18F2550
Bill
Smart Kits build Smart People
Old 17th December 2008, 03:10 PM   #4
I think it have problem by usb to serial converter.
Mea is offline
circuit debugging, icd2, icd2 clone, pic in circuit emulator, programmer for pic
ICD2 Clone and dsPIC javilon Micro Controllers 51 12th January 2009 02:48 PM
New ICD2 clone design. Someone Electro Micro Controllers 18 1st July 2008 12:15 PM
Help with ICD2 clone!!!!!!!!!!!! juanbbv Micro Controllers 17 5th April 2008 06:08 AM
ICD2 Clone with MPLAB 7.30? Mike, K8LH Micro Controllers 1 24th December 2005 10:18 PM
Serial ICD2 Clone PCB available... Mike, K8LH Micro Controllers 35 23rd July 2005 09:59 AM
