| Hi all, I got this probelm and was wondering if anyone can help me. I got 2 PIR detectors that sends a pulse out to the PIC16F628 pin 17 n 18. What i want the microcontroller to do is to figure out which of the 2 PIR's have been triggered and send out a string eg "CAMA" or "CAMB" through pin 8 through the serial port to the PC which ineracts with visual basic 6 (I can do the VB side just not the microcontroller) Thank you for helping me, much appreciated I have started the code, but i was wondering if ne1 can fill the gaps if i missed any. THANKS :lol: Code: LIST P = 16F628 ; MICROCONTROLLER USED
#include "P16F628.INC" ; HEADER FILE (CONTAINS APPROPRIATE EQUATES SECTION
; CONFIGURATION WORD
ERRORLEVEL 0, -302 ; STOPS BANK SELECTION MESSAGES
__CONFIG 0x3D18 ;CONFIGURATION WORD (SETS OSCILATOR ETC)
MOVLW 0X07
MOVWF CMCON
BANKSEL TRISA
MOVLW B'00100011'
MOVWF TRISA
MOVLW B'00000010'
MOVWF TRISB
BANKSEL SPBRG
MOVLW D'12'
MOVWF SPBRG
MOVLW B'00100100'
MOVWF TXSTA
MOVLW B'00000000'
MOVWF PIE1
; Main program
START
BANKSEL PORTA
BTFSC PORTA, 0 ;Check to see if the carry is set
CALL CAMERA_A
BTFSC PORTA, 1
CALL CAMERA_B
GOTO START ;Loop forever
CAMERA_A
C_A
BANKSEL TXSTA
BTFSS TXSTA, TRMT
GOTO C_A
BANKSEL TXREG
MOVLW H'41'
MOVWF TXREG
RETURN
CAMERA_B
C_B
BANKSEL TXSTA
BTFSS TXSTA, TRMT
GOTO C_B
BANKSEL TXREG
MOVLW H'42'
MOVWF TXREG
RETURN
END | |
| Tris B should be loaded with b'00000110' - Both the RX and TX pins have to be set as input in order for the hardware uart to work properly. (page 69 of 16f628 datasheet. section 12.0) Then you have to set bit 7 (SPEN) of register RCSTA, wich enables the usart. (watch out. RCSTA is in another bank then TXSTA) When sending you should check bit TXIF of register PIR1. It will be set when you're allowed to write to TXREG. Waiting for TRMT makes no sense since it is a status bit for the shift register. TXREG may already be empty when the shift register is still....shifting | |
| :idea: It may also be a good idea to sit in a loop after sending the data to make sure that the pin is low before returning to "START" otherwise you will get...... CAMACAMACAMACAMACAMACAMACAMACAMA (etc!) Hope this helps!
__________________ Regards MATT! | |
