Old 22nd January 2009, 01:33 PM   #31
I still haven't figured this out. I even pulled the shield off of the card slot to make sure the contacts were touching the right spots on the card and detect continuity all the way from the contact to the uC pin.
I'm going to leave this for a while and work on some other projects.
I realized my setup picture above points to my Logic analyzer screen shot.
http://www.higginstribe.com/z8e/sdcard-encore-setup.jpg
Mark Higgins
DirtyLude is online now
Old 22nd January 2009, 01:47 PM   #32
Originally Posted by blueroomelectronics View Post
Well you will need a level shifter when using the SPI in hardware for the SDI pin. 3.3V is just not high enough for the Schmitt inputs on a 5V PIC. I'd have to check the datasheet but I recall it's something like VCC-0.8 (4.2V) is a 1.
Hi Bill,
I have had a look at the data sheet but the page doesnt make a lot of sense.
What does it mean?
Mark
UTMonkey is offline
Old 22nd January 2009, 02:02 PM   #33
To better explain that page. It basically shows you the voltage at any given pin (left side aka characteristics) .
So you look for the pin in question in this case I/O PORTS (Except RC4/RC5 in USB MODE)
Then you figure out if its a SCHMITT PIN or TTL or is it RC3 and RC4
If its a SCHMITT pin then the LOW = VSS to .2 from VDD (1v)
The SCHMITT pin HIGH = .8(4v) from VDD to VDD itself (if a pic with 5v source then 5v)
As bill said below:
.8v * 5v = 4v (HIGH)
.2v * 5v = 1v (LOW)
AtomSoft is offline
Old 22nd January 2009, 02:05 PM   #34
It means 0.8 * VCC is a logic high for schmitt inputs
4V with a 5V VCC
Bill
Smart Kits build Smart People
Old 22nd January 2009, 08:49 PM   #35
Thanks Jason and Bill.
UTMonkey is offline
Old 26th January 2009, 02:27 PM   #36
I found my problem. Phase was set incorrectly, so it was clocking data in and out on the wrong edges. I knew it was something stupid like this.
Thanks for giving it a look.
Mark Higgins
Old 27th January 2009, 09:44 PM   #37
Remember the SPO on the SD card is driven not open collector so pullups won't help.
Sparkfun uses this design on one of their level converter designs.
Ok, just pretend I know very little about electronics (there already? good ).
I have just grabbed a spare breadboard and wired up the above circuit with a 5 volt and 3 volt regulator, I wasn't able to source a BSS138 but used a 2N7000 (literally because they are both n-channel mosfet - I still don't understand mosfet operation at all)
With a multimeter and with no inputs on TX-3.3V I measured 3.3 volts on TX-3.3V and 5 volts on TX-5V.
Is this correct? I am guessing yes, but please correct me.
Next, I ground the TX-3.3V . I now measure 0 volts on TX-3.3V and 0 volts on TX-5V.
Is this correct? is this what Bill described as:-
Thanks in advance.
Mark
UTMonkey is offline
Old 27th January 2009, 11:29 PM   #38
Sounds perfect.
Bill
card, query, spisd
IR Query yori Electronic Projects Design/Ideas/Reviews 2 7th January 2008 02:58 PM
query savnik Micro Controllers 17 24th June 2007 01:30 PM
LNB query jeevan772006 Electronic Projects Design/Ideas/Reviews 5 11th December 2005 12:17 PM
amp query monkeytree Electronic Projects Design/Ideas/Reviews 12 19th October 2005 07:27 PM
smart card.....or Xphone card circuit bogdanfirst General Electronics Chat 4 23rd September 2003 12:14 AM
